Question about Zenith SY3572DT TV
Color Problem after replaced Circut Board
I just put a new circut board in my tv, and now i have a problem with the screen having a purple tint. Is this a faulty circut board, or is there some adjustments i need to check? Also i have noticed the TV will turn on by its self once a day. thanks.
  • 1 more comment
  • Joey Dowell Jul 29, 2007
    i know how to get into the service mode. can you help me with a walkthrough of the menu?
  • Joey Dowell Aug 14, 2007
    and you help me go through the service mode to correct this problem, or help me get a hold of a service manual?
  • Joey Dowell Aug 20, 2007
    if i knew how to a fix a tv do youthink i would be posting the question?
  • 398 Answers
When you replace the entire board in a Zenith TV, you must make the adjustments to align the new chassis with the old picture tube. You must adjust the CRT bias and drives as well as the horizontal and vertical parameters. On the older boards there were controls on the main and CRT boards but on the newer boards the adjustments are made with the remote control after entering the service mode. Tune in the shopping channel QVC, set the color and contrast to minimum and lower the brightness until the picture is just visible. Set the CRT bias settings for a pure black and white image, then increase the brightness and contrast to get a very bright picture and if necessary adjust the drive settings so that the bright picture is pure black and white. Return the video settings to normal and then adjust the vertical and horizontal settings so that the info boxes on QVC are centered top, left and bottom. If you are not sure that you can do that right then have a qualified tech handle it for you.
Posted on Jul 24, 2007
  • Mike Longo
    Mike Longo Aug 15, 2007
    I told you EXACTLY what to do to correct your problem and you rate it "not helpful"... Is it my fault you are trying to fix your own TV when you have no idea how to fix a TV?
What's your question?my PCB have got a problem when I look closer I see a head sink on the board they is an ic that bust so I need that number of the ic but it see like it start with T
Although it may be done, i think replacing the circut board rather than the ic would be the answer to this one. Even if you have the equiptment and the skills it takes to succesfully replace the ic, chances are ,a critical circut malfunction occured damaging you chip. The same result may happen again with the new ic.
I would consider pricing either a circut board or a new display all together.
Jun 06, 2016 | Televison & Video
Hln617w1x/xaa keep shutdown in 5 to 10 minute,picture kind of bleeding??
Its a common problem. The lamp needs to be replaced.
Call 1-800-samsung & choose the parts dept.
For the replacement lamp it cost $149.99 plus tax & shipping .
You give them the lamp code ( red sticker on the side of the tv) , they send it out 5day shipment.
Local tv repair services can install it for an installation fee. This will save money apposed to ordering through a tv repair shop who charges an order part fee plus etc...
Oct 17, 2008 | Samsung HLN617W 61" Rear Projection HDTV
I have 2 lines like a shadow on my screne in the top midle
normaly flat screens have 3 circut boards unlike the conventional TVs one of the three boards are display circut ..slowly it will give way and will need replacement, if your Tv is under warranty its nice, or else you will need to spend.
Nov 26, 2014 | Televison & Video
Circut board
For that age, you can put that kind of money into a new machine. Sounds about right though.
May 31, 2012 | Kenmore Elite HE4 Electric Dryer
Hi I have a Toshibe DLP 46HM95 that I have purchased in 2004. I am having a problem with the picture color. It has a pink/purple/green tint and seems like the connection is trying to go out. I replaced the...
This problems,u have is not the projection lamp problems.The problems,u have it known as convergence problems,it dead.The colors lines R,G,B mis alignment,picture have colors shadows,pictures look like a 3D pics.The Toshiba DLP tvs have a board call a HYPER board,that the Toshiba tvs convergence board.The (HYPER-BOARD)the tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the HYPER-BOARD known as a convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 29, 2010 | Televison & Video
LG Flatron W2234S 22 purple tint problem
your LCD monitor has bad ccfl lamps or inverter circut..
May 08, 2010 | LG 22" FLATRON LCD Monitor
Bosch SHX46A05UC/30 runs for 4 hours.
The circut board in the biege plastic case under the buttons on the right has what is called a cold solder. In other words the solder melts under operational use. Some are repairable and some are not.
1. UNPLUG DISHWASHER or turn off breaker and test for electricity.
2. Remove screws from door panel.
3. Take pic of position of wires going into plastic box.
4. Remove top section of plastic box with buttons exposing small circut board.
5. Open plastic box exposing large circut board and in the middle of it you will see a black spot where the solder has popped. Resolder and reassemble OR replace old circut board and then reassemble.
A new circut board is about $135
Usually electrical parts are not returnable
/uploads/images/bosch-shx46a05uc-30-runs-4-hours-23453222-3-1.jpg
/uploads/images/bosch-shx46a05uc-30-runs-4-hours-23453222-3-2.jpg
/uploads/images/bosch-shx46a05uc-30-runs-4-hours-23453222-3-3.jpg
Oct 23, 2009 | Bosch 24 in. SHX46A05UC Built-In...
Rear turn signal bulb on passenger side of 1997 GMC Yukon needs to be replaced, how do I do this.
Open your rear door and on the inside jam where the light is remove the two screws.There either a philips or torx head.Rotate out a little and litely pull the other side tabs out of the notches in the quarter panel side.Once you remove the light you will see a circut board with two more screws.Your bulbs are on the inside of the circut board.If your new bulb doesnot work,you may need to replace the circut board,there known to burn out.Hope this helps.John.
Mar 09, 2009 | 1997 GMC Yukon
I have a blue shadow outlining faces and pictures on my 50" is it color adjustment? how can I fix it - Please
No this is not a color adjustment sorry to say! it sounds like the circut board thet runs the color lenses inside your tv has some burnt out capciters and the circut board will need replaced! (the one thet controls the blue lens!) Please rate my response!
THANK YOIU!
Jan 14, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Blown resistor
if you mhave the circut diagram please check it .
Nov 23, 2008 | Electronics - Others
Televison & Video Logo
153 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
