I have a miele novotronic w718 I used the local switch to open the door but as I close again then switch on no lights coming .please can I get the switch diagram that I. can trace the fault rgds. wamae
2 Suggested Answers
reverendrave
  • 24 Answers
SOURCE: replace door seal miele novotonic w 502
Hello mc2739,
It's been awhile for me since I have done this so I searched on the internet and found the following. The instructions are pretty detailed. You may want to contact Miele if any problems
1. Open the machine door.
2. Turn the main power off and unplug the machine from the wall.
3. Completely remove the powder dispenser drawer (it will come out so far (and stop), then there is a small button at the rear of the dispenser which you need to depress to remove it fully, you'll see this button once you've withdrawn the drawer to its stop position.
5. Undo and remove the 3 x hexagonal head bolts surrounding the door seal (they are at approximately the 2, 6 and 10 o'clock positions). Note these bolts actually secure the front panel to the machine chassis, they do not retain the door seal. Don't worry the front will not drop off.
6. Now look at the aperture of the powder dispenser drawer (you have of course removed the actual drawer earlier). Locate the lower left hand corner of the aperture, and you'll see a recessed philips head screw in a hole. Undo and remove that screw.
7. Now, you'll need to get on your hands and knees. You DO NOT need to tilt, or lift up the washing machine to do the next bit. Locate the underside of the front panel right at the bottom. You'll notice that it sticks out about half an inch or so and is proud of what I would call the kick plate which extends right down to the floor. You need to look on the underside of the front panel, about an inch or so in from the left hand edge. There you will see a spring loaded clip which when closed is located within a slot on the underside of the front panel. Using a flat bladed screwdriver, you need to carefully lever the spring clip open whilst gently pulling the whole front panel (from the left side) ajar. It will just suddenly pop out once you've done it.
8. Open the pump access door lower left hand side of the front panel) and unclip the drain tube from its plastic retaining clip.
9. Now carefully swing open the whole front panel, it opens like a door (hinged on the right hand side). It might be a little stiff as there are a whost of leads attached to it, but it is designed to open fully (with the leads attached) to about 90 degrees.
10. Next, unseat the rubber door seal from around the door opening area (on the chassis, not the front panel, obvioulsy), so that the seal the flops away from the chassis and lies just inside the machine.
11. You will notice that there is a thin steel band holding the door seal in place around the drum. On the right hand side (at about the 3 o'clock position), you'ss see a tensioning screw for the band. With a flat bladed screwdriver undo this completely and remove the screw (it is accessible from above with a long screwdriver). Be aware that there is 1 x washer and 1 x 'nut' type fitting that will fall out when you remove the screw. Locate these and retain them for later.
12. Now extend the steel band to its maximum opening (by moving the 2 x lugs apart where the now removed screw was).
13. You can now remove the steel band. Then pull it out through the hole/door aperture in the chassis.
14. Locate the small rubber tag at about the 12 o'clock position where the seal is attached to the drum and tug it. The seal will then come away from the drum. Remove the old seal completely.
15. Using your new seal, place this correctly around the drum (there is a lip on the seal and this has to go over the lip on the drum. Remember, the seal goes on the OUTSIDE of the drum. Ensure the 'tag' is at the 12 o'clock position.
16. Reassembly is then the reverse of removal.
17. Make sure that you do up the retaining steel band sufficiently and that you correctly locate the sela on the chassis front panel (there is a groove in the seal which will locate the seal in the aperture).
18. Finally, once you're done, put the machine through a few rinse cycles (where the water level is high) and look for leaks. If you have a leak, it is likely that your door seal has a rip/tear, or that it has not been correctly located around the drum - in which case you'll need to investigate.
Posted on Sep 17, 2009
Miele washing machine novotronic w505. I did a laundry, just back and found the machine without power / no electricity. It seems and laundry made well. I opened the door handle&clean the filter.
Usuali, there is no fuse inside miele washing machine. One possibility is, that switch for closed door is not working properly. Try to close door with some more force. If that does not help, switch is gone, or something inside on machines "brain"
Dec 03, 2017 | Miele Washing Machines
Miele 500 washing machine inlet light comes on and machine wont pump water out or spin
try leaning against door when pressing start . if it runs get the switch replaced
Jan 24, 2016 | Miele Novotronic Premier 500 Front Load...
I have a miele novotronic dryer t430 have power when door closed wont start I get one click and door opens on its own
-Possibly door switch is faulty or screw that hole the switch is too lose. Check & tight it or replace.
-Att! Make sure disconnect power before work on!!!
Good Luck
mai
Sep 19, 2014 | Dryers
Miele Novotronic W 832 washer won't turn on. It suddenly turned off after trying to open the door and now it won't turn back on. I tried switchinging powersources, didn't work.
Make sure the door is properly closed!!! The door opener is electric, and the electrics are turned off unless the door is properly closed, hence with the door closed but not fully "home" you will neither be able to re-open the door nor wash what is in the machine. Just give the door a firm push closed and it should spring to life.
Apr 27, 2011 | Miele Novotronic Premier 500 Front Load...
Miele novotronic wt 945 door release button not responding wash functions not responding when turned on and off only drier light is on no actual response from drier section cannot open the machine Is this...
Open the door manually.
Open the drain flap on front left bottom
The door release can be seen hanging, pull the cord, the door will open.
Close and open the door 2 or 3 times and your machine will work ok.
S. Datta
Bickley
Mar 06, 2011 | Miele WT945 Front Load Washer / Dryer
Miele novotronic wt 945 door release button not responding wash functions not responding when turned on and off only drier light is on no actual response from drier section cannot open the machine Is...
Sorry but I would strongly suggest that sending any part to Miele and paying Miele for fixing the fault would cost considerably more that a 'local' service engineer ;-0(
Also Miele would not necessarily accept someone sending parts or all of a washer to it.
'Local' Service engineers are available for exactly the purpose of avoiding customers having to send suspected faulty equipment back to the factory. Also factories are not normally set up for carrying out retail repairs.
So, sorry again. Call your local repair man who should have the equipment to diagnose and cure the fault ;-0)
Good luck,
John C
Mar 06, 2011 | Washing Machines
I need from manual guide on English for dryer Miele t565c
I have a t565c novotronic dryer,the light in the drum comes on but when i close the door and turn it on it want start .?
Dec 28, 2010 | Miele Novotronic T220 Electric Dryer
Door stuck closed on a Miele Novotronic W+862!
I'm not sure if you have done this, but open the pump door (the little panel at the bottom left - it opens from the top hinged at the bottom) and slowly drain the machine by unscrewing the large knob inside - do it gently and in small stages or you'll flood the room.
Once you've done that you should be able to open the door by pulling on the orange tab that is also behind the pump door.
Jul 31, 2009 | Washing Machines
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
