Question about IBM ThinkPad T40 2373 Notebook
Audible Error when starting up
My IBM ThinkPad R40 was working yesterday, but wasn't charging well.  Now when I try to start it up or wake it from sleep I get a serious of sounds that sound like a siren naa   noo  naa  nooo  naaa.  Any help would be appreciated.
  • 1 more comment
  • rwolbach Feb 15, 2009
    I have a similar problem with the t40. While I was installing a wireless router it started making a series of 4 beeps and stopped working. Now when I try to start it, it keeps making a series od 4 beeps and it wont boot up.
  • DEKR
    DEKR May 11, 2010
    still need help
  • DEKR
    DEKR May 11, 2010
    have you changed anything to your system
    and do you get the sounds with AC power and battery
    check settings in control panel power options
My name is Luis and my Ibm thinkpad r40 keeps freezing and my screen goes black.
Hi, could be simply your computer is going into sleep mode and not waking back up. try changing your screen saver option to not hibernate or sleep.
Aug 18, 2009 | IBM ThinkPad T40 2373 Notebook
Start up
You can get one at the place where you bough it from. They'll give it to you.
So...
Good Luck!!
Aug 06, 2009 | IBM ThinkPad R40 2722 Notebook
Error no 0176
Change the bios battery.Remove the notebook battery and then you should see the bios battery.Maybe you should have to disassembly the complete pc because it is a little dificult without disassembly.
Apr 13, 2009 | IBM ThinkPad R40 2722 Notebook
Problem with ibm thinkpad r40
The IBM beep code error 1 long 2 short beeps means there is a video card fault. Reseat your RAM because the video card uses some of the RAM. If it doesn't work then the video chip on the motherboard is faulty, the only way to fix is to replace the motherboard - this may not be a cost effective solution.
Connecting an external monitor to the laptop won't work because the video card also sends data to the video port.
Apr 06, 2009 | IBM ThinkPad R40 2722 Notebook
Ibm thinkpad r40 windows xp-pro after formatting and re-installing the system, all updates and SPs downloaded and installed, the wireless "disappeared"! the radio led wouldn't lit, in the connection list...
if drivers installed device is looking for wifi manager which is the software package for wifi.
you can goto control panel open administrative tools select sevices and scroll to wireless zero config and press start.
this will then use windows settings.done
Jan 24, 2009 | IBM ThinkPad R40 Notebook
Ibm thinkpad r40
This could be a problem with the battery, try removing the battery and starting on the adapter only. If this doesn't work, then I'm afraid it is going to be a motherboard problem, most likely with the power management system, this is the most common area with this type of problem. You can take it in for diagnostics, but I'm afraid you're going to end up having to replace the motherboard in order to fix the problem.
Aug 25, 2008 | IBM ThinkPad R40 2722 Notebook
Cmos password for ibm r40
You will have to remember it. IBM puts a security chip on the motherboard, the bios password is burned into this, and there is no way around it. There are a few places that will replace the chip, but they are very expensive. The only other way is to replace the motherboard. I've found that replacing the motherboard is cheaper than having the chip replaced, so, if possible, remember the password.
Jun 30, 2008 | IBM ThinkPad R40 2722 Notebook
Ibm thinkpad r40
Completely dead could be the power supply, if not, then the board.
Jun 06, 2008 | IBM ThinkPad R40 2722 Notebook
IBM ThinkPad T40 2373 Notebook Logo
89 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
