Question about Rinnai Digital Remote Water Heater Control Mcc-45-4us
Need to wire a zone control for a closed system with a circulator
I INSTALLED A RINNAI R75LS TANKLESS WATER HEATER. I NEED TO ADD ZONE CONTROL TO GET THE CIRCULATOR TO RUN SO THE WATER FLOW TRIGGERS THE RINNAI HEATER TO START. I HAVE A SR201 ZONE CONTROL, BUT THE WIRING DIAGRAM SHOWS CONNECTING TO A BOILER CONTROL.
  • vegster May 11, 2010
    couple of questions, i take it you are trying to circulate the water so that you dont need to wait a while when you turn on a hot tap to get hot water? or do you have it as some kinda heating loop? are you using a circulation pump if so what one.
    Scholar:
  • 73 Answers
Tankless water heaters for domestic use fire whenever there is water flow. As long as the pump flow rate exceeds the minimum flow rate of the appliance, the heaters hould fire (the return temperature needs to be less than the set temperature as well). Boiler systems will typically require a thermostatic signal (call for heat) and water flow before they will fire. Tankless heaters are designed for residential use and only require pump flow to fire.
Posted on Aug 18, 2009
  • 332 Answers
Thats because the rinnai does not have a set up for a circulating pump it would make the unit run all the time,, they are not designed to work that way,, you will have to just wait for the hot water to get to the faucet just like before,,don't let any one tell you there is a way once the water flows it turn on the tankless so it would never shut off, you could get on that goes on a timer on say the farthest fauset away from the unit and set the timer to come on like 2 min before you are ready to use the water in that bathroom in the morning or at night other then that there is nothing else you can do
Posted on Jun 29, 2009
  • gary miller
    gary miller Jun 30, 2009
    the easiest way to do this is to add a circualtar pump opn the hot side supply line in a bathroom sink farthest away from the water heater, have it on a timer that just plugs into the wall, this way you can set it for about 5 min, beofre you are going to use the hot water in the morning or at nightm but to out a zone valve in would be waisting alot of gas on the water heater beings it will still take the same amount of time for the water to get hot on the faucets farthest away from the unit,, by doing it the way I described it will pull the hot water thru the lines where a zone would notbe efficiant to your system,
I am trying to increase the temperature on the controller and it wont change. I have installed a new one and it still will not increase
[PDF]Operation / Installation Manual - Rinnai
https://www.rinnai.us/.../V_Series_Indoor_25xx_U...
Rinnai America Corp.temperature (shown on the digital remote control) the gas burner will ... Without the connection of a remote controller(s), the Rinnai Water Heater is preset to.
PDF]Tankless Water Heater Service Manual - Rinnai
https://www.rinnai.us/.../100000098_Rev_B.pdf
Rinnai America Corp.Indicates condensing water heater models. ... Rinnai Water Heater Service Manual. 2 ..... Digital manometer or U tube type manometer with 14 inch water column (W.C.) scale, a hose and two .... will flash on the display of the remote controller.
Nov 23, 2015 | Rinnai Digital Remote Water Heater Control...
Controller not working
The rinnai is a computer that heats water. It is not ordinary water heater most people are familiar with, and repairs are not do-it-yourself, requiring a trained technician qualified in that brand who can diagnose both computer and water heater problems and plumbing problems.
Call rinnai for recommended local technician. Click on support tab. Note their webpage is very short on repair details, unlike companies that sell tank-type heaters... because tankless units are not do-it-yourself.
http://www.rinnai.us/tankless-water-heater
Problem might be simple blown glass fuse on circuit board or complete failure of computer and sensors.
Here is page written for Rheem tankless, that explains general complexity of tankless computers, and showing required maintenance, such as deliming each year:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
To save problems with tankless computers plus anticipated expense of maintenance and repairs, I recommend homeowner install tank-type gas water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Also install one-time-use whole house surge protector, and install grounding rods to prevent further damage... lightning frequently likes the same places over and again:
http://waterheatertimer.org/How-to-wire-Whole-house-surge-protector.html
Gene
h
Aug 12, 2013 | Rinnai Water Heaters
What does it take to convert a Rinnai R75LS water heater from propane to natural gas?
Contact Rinnai.
Gas control valve is different, burner is different, burner and gas valve must match, threads are regular instead of reverse, dip switches probably have to be changed since combustion of NG is not as hot. Maybe different sensors. Pressures are lower with NG.
Mar 28, 2013 | Rinnai Water Heaters
Im looking for the best option to get a Rinnai unit that would supply water at 30c or just below. i was going to buy the REU 55RT but looking at the manual i dont know how low the temp can get
Most tankless are preset to 120 degrees F.
30 degrees C is 86 degrees F.
If you want adjustable product, then tankless is not best choice.
Tankless are high tech gadgets with multiple interrelated parts controlled by sensors feeding information to control board. Everything internal and external has to be working correctly for tankless to work at all.
Most tankless brands do not suggest self-install, or self-adjustment, or any adjustment for reason given above.
You would be better off buying typical tank-type gas or electric and then thermostat adjustment is simple.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
http://waterheatertimer.org/pro-n-con.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 23, 2011 | Rinnai Digital Remote Water Heater Control...
How do I turn it on? I press the "on" button and
The manual says:
http://www.coinwash.com/temp/rinnai.pdf
"For the name of the Authorized Distributor or Installer nearest you, please contact your local HVAC dealer or gas service technician, visit the Rinnai website (www.rinnai.us), call Rinnai at1-800-621-9419 or write to Rinnai, 103 International Drive, Peachtree City, Georgia 30269"
Manual says that the remote is for setting temperature.
