Question about Frigidaire FWS833A Top Load Washer
My frigidare fex831cs0 makes noise at final spin cycle
  • 25 Answers
SOURCE: load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
Posted on Feb 16, 2008
  • 220 Answers
SOURCE: Frigidaire Washing Machine Model # GLTF1670AS0 Makes very loud
If you want to take the time, I just replaced my drum bearings and seal for $62.00. No really any special tools needed. My model showed the bearings were not sold seperately and you had to buy the complete tub half, but when you take it apart, you can knock out the bearings and buy them online or at a bearing house. I have a seal part number also.
If I remember right the bearing part numbers are 6306-2RS and 6307-2RS (1 each) and the seal is a 40mmX80mmX10mm thick. Make sure you get the -2RS bearings because they are sealed. The ones that came out of mine are shielded bearings ( -Z ) and they will not resist moisture if the seal shaft seal fails.
Most AutoZones have seal and bearing drivers you can "borrow". They really help during installation so you don't deform the seal or damage the new bearings.
Any good bearing house should be able to macth on up or if you post back I can give you the exact number. I think most brands of front washer use the same bearings, but you may want to take yours apart before you buy.
Worst case the junk yard doesn't care if it comes in pieces or as one piece. Give it a try.
Not sure you will want to get this involved, but its not really too bad of a job.
Posted on Dec 31, 2008
SOURCE: Clunking noise and vibration during final spin cycle
For all those who say they recently bought the machine, the cause of the machine "walking across the floor" and vibrating violently is the packaging bolts on the back of the machine that were supposed to be removed when the machine was installed (why it says remove packaging bolts in the installation manual). These packaging bolts hold the suspension steady and firm during shipping but MUST be removed before operating the machine. When these packaging bolts (I think there are four total, some up to 6 inches long penetrate the rear of the machine) are removed, they allow the suspesion to absorb the vibration.
Posted on May 25, 2009
  • 5 Answers
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Posted on Aug 02, 2009
SOURCE: FWT449GFS2 making loud banging noises during final
lxr6232eqo making loud banging noises during final spin cycle
Posted on Aug 31, 2009
Fwfb9100eso
Frigidare fwfb9100eso will not spin , but makes a noise when in spin mode
Nov 19, 2013 | Frigidaire Washing Machines
Frigidaire Washer/Dryer Combo FEX831CS0 won't work
Hello Laura Clark - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with the pump, door lock assembly or timer. Since it is such a complex unit, I suggest contacting a professional to move forward accurately
Dec 12, 2012 | Frigidaire FEX831CS Top Load Stacked...
Frigidare front load washer has loud banging on spin cycle. After much work we reallized one shock was broken of which we repaced both now it still making the loud banging shaking motion. Also the washer...
Thanks for choosing FixYa and welcome. Since the suspension is ok and it is level, check your drive motor and spin bearing. Usually, these are the trouble parts when loud noises are associated with the spinning cycle. Your drive motor controls the spinning. Since the noise is during spinning, that is probably where your problem lies.
Apr 29, 2011 | Frigidaire GLTF1670A Front Load Washer
Final spinning cycle makes very loud noise.
sounds like you have the dreaded bad tub bearings. Does it sound like an aircraft taking off? Open the door and lift the drum and see if you feel any play.
I don't know your technical ability, but you can match up bearings and a seal and repair it ( frigidare will only sell you the complete drum with bearings) but its a big job as appliance work goes. You will have to decide how to proceed from there as far as fixing it or buying a new one.
Aug 11, 2010 | Frigidaire ATF6000ES Front Load Washer
Violent spin cycle on the Frigidare front-loading washer
I assume you bought it new, so on that basis, did you remove the transit packing materials inside the machine ?
Front loading washing machine normal design is for the drum assembly to be supported by two or more springs at the top, and two dampers at the bottom. This allows the drum to move in a controlled fashion and also minimises vibration, particularly during spinning.
When the machines are shipped from the factory, transit packaging is put inside the machine to ensure that any shocks to the machine during transit dont damage the springs or dampers. This must be removed before use otherwise you get pretty much the symptoms you describe.
The manual that cam with it will show you how to remove the transit packaging. In such a short time I suspect you wont have suffered any damage, but take the transit packaging out as soon as possible.
Nov 04, 2009 | Frigidaire ATF6000ES Front Load Washer
FWT449GFS2 making loud banging noises during final spin cycle
Aug 31, 2009 | Frigidaire Washing Machines
FRIGIDARE FRONT LOAD WASHER,2+YRS OLD ON FINAL HIGH SPEED SPIN MACHINE MAKES LOUD VIBRATION NOISE AND FIND NEED TO SHUT DOWN DUE TO FRANTIC VIBRATION AND NOISE.
It is possible the bearings on the motor that spins the canister could be going bad especially at the high speed. This could also be from clothes getting unbalanced in the final spin cycle. Hope this helps. This could still possibly under warranty!
Aug 22, 2009 | Washing Machines
Frigidare Front Loading Washer model# FWT645RHSO
check out the drain pump if drain pump is blocked up water will not get away quick enough and stop machine from spinning
if that is clear
turn bowl by hand and if you get a runble noise then the main bearings are gone
that will need dismantle and replacement or new machine
Mar 15, 2008 | Frigidaire ATF6000ES Front Load Washer
check to make sure you have removed all the shipping braces
Mar 02, 2008 | Washing Machines
Frigidaire FWS833A Top Load Washer Logo
50 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
