Proscan tv surround sound hook up
I just got a proscan lcd tv and i also got a surround sound/dvd combo. (the durabrand dvd home theater system). okay here is the problem. i tryed to hook the surround sound up to the tv so i could get sound from my regular cable channels on the surround sound speakers but its turning into a headache. But, the surround sound does work when play a DVD movie and the picture shows up fine on the tv. just want to know what may be wrong
thanks
2 Suggested Answers
  • 4 Answers
SOURCE: proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Posted on Jan 28, 2009
IWhat's your problem? I have a Hisense LTDN42V68US LCD TV and I am trying to hook it up to a Phillips HDMI DVD Home theater surround system HT53544 my problem is I am not getting a sound I only get so
Good day!!!
Your problem is on your digital cable signal or connection..
Please check all the wirings and connection from the to cable box..
its better if you re insert all connectors and restart all TV,cable box....
Hope it helps...
Dec 06, 2011 | Televison & Video
I purchased aRCA 250W DVD Home Theater System with
do you have a set of cables coming from the tv AV out to your home theater system? if not you need to you can use coax out or anolog out either one
Dec 03, 2009 | Televison & Video
Can a durabrand dvd home theater system,model #sts96 be used on tv for surround system
I have a sts92 system and run the tv sound through it for surround sound. My Tv has an AV out option, so I ran component cable from the AV out on the TV to the AV in on the sts92. When watching TV, turn on the theater system and set the function to AV in.
Feb 24, 2009 | Durabrand STS92 System
Hook up to tv
hello there. name is ryan lets see if this helps.
typically in a combination unit there is no rca audio ouputs on the tv. reason being is it is a combo unit not meant to be a item within a home theater system. it has the whole home theater built in it. ;) however if there is any audio output jacks on the tv you should be able to wire the surround sound unit up via rca cable output from tv to input on reciever for surround sound
Feb 13, 2009 | GPX DV7500 System
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Need home theater hooked to TV with built in DVD
This is the easiest way 2 explain it. Hook up on the home theater should be labeled in and out. same as on the tv. The TV might no have that feature as the DVD is built in. You might just have an option for sound from the TV/DVD to the home theater. Again OUT from TV IN to receiver. Same with any other device set up.
Jan 27, 2009 | Durabrand 5.1 Surround Sound Computer...
Ihavea 37'' dynex lcd and want to hook up a samsung home theater
cable box needs to be dolby digital to allow surround sound to work
Dec 26, 2008 | Samsung HTZ-510 Theater System
Only works when playing a DVD.
This is an easy and quick fix.
What you will need:
RCA cables (audio)
( possibly Line out converter )
Your television is either going to need Video Out, or if you have a VCR or VCR/DVD combo connected to your television. Assuming that you have a VCR combo, the way your tv should be set up is on the back of the vcr combo, your cable will run into the coaxial IN and then you have another cable running from Coaxial OUT to your tv. If you have it set up like this, then the DVD / VCR combo will have RCA Audio / video out ports on the back side. Run RCA cables from the DVD / VCR output to the surround sound INPUT. If you already have your inputs in use on the surround sound, Radioshack has RCA splitters for about $1.50 each, you might need to pick some of them up so you dont have to go through the trouble of reaching behind it all the time to disconnect and reconnect whatever your trying to connect. Now if you dont have the DVD / VCR combo, then your TV "MUST" have RCA Outputs. if it doesnt, then the only way that your going to have your surround sound connected to your tv is to take the TV apart and get a RCA "Line output converter" and wire it to the left / right channels of your tv. From what I've read, i think this is what your trying to do so I hope this helps
Feb 19, 2008 | Durabrand STS92 System
Proscan 32LA30Q & Surround sound
Make sure that your patch cables are cumming from the audio line OUT of the TV to the audio line IN on the surround amp. A common mistake on hook up is usually the problem.
Jan 14, 2008 | Proscan 32LA30Q Television
Televison & Video Logo
391 people viewed this question
Top Televison & Video Experts
Electro Med Services...