When you turn on hot water spigot, tankless water heater will heat the water to the set point temperature.
If water heater is not set up to use remote, then tankless unit will heat to 140 degrees F.
"With the MCC-45-4US remote control installed the water temperature is adjustable from 96
to 180°F. The water temperature cannot be set to a temperature other than 140°F
without the use of the MCC-45-4US remote control unit. If you require a temperature
other than 140°F you must install the MCC-45-4US remote control unit."
"Error messages are displayed on the remote control units, simplifying service calls."
Page 9 of manual shows hot to set temperature using remote.
Water taps must be shut off to set temperature.
Circulating pump must be turned off.
"Simply press the H or C button until desired temperature is displayed"
"green in-use indicator will display"
If your unit is not working, the manual says to contact local plumber.
Fixya has specialists who will talk to you by phone about your problem for a fee.
Dec 18, 2010 | Rinnai Digital Remote Water Heater Control...
I have a Rinnai R75LS and have it hooked up to clean with vinegar. However the R75LS will not allow the vinegar to flow through. I have watched videos etc. and seem to be unable to get the vinegar to...
I'm assuming you heater will let water flow through and it's not completely blocked with scale. There is a motorised valve that needs to be open. Start with the heater connected normally and run a hot tap. While it is firing turn off the power, this will leave the valve in it's open state.Now connect up your heater to the vinegar supply; do not turn the power back on.
Sep 16, 2010 | Rinnai Webstone The isolator EXP tankless...
Which circulating pumps works on tankless water heaters
Laing UCT-909-TANKLESS UltraCirc Tankless Water Recirculating Pump
This is designed to maintain the proper flow to fire the heater. Please be sure the pressure in the house is at least 5 psi over the minimum required for your unit.
Apr 03, 2010 | Rheem Tankless Hot Water Heater...
I want to upgade from my old water tank to a tankless water system. I have underfloor heating and it has 4 zones but i run it as one zone and it is controlled from a therm ostat that controlls a pump.I...
what you have is called a hydronic heating system.
this heating system is completely isolated from your water heater I believe this as most hydronic systems I have installed circulate water through the furnace to heat the house. If this is true you need only to connect your old water heater cold water supply side to the tankless and, old hot water side to the house system: the showers/tubs/sinks etc. in your home.
my appologies if I have missunderstood your inquiry.
Jan 26, 2010 | Rinnai Digital Remote Water Heater Control...
Runs out of hot water
I wonder if you have this problem below caused by a drop in water pressure from someone flushing a toilet or a washing machine. I would call the company to remedy this issue.
17. What is a cold water sandwich effect? The term “cold water sandwich effect” is a term that is used to describe the introduction of cold water into the hot water supply line during frequent on/off operation of an instantaneous water heater. The cold water sandwich effect, when present, appears as a momentary drop in hot water temperature as it is discharged from a hot water supply outlet (i.e. shower, tub, or faucet). This phenomenon is present in the operation of all instantaneous, tankless style, water heaters, but is minimized with the high tech design of Rinnai water heaters.
The technology built into the Rinnai water heaters is designed to minimize the cold water sandwich effect. Rinnai water heaters are microprocessor controlled and when water flow through them ceases, they remain in a “ready to fire state” for approximately 1 minute. If water flow through a Rinnai water heater begins within the first minute following water flow stoppage, the water heater will fire back up within 1 to 2 seconds. This minimizes the cold water sandwich effect that would otherwise be experienced with a low tech tankless water heater. It should be noted that the cold water sandwich effect cannot be removed completely from tankless style water heaters. The safety standards developed to insure the safe operation of water heaters require a delay in the ignition sequence of all gas water heaters.
While the cold water sandwich effect cannot be completely eliminated from standard plumbing systems, it can be eliminated from plumbing systems that have a supply and return hot water circulating system. Rinnai has developed 2 methods to eliminate the cold water sandwich effect in residential hot water circulating systems.
The first (and preferred) method to remove the cold water sandwich from circulating systems utilizes a small electric tank water heater (powered up) that is used with a dual purpose. The small water heater acts as a mixing tank to eliminate the cold water sandwich effect from the Rinnai water heater and it uses its electric heating element to offset the heat losses from the hot water circulating system.
The second method to remove the cold water sandwich from circulating systems utilizes a small 2 to 6 gallon storage tank installed on the hot water outlet of the Rinnai water heater. This tank acts as a mixing tank to blend the cold water sandwich with hot water and eliminating its effect at fixtures.
Mar 11, 2009 | Rinnai Water Heaters
Rheem RTG 53 PVN with fault codes C4 or C7
I had the same problem with my tankless waterheater (flashing c4 76 alternately). I called Rheem
tech support and they had me 1 power down the remotepanel 2 unplug the unit from the wall 3 remove the cover 4 remove the wires for the remote panel from the circuit board and pull the twisted pair that goes to the remote out from the bottom of the unit. 5 reinstall the cover 6 plug the unit back
into the wall and turn on the hot water see if it works. It did in my case and they are sending me a new remote panel. I hope it helps.........
Nov 21, 2008 | Rheem RTG-53PVN Indoor Natural Gas...
Rinnai Digital Remote Water Heater Control Mcc-45-4us Logo
355 people viewed this question
Top Rinnai Water Heaters Experts
gizmonix
Level 1 Expert
jdthefixer
Are you a Rinnai Water Heater Expert? Answer questions, earn points and help others
