Question about Radio Communications
Digitech walkie talkie change channel from 8 to 1 model dc1003
Agent Ken
  • 250 Answers
SOURCE: T5900 Walkie Talkie Issue
Hello Bo Duke,
If one radio won't walk to the other my guess if that you have the Privacy Code function set up incorrectly.
The privacy code function mutes the radio unless it receives a signal from another radio transmitting the same privacy code. If Privacy Codes are turned on for Radio A but not turned on for Radio B then you will be able to transmit from Radio A to Radio B but not from Radio B to Radio A. If Privacy Codes are turned on for both radios but each unit is set to a different code then neither radio will be able to talk to the other.
Make sure that the radios are both set to the same privacy code or that the privacy code function is turned off on both radios. You can find more information on how this function is set in the radio's Owner's Manual.
Hope this helps!
Ken
"Go Ahead. Use Us."
Posted on Jul 03, 2008
AvioriX
  • 689 Answers
SOURCE: oregon scientific walkie talkies
Hi Neil
You can obtain the Owner's Manual (Contains simple instructions) from link below
http://www.expressfix.net/manuals/2WayRadios/OregonScientificTP329
Posted on Sep 06, 2008
SOURCE: binatone MR 250 walkie talkie is locked how do i unlock it?
Try holding down the ENTER button
Posted on Jan 13, 2009
  • 4 Answers
SOURCE: BellSouth 1010 walkie talkie receives constant static
you have opened up the squelch - refer to the manual to close and return radio to normal operation
Posted on Apr 30, 2010
eradiostore
  • 1654 Answers
SOURCE: The battery is fully charged
Your batteries are either no good, or not charged. When you press the PTT button it takes more energy than being in standby mode. If you have a battery problem it will fail quickly when the PTT is pressed.
Rechargeable batteries last approx. 18-24 months. Check your battery for a 3-digit date code. It is usually a 3 digit number followed by a couple of letters. The numbers tell the date of manufacture. The first number is the year, followed by the week of the year. 025 would be 2010 the 25th week. (or if very old it could be 2000 the 25th week.)
If you feel age is not a problem, you might check your charger(s) to see they are fully powered, and clear of debris on the contacts (and the radio contacts as well). Clean with a pencil eraser if needed.
A few tips: Be certain when placing your radios on the charge they are turned off. Check your wall outlet to be certain it doesn't get shut off with a light switch. Expect to replace your batteries every 2-3 years.
Best regards.
Posted on Nov 10, 2010
I need a manual for a Digitech dc-1005 walkie talkie
Hi Mitchell,
I own a Digitech DC1065 80 Ch CB HH, and no problems, so far.
Have you tried the Digitech website?
If so with no luck, may I suggest you join yahoo group specific to your radio Make/Model, there are experts with great info, plus you can download manuals, diagrams and software, etc.,,
I hope this is of help to you. (Ibought my DC1065 on ebay, no manual, but found the unit easy to work out, but I've got a bit of knowledge with radio equipment).
Cheers,
Peter
Jan 20, 2013 | Radio Communications
How do I change the channel on the Digitech DC-1005 walkie talkie? THanks
Looking everywhere online for an instruction manual for my little green and yellow walkie talkies ( Digitech dc-1003) without luck, so I had to work it out for myself.
The first button with the circle with line though it is the on/off button but it is also the channel select button. Hold it down for 2 secs to turn it on or off, OR press it once to be able to choose channels (the flashing number can be changed using the triangle up and triangle down buttons). Once you've chosen your channel, press the on/off button to select Hi or Lo frequency then press on/off button a third time to save. If you don't want the annoying static that sometimes comes, press the on/off button a fourth time for the squelch function (saves batteries and eliminates annoying hiss).
The next button is "S" which is the scan button. Hold it down to start scanning through all channels to try to pick up a transmission (we found a conversation between two fishermen today). When it finds a transmission, it will pause to let you see the channel number then continue. Hold down "S" button again to go back to original channel.
Next button "C" is the Call button. Pressing this button transmits a beeping alert to people on the same frequency/channel to let them know you are about to transmit a message.
The trangle up and triangle down buttons control the volume or select channels (as mentioned above).
Hope this helps. :)
Dec 27, 2010 | Audio Players & Recorders
Is there a way I can change the channel on my Walkie Talkie manually. I can't get them both on the same channel.
On the Motorolas you have to press the menu button until your current channel flashes. Then press the plus (+) or minus(-) sign to change the channel. 21 is a great channel and you can get distance on it.
May 10, 2010 | Motorola Walkie Talkie 2-Way Radio
Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Oct 23, 2008 | Motorola FV200AA GMRS/FRS 2-Way Radio...
How do I make it work
It depends on the channels on the walkie talkies.
Can you supply the frz range of the TRC, and walkie talkies make and model and I will try and get the frez on the channels for you.
I can then tell if it will work or not.
Apr 27, 2008 | Computers & Internet
Walky talky
A walkie talky as we called them, back when we were younger - and hell we probably still do in some respects, hence the fact my friend still refers to her cordless phone as a "walkie talky" and the principals haven't changed that much.
The common old Walkie Talky or CB radio use what we call a half duplex, that means only one person can talk at a time. We are talking and listening on the same channel.
Cell phones are full duplex, meaning two way conversation, and this is simply listening on one channel whilst talking on another, so the basic principal is basically the same, just a little more sophisticated.
Walkie-talkie typically has one channel
CB radio has 40 channels.
Cell phone
can communicate on 1,664 channels or more!
I have included a link to a circuit diagram.
http://www.freeinfosociety.com/electronics/schemview.php?id=1870
There is also two links below, building the transmitter & receiver.
Transmitter: http://www.zen22142.zen.co.uk/Circuits/rf/2bjttx.htm
Receiver: http://www.electronics-tutorials.com/receivers/regen-radio-receiver.htm
Trust this helps, and please take the time to rate the answer given, thank you.
Feb 04, 2008 | Motorola Walkie Talkie 2-Way Radio
Radio Communications Logo
41 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
