Question about Samsung DLP HL-P5663W 56" TV
Subtitles will not be removed cation option will not light up
Samsung tv HLP4663WX/XAA
subtitles cannot be removed ... caption option wil;l not light up as a useable option
  • longtin59 Jan 28, 2009
    It happens on all channels and has nothing to do with any DVD or movie channel
    I don't have a clue how to reset a TV????
  • 362 Answers
Hi longtin59,
Lets see if we can turn the CC of through the menu: Let me know know which option will not highlight.
  1. Press MENU button
  2. Select SETUP, press ENTER button on remote.
  3. Select CAPTION
  4. Select OFF, Press ENTER button on remote
  5. Select MODE, Press Enter
  6. Select OFF Press Enter.
Here is a link to the manual if you don't have it. http://www.retrevo.com/d/ds/progress?doc=4b841e68bfe7e0f30be91cb9075e7bfa
Let me know if this is HELPFUL.
Lone99star
Posted on Jan 28, 2009
  • 11,896 Answers
IF BY CHANCE YOU DON'T HAVE A USER MANUAL, YOU CAN DOWNLOAD IT HERE (copy and paste in your browser)
http://www.usersmanualguide.com/samsung/tv__projection/hl-p5663w
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Almost always, your described problem could be addressed by performing an initial setup/configuration. This is better done after the unit has been left unplug for an extended period of time; the purpose of which is to revert it to factory defaults.
Of course the original remote control would be needed. The same would also hold true if you are using a receiver box with composite/component outputs.
Good luck and thank you for using FixYa.
  • 3,037 Answers
Have you tried resetting the tv at all? The easiest way is to unplug it overnight and see if it ceases to be a problem. Is anything else also not working, as other problems would help narrow down a faulty component.
bestdarngood
  • Benjamin Patri
    Benjamin Patri Jan 28, 2009
    Resetting a tv is easy, A hard reset is just removing all power from the device for a set amount of time, with a tv, usually 8 hours or overnight ensures a reset which is what I recommend first trying.
    Brigadier General:
  • 8,619 Answers
Hi
In that case that DVD is protected and the options cannot be changed.Try some other DVD and see if the subtitles can be removed.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Jan 28, 2009
    To reset the TV to factory default you simply need to follow these steps :
    Press the MENU button to display the “Mode” menu.
    Press the up or down button to select “Reset”, then press the ENTER button.
    The previously adjusted picture settings will be reset to the factory defaults.
    Kindly refer to this user manual for your TV for future references.
    Thanks
    Rylee
How do I get closed captioning?
According to the Samsung support website there is an option in the menu which is called "caption" which can be selected off or on.
This is a link to a copy of the manual.
Samsung UN65F6300AF manual
In the manual it says to select the onscreen menu and then ...
Subtitles
Screen Menu > Broadcasting > Caption Try Now
View subtitles along with subtitle-enabled digital and analog broadcasts.
Show Subtitles
Screen Menu > Broadcasting > Caption > Caption Try Now
Show subtitles. Subtitles will be displayed when you choose a broadcast that supports subtitles.
"" DVD Subtitles are only available when connected to an external input connector.
Mar 13, 2015 | Samsung 6350 Series UN65F6350 65" LED...
Samsung TV: HLP4663WX/XAA Lamp Code: BP96-00826A(P) No picture . . . no light from lamp On/Off Switch: ''lamp'' and ''Stand By Temp'' Should I replace the lamp?
hello am rico, no. first check your power supply, because lamp has nothing to do with power. more like it you goona have power supply problem. if you need more help, feel free to call at 602-810-7149 anytime.
Jan 07, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
HOW DO I REMOVE THE SUBTITLES FROM MY SONY BRAVIA
The Subtitle option is available only with the connected devices like DVD Player, Blu-ray Disc Player etc. The option avaialble in the TV is known as Closed Caption. The Closed caption option can be turned off by selecting the options below:
Press Menu button on the TV Remote. Select, Setup settings. Then select Caption Vision option to OFF. This option is for turning off the Closed Caption option in the TV to OFF. For disabling the Subtitle option in the connected devices like DVD Player and Blu-ray Disc Player, press the SUBTITLE button on the supplied Remote continuously to select OFF.
In few of the TV broadcasting channels the Subtitles cannot be turned OFF as this is being broadcasted with the channels.
Good Luck! KenSolutions
Oct 28, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
How to remove samsung subtitles
Check ur cable remote or ur samsung remote.U see a button CC either remotes push it make sure CC1,2,3 to off.U should have no more captioning.
May 11, 2010 | Samsung SPN4235 42 in. Plasma HDTV
Add subtitles samsung
Must tries mutilple channels,pushes the remote button CC 1,2,3 on every channels.Sometime channels don't have captioning.
Feb 24, 2010 | Samsung LE37B550A5 37 in. HD-Ready LCD TV
Cationing ws working, but isn't now. LG TV.
if you are watching satellite or cable, make sure that captioning is on on that device also
Mar 06, 2009 | LG 26LG30 26 in. LCD TV
Closed caption
You have to activate the closed caption option on your charter cable box. Power off your cable box and immediately push the menu button. A menu should appear where you can toggle captioning on/off. Good luck!
Oct 27, 2008 | Toshiba 42LX177 42 in. LCD HDTV
Black screen covering most of tv screen at a few channels; a code appears at upper left corner. The black screen disapears for a few seconds if I turn the volume up or down at the remote control but it...
Turn off your closed caption and or text mode using the closed cation button on the Magnavox remote or through the TV's menu there wil be an option to do so.
May 24, 2008 | Philips Magnavox MS2530C 25" TV
Samsung DLP HL-P5663W 56" TV Logo
47 people viewed this question
Jerry Greenberg
Jerry Greenberg
