We have a Whirlpoon Whitemagic 1-2-3 650 P washing maching. We can able to power & select the program upto to this everything is coming fine in the panel but when we give start, the Water re-use
We have tried switching off & select different program but ultimately the water re-use light is blinking & machine not working
  • Joel Jan 28, 2013
    Hai, Yesterday Technician from Whirlpool has come & changed the entire PCB which costs around half of that Washing Machine. Now it is working fine
  • Washing Mach... Master
  • 17,130 Answers
Try and clean the INLET and OUTLET filters and valves, Check the harness and the connections. If there are in order it can also be related to the control panel.
Posted on Jan 23, 2013
ngfam1
  • 639 Answers
SOURCE: Fisher Paykel Smart Drive 051
Peace Friend,
ngfam1 At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
  • 236 Answers
SOURCE: Washing machine is not completing it's wash cycle
either you have a blocked hose to the pump or the pump itself is either jammed or the impellor has come off the shaft. either way i think you will need to replace the pump. i presume you managed to get the water out? if so i would say the pump is favourite.
Posted on Mar 16, 2009
  • 215 Answers
SOURCE: water coming out of drawer & door
Hi Gary,It sounds to me that you have a blockage within the pressure systemas this is a classic sign. If you take the top off the machine you will see a round switch with a few wires going to it.This is the pressure switch. at the bottom of this switch is a thin pipe,normally black or clear. there is a small spring clip holding this pipe to the switch, If you remove this pipe and gently blow down it you will probably find it is blocked. You will then need to follow this pipe to the bottom of your machine. At the bottom of the machine where this pipe is fitted you will see there is a chamber and it is this chamber likly to be blocked.Some times you may clear this with a small piece of wire by removing the small pipe and poke wire through, but best way is to see how this chamber is removed and remove it for cleaning.Ensure machine is off at mains. this chamber fills with water and causes air pressure within the switch at the top of machine, which in turn tells programe when machine is full and also when empty. If this fails then machine will not turn off water supply as long as it is on. there fore when you reconnect parts ensure they are tight and clips back in place. Good luck and hope this works. Failing this working you may need to call an engineer to check switch and possible fault on board.
Posted on Feb 13, 2010
SOURCE: Maytag washing machine stopped working mid wash cycle
http://appliancejunk.com/forums/index.php?topic=2946.0
Go to the above link, get a suitable service manual, and follow the troubleshooting procedures
Washing Machine FAQ
Appliance Repair Guide: How To Fix Appliances - ACME HOW TO.com
DIY help site.
Posted on May 02, 2010
  • 159 Answers
SOURCE: No water flow on Fisher and Paykel smartdrive 708 washing machine
Take the lid off,just open it & pull it straight up.There should be a little red button that the lid strikes against unless its a different model,in that case it has a magnetic reed switch under the right hand side of the hob.press this red switch instead of closeing lid,see if it fill with no problem.the lid may not be making good contact with switch..if thats not it then it may be the inlet valve..then you can try the hot,if theres no problem with hot then its the cold valve.
Posted on May 30, 2010
Testimonial: "Very helpful, as I was completely ignorant about the workings of a washing machine. Replied promptly and had a good sense of humour - important in a crisis!"
Whirlpool Washing Machine Whitemagic h70 Wiring Diagram
Can't seem to find one.
Is there a model# other than whitemagic h70?
I have had luck on parts places showing schematics when you start looking for parts in the machine.
Maybe that can work for you.
Nov 25, 2015 | Whirlpool Washing Machines
Whirlpoon front load washing machine door hatch stuck
check for any obstruction which is locking the door
Apr 28, 2008 | Washing Machines
Pe ERROR WITH WHIRLPOOL MAKE WHITEMAGIC 123 650 h WASHING MACHINE, MACHINE WORKS BUT OUTER BOWL DOESNOT SPIN AND MAKING BEEP SOUND DURING PROGRAMMED
does tube move by hand? does it have the correct amount of resistance when turning, or is it hard or too easy?
Dec 09, 2014 | Whirlpool Washing Machines
My whirlpool whitemagic washing machine top panel board doesnt work or no power?
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If there is no power check the outlet and mains wire. If not the control board is a suspect., check the door switch which needs to close for the program to activate.
Feb 28, 2013 | Washing Machines
My whitemagic machine allows me to select a program and when i press the start button it shows PE error. This is happening since 2 days now.
This is a Pressure Sensor Error.
Remove the top of the washer. The pressure is usually located at the top. It will have a plastic tube about 5/16 in size. Remove the tube and blow down into it to try and clear any blockage. If that doesn't work replace the pressure switch.
Oct 27, 2012 | Whirlpool Washing Machines
PE error where E is blinking in whirlpool whitemagic
pe error on the machine is normally the pause in action. try pressing the start /pause button again to activate the wash program
Jun 23, 2012 | Whirlpool Washing Machines
I get a "PE" error
As you said in the question you are washing machine is showing error "PE" it's not a big problem you are washing machine is just fine.PE means error signal due to low voltage .Machine resumes functioning after the voltage comes back to normal.Thanks for your question.
Jun 19, 2011 | Washing Machines
Zanussi zwf1430w progress 14oo
Its your filter that needs to be emptied; open up the front, locate filter, clean out. Refer to users' manual.
May 11, 2008 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
107 people viewed this question
Top Washing Machines Experts
