Question about GE JVM1440 Microwave Oven
How do I change a fuse in a GE JVM 1440 microwave oven? I have looked at all supporting material and do not know how and do not want to mess it up without having instructions. Thanks
Remove 2 screws from front vent cover and removed vent cover
Remove one screw from top of display
Gentley push display panel up about 1/4 inch and tilt the top toward the front.
Disconnect 3 thin gauge molex connectors
Disconnect 1 heavey gauge connector
Remove screw from grounding wire at botton of display curcuit board
Remove display panel completely
Remove grill from above display area
To the left is a 2 x2 inch square board
Coil, capacitor and fuse block
Remove fuse
Check fuse rating
Match fuse rating and replace
Posted on Mar 12, 2009
  • GE Master
  • 9,098 Answers
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
The prime suspects would be the bottom TCO, the 20A ceramic fuse located on the noise filter board near where the cord goes into the unit, the oven cavity TCO, or the magnetron TCO.
All these will be shown in the mini manual.
To access and test (and if necessary replace) the oven cavity TCO, you will need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on Jan 29, 2009
I have a GE spacemaker microwave oven model JVM 1440. A bulb blew and when I went to change both over the stove bulbs stay on all the time. What is the problem and what should I do.
there is some kind of circuit board damage. carefully check for burned foil paths on board; around where the relays are. if so, you may be able to "bridge" the broken foil paths with solder. just unscrew the bulbs in the meantime.
Aug 03, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Oven is not heating at all. I also smelled burnt plastic. Model is GE Spacemaker XL JVM 1440.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Aug 02, 2010 | GE JVM1440 Microwave Oven
Our GE JVM 1653 spacemaker microwave looks like it is working but the food doesn't heat up. It lights up and goes around but no heat? Whats up?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ysss
Jul 06, 2010 | GE JVM1653 Microwave Oven
Need manual
Hi
Thanks for using FixYa. Please see the link to download the manual for GE Space Maker JVM 1640SJ Microwave Oven---
GE JVM 1640SJ Microwave Oven Manual
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Can i vent my jvm-1440 microwave/fan ?
yes, you can recirculate it out the front which i suppose u do currrently... you may also vent it out the top, or the rear. to do this u must drop the unit down,and rotate the fan motor to point the appropriate direction, and also install or have a exterior venting piping existing currently..
Apr 16, 2010 | GE JVM1440 Microwave Oven
My GE spacemaker JVM 1440 Watt microwave has F4 error code.
Have GE JVM1440BH light and fan that are operated by the touch pad do not work. Both stop working at the same time. Ideas????
Mar 21, 2009 | GE Microwave Ovens
Microwave part of my GE Sensor Convection Microwave doesn't work
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Dec 22, 2008 | GE Advantium 120 Convection/Microwave Oven
GE JVM1440 Microwave Oven Logo
793 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
