Question about Dishwashers
Dishwasher fisher and paykal model dw60c lights flashing not draining
aborcass
  • 2651 Answers
SOURCE: Fisher & paykal soft touch dishwasher leakage
could be a multitude of issues causing water to leak, from misloading dishwasher to a faulty water valve. theres a pretty good trouble shooter/ tech sheet located on inside back wall behind the lower drawer
Posted on Mar 16, 2008
  • 3247 Answers
SOURCE: my fisher paykel DD S03SS dishwasher leaks from the top, & drain
The drawers should not leak unless there is a problem with the vacuum seal. Try cleaning the edges of the doors and operate. You should feel the vacuum is holding the doors. The seals could be faulty or vacuum system may be faulty.
About not draining completely - a possibility is the common drain hose after the U adapter being clogged. Remove the clamp and pass a flexible wire coat hanger towards the main drain pipe. If both drawers are not draining then it is unlikely the drain hose between the U clamp and the dishwasher is clogged. Also make sure the height of inlet water pipe and drain outlet is as specified in the installation manual
Posted on Nov 10, 2009
rylee_smith
  • 8619 Answers
SOURCE: How do i reset a
Hi
Thanks for using FixYa.
F1 error means that the flood switch has been activated. You’ll need to reset it by powering off the breaker or by unplugging the unit from the power socket and mains for more than five minutes. Please check that there is no blockage in the drain hose and it is not raised higher otherwise the water will run back to the dishwasher. Also perform the following procedure---
    • Unplug power and remove bottom dish drawer
    • Use a Sponge and dry all the excess water underneath
    • Remove circuit board cover
    • Dry all around and underneath as much as possible
    • Apply hairdryer for 10-15min
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 07, 2010
techbuster
  • 5081 Answers
SOURCE: Fisher Paykel Dishwasher model DD603SS The
Since the drain pump will pump the water out using the "cancel/drain" button, if it did not work then your problem is likely to be in the drain hose system or the garbage disposal downstream from the drain pump. Check for kinks in clogs in the drain hose. Grease can build up in the portion of the drain hose just before it attaches to the garbage disposal.
If the hose is fine then i think the drain pump can be the problem.
Clean out any food or debris that is trapped within the pump assembly.
Posted on Sep 16, 2010
  • 3247 Answers
SOURCE: My fisher & paykel dishwasher
please confirm which model do you have 820 or 920.
I am assuming this is the one without display.
most likely cause is the flood switch at the base has actuated. This means water has leaked through the door gasket.
One way to check is to turn power off and draw the dishwasher out from under the sink. May have to disconnect the electric and water inlet.
Tilt the dishwasher to one side and wait for about 1 hour. Try the power on and see if the beep goes away.
You can access this switch by opening the chassis. It is item 5 on page 10 of this parts catalog. You can use a hair dryer to dry the circuit board.
If no help then you have to call the technician as there is not much service information readily available for this model.
See this user manual if you do not have one.
Posted on Jan 24, 2011
I have a Fisher&Paykal DD6031 drawer dishwasher. Stopped running mid cycle. Lights flashing on drawer front green,red,yellow,red green,red,yellow . I don't know what that code means. On the inside Heavy...
follow this steps and fix it. GOD BLESS YOU
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher Paykal 602 dishwasher - top drawer won't power on
Most likely the thermal fuse (inside heater assembly) is blown.
Not easy to repair. Need to replace the whole heater at the base of drawer.
Mar 28, 2013 | Fisher and Paykel Dishwashers
Dishwasher wont go past 11mins on washing cycle so dosnot empty
hi, here i m just giving a link .please visit the link.
link is:-
http://www.scribd.com/doc/37132673/Fisher-and-Paykal-DD603-User-Guide
here you will find the full gudie line about your dishwasher .Read it,and you can fix the dishwasher problem (s). i hope this will be helpfull to you.
please don't forget to vote me.
goodluck............
Jan 21, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
Top draw beeping delay and water not draining
Not sure what you mean by beeping "delay" I am not sure if there is any such light on the dishwasher. The HRS DELAY is displayed on the LCD when dishwasher has been set in delayed start mode. Are you seeing this flashing in an orange background? There could be several reasons for water not draining. Does the beeping go away if you press the power on/off button? Also does the delay flashing stop. Have you checked to see nothing is blocking the drain pump which is the same rotor that drives the washer arms.. What about the kitchen down pipe - is it clear? If you think you have to take the drawers out to reach the drain hose then follow instructions on page 7 step 2 of the installation manual. It is for a later model but your one should be similar. Make sure you turn the mains power off when working inside the dishwasher.
Jul 06, 2010 | Fisher and Paykel 24 in. DD-602 Built-in...
I have the fisher & paykal excellence 6-5 smart drive model gw609au when i first turn it on the seconds green light is flashing and it is trying to fill up but starts and stops all the time then just...
Hi Damian just read your posting.Your fault on your machine is the out of balance switch is faulty.Do you still require help?Please reply and I can guide you throe the repair of this problem.
Jul 02, 2010 | Fisher and Paykel Fisher & Paykel Washer
The power does not come on my fisher and paykall washing machine not sure what model but it is a 7.5kg top loader
if the display doesnt light up when u turn on power 2 unit it is one of 3 things, 1st/ no power at power point check with hair dryer or toaster, 2/ drain pump open circult. 3/ motor controller is faulty. hopefully it is the 1st option.please reply 4 more help
Apr 09, 2010 | Fisher and Paykel IWL12 Top Load Washer
F4 fault on fisher paykal dish drawer
F4 fault would inidicate the temperature sensor that senses the water temperature is faulty or the heating element is not working.
Looks like you will need a technician to visit and have a look.
Dec 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Mar 16, 2008 | Fisher and Paykel 23 in. DD603H SS...
Fisher & Paykal washing machine, Mod:GHL10US
if you want to find out for sure post your email here and i will send you the service manual
Jan 15, 2008 | Fisher Paykel EcoSmart GWL15
Dishwashers Logo
67 people viewed this question
Top Dishwashers Experts
