Question about Rockstar Games Grand Theft Auto: San Andreas for Windows
Feature transfer error
Pl help me
    New Friend:
  • 17 Answers
Whats the problem
Posted on Jan 23, 2013
Cannot install wireless-n usb 2.0 adapter on xp 32bit
which n adaptor is this and whats ur operating system!
Dec 19, 2017 | Computers & Internet
I'm trying to install a game but it stops and gives me a feature transfer error, help me please.
Feature transfer error is usally self explanatory. This most often means there is a conflict with the game and the operating system you are loading it on. As well can be the hardware does not meet the minimum specs or the OS just compatible. Make sure the disk is spotless and if so could be a bad burn of the game. Try running the disk on another pc to be sure its good.
Aug 10, 2011 | Toshiba Satellite A205-S4617 Notebook
How do i transfer to pc
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 05, 2010 | Sony DCR-DVD610 DVD Camcorder
Docucolor 242 code 042-326. What do we need to
arrwup.gifBSD On BSD 9.20 - Transfer Belt Position Monitoring arrwup.gifDescription Belt Home Position too long
arrwup.gifInitial Action NOTE:
If this fault is declared 3 times in succession, the print mode will be disabled. In order to clear this condition, reset NVM location 741-105 to 0.
  • Check the opening/closing of the Front Cover.
  • Turn the power OFF then ON.
arrwup.gifProcedure Check that the Transfer Belt is in the center (where the IBT Belt Edge and the IBT Belt Frame are approx. the same distance from the front and rear). Center if required (see REP 9.3).
Perform ADJ 9.13 Belt Edge Learn Cycle.
The Belt Edge Learn Cycle ends abnormally. Yes No Unanswered
End
Check the reflective mark at the rear of the Transfer belt.
The reflective mark positioned correctly and reflects properly. Yes No Unanswered
Clean the reflective mark and reposition it properly, if the problem continues, replace the IBT belt ( PL 7.3).
Enter dC330 [042-200 Transfer Belt Home Sensor]. Rotate the belt manually for 1 turn.
The display changes. Yes No Unanswered
Go to OF 99-1 and troubleshoot the Transfer Belt Home Sensor ( PL 7.5).
Check the operation of the actuator of the Transfer Belt Edge Sensor Assembly.
The actuator moves smoothly. Yes No Unanswered
Replace the Transfer Belt Edge Sensor Assembly ( PL 7.4).
Select [042-016 IBT Steering Motor (CW) High Current] and [042-017 Steering Motor (CCW) High Current].
The IBT Steering Motor operate. Yes No Unanswered
Go to OF 99-9 and troubleshoot the IBT Steering Motor ( PL 7.4).
Check the installation position of the IBT Belt Module (the four legs of the IBT Belt Module are placed on the board springs of the Transfer Drawer and the fixing screws (M4: x2) of the IBT Drawer are tightened).
The IBT Belt Module is installed in the proper position. Yes No Unanswered
Adjust the installation position of the IBT Belt Module.
Set dC131 [741-105 Angle Data Initial Value (A0)] to 0.Install the IBT Belt in the center (where the IBT Belt Edge and the IBT Belt Frame are approx. the same distance from the front and rear). Perform ADJ 9.13 Belt Edge Learn cycle.
End
Replace the Transfer Belt Home Sensor ( PL 7.5). If the problem continues, replace the Transfer Belt Edge Sensor ( PL 7.4). If the problem persists, replace the Transfer Belt Edge Sensor ( PL 7.4). If the problem is persistent, replace the IBT Belt Module ( PL 7.1).
Sep 08, 2009 | Xerox Office Equipment & Supplies
Not supporting to yahoo mobile & not able to send photo
visit http://www.getjar.com and download the supported version for your handset.
May 14, 2009 | Motorola Mobility L6 Cellular Phone
Conference Calls/Transfer
Conference [Feature] [3]
  • Establish a conference call between yourself and two other parties.
1. Make or answer the first call.
2. Put the first call on hold.
3. Make or answer the second call.
4. After the second call is connected, press [Feature] [3].
5. Press the line or intercom button of the first held call.
6. Press [Rls] to end the conference call
  • To remove yourself from a conference permanently (unsupervised conference):
    • Press [Feature] [7] [0]. The other two callers remain connected. (Some external lines may not support this feature.)
May 21, 2008 | NorStar Meridian M7310 Phone
Feature Transfer Error
Go into safe mode, edit the registry and remove all Panda entries. Also go into Configuration and uncheck Panda to startup if checked.
Try running the software while in safe mode and it gives a message that another software installation is detected and will be removed on startup, you'll know you need to find and remove files. It did not remove those mentioned above.
Feb 18, 2008 | Toshiba Satellite A205-S4617 Notebook
Open Questions:
See all Rockstar Games Grand Theft Auto: San Andreas for Questions
Rockstar Games Grand Theft Auto: San Andreas for Windows Logo
23 people viewed this question
Top Rockstar Games Video Game Consoles & Games Experts
Edward Talavera
Edward Talavera
James Wishart
Sreehari Nair
Sreehari Nair
Level 1 Expert
Are you a Rockstar Games Video Game Console and Game Expert? Answer questions, earn points and help others
