Question about Philips HTS3410D/37 700W DVD Home Theater System System
Phillips hts3410d no sound VERY dim led
Home theater worked fine and one day and the next there was no sound and the led was very very dim. it flickered back on after messing around w/it and the sound worked again. tried to use again a few days later and no led again and no sound.. wont go back on like last time. is the theater system shot?
  • 6,784 Answers
Have you had any thunderstorms recently in your area? if so, this could be a pulse sent threw your system form an electrical storm. this happens often during dangerous thunderstorm activity. Also, your electrical wiring in your home can produce this as well due to a faulty circuit breaker box or lose ceiling fan hook ups. the best scenario could be a defective product. this way, you can get a full refund or a replacement set up.
Posted on Jan 28, 2009
Phillips HTS3410D audio
You seem pretty anxious to perform surgery. Have you done traige yet?
It could be something as simple as a malfunction on a heaphone jack connection.
DO headphones work? Try using FM as the most basic source.
How do we know the internal audio is present and sufficiently loud to drive the speakers? If you have a tape deck or a TV with audio in connections, run an RCA jack to it and see if there's something there to listen to. No signal = no speakie = something other than the power amps failing = not those caps you read about.
BTW: don't use Maximum volume while troubleshooting. If you finally do touch the one thing causing the problem you'll probably launch the speaker cones right out of their enclosures and have to start all over again with blown speakers.
Mar 26, 2010 | Philips HTS3400/37B System
I need the code 4 a phillips HTS3410D dvd home
I don't think the codes are given by model number but you can access one for all's website directly and obtain the code list for your urc device, the link is: http://www.oneforall.com/support/manual , you will need the remote control model number.
Feb 19, 2010 | Televison & Video
I have a HTS3410D Home Theater system. I cannot
a blinking or pulsing power light usualy means a problem with the power supply. Check for burned resistors or swallen capacitors on the power board it will be the one with the one with the main power running to it.
Nov 17, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
Dvd player won't stay on
your unit sir or maam, it has a deffective parts you need to replace the parts the two channel of the power output ,because this parts is shorted,you need a good technician to fix it. and buy the parts to replace it
kira_ryuk99@yahoo.com
Jan 11, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
Philips HTS3410D home theatre system. DVD is stuck inside - won't play, won't open. any ideas?
Power off the system
Unplug the power cord
Wait 5 minutes
Plug back the power cord
Power up the system
Press the open/close button
Load a DVD and play
If the tray still will not open, the cover will have to be removed and manually operated. You may have to have a technician look at the unit.
Please rate this solution - Thanks
Dec 27, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
STANDBY LIGHT KEEPS BLINKING
Unplug the power cord, wait for 5 minutes, plug the power cord back in and try to operate the unit.
If this does not work, you will have to get a technician to look at it for you.
Please rate this solution - THANKS
Dec 26, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
Unit is behaving oddly
there is probly a short in the wiring some were
Jun 12, 2007 | Philips HTS3410D/37 700W DVD Home Theater...
213 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
