A SC542 error is a fuser problem. Did you have a power problem? You can try to reset it by turning the copier "ON" and once you have the code displayed on the screen.... Press the Yellow clear botton once - then the #'s 1 - 0 - 7, one at a time then press the Red Stop botton till the display changes..... Once, it changes turn the Main Power Off, not the one on the control pannel. Then turn it back "ON" and that should take care of it for you.... If it did not, you may have some more problems that can not be reset till they are repaired.. Good Luck
Hi, i have a ricoh af 3045, i cant input a user code or set admin password because the machine...
(More)
Hi, i have a ricoh af 3045, i cant input a user code or set admin password because the machine dissplay´s this mesage, you do not have the privileges to use this function.
how much would it be to check the light path on an Infocus Lp640 projector? It lights up but there...
(More)
how much would it be to check the light path on an Infocus Lp640 projector? It lights up but there is minor discoloration on half of the projected image.
Trying to make 2 - 2 copies. Machine has message "duplex unit not set". I don't know where...
(More)
Trying to make 2 - 2 copies. Machine has message "duplex unit not set". I don't know where the duplex unit is, much less the metal tab. Please start from the beginning!
