Question about GE Advantium 120 Convection/Microwave Oven
Button names wearing off
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The inked control button titles are wearing off our Advantium 120, model sca1001fss 01, manufactured in 2002. Can I purchase new stick on titles.
  • GE Master
  • 9,098 Answers
No, sorry. You'd have to order a new control panel assembly.
For model number SCA1001FSS001 it's part # WB07X10439 for $66.15.
You can find helpful exploded view diagrams and order it by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Jan 29, 2009
Our Advantium 120 oven (model # SCA1001KSS 02, Manufactured June 2008)is not working. Began w/ time not coming on when cooking and just a little green microwave light shows while cooking.
Typical of a control microchip failure caused by a power surge. With a microwave as old as yours, it is safest to simply replace the entire oven rather than attempt to fix it, as older magnetrons are likely to fail.
May 05, 2015 | GE Profile Advantium 120 Above-the-Cooktop...
We keep getting A MESSAGE "select action 1.0lb quick defrost" which displays every 15 minutes after any function on the Advantium 120 is used.
I surmise there's a short in the Quick Defrost button on the keypad. Either the keypad has collapsed there, or some contamination has gotten in. Another possibility is a failing program memory bit in the controller chip, but a contaminated keypad seems most likely. What happens if you press and hold that button while trying to key in another instruction? Is there any change in behavior?
Oct 21, 2014 | GE Advantium 120 Convection/Microwave Oven
How do I unlock the control panel
If this is a GE Advantium series microwave, the control panel can be locked to prevent children from manipulating the controls. To lock or unlock, press and hold the CLEAR/OFF button for 5 seconds. These instructions are included on page 36 of the owner's manual listed here:
http://www.managemylife.com/mmh/owner_manuals/14895/GE-Built-In-Microwave-Oven-L0902200?brand_name_search=+GE+Advantium+120
If you have questions, please post back and let me know. Please include your MODEL NUMBER if diffrent form the model you posted this question under. I hope this helps you.
May 20, 2010 | GE Advantium 120 Convection/Microwave Oven
How do I replace the fuse in a GE Advantium SCA1001KSS?
under the outer cover on a fuse clip its a special fuse avail at hardware stores
Oct 08, 2009 | GE Advantium 120 Convection/Microwave Oven
GE ADVANTIUM - CONTROLS LOCKED- I CAN NOT FIND MANUAL
Try pushing the clear/off button for 3 seconds to lock or unlock the controls.
May 19, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Opinion
I have had an Advantium for about 3 or 4 yrs and would use nothing else! When this one wears out I will buy another one! I hardly ever use my regular oven any more! Hope this helps.
Feb 02, 2009 | GE Advantium 120 Convection/Microwave Oven
Power level
Hi cindeet,
I don't have this particular model, but have experience with other GE stoves & ovens. Looking at the control panel for an Advantium 120 at the link below,
http://www.geappliances.com/products/introductions/advantium/downloads/advantium_brochure.pdf
I'd start by pressing the "Power/Temp" button, and then turn the knob to select which power level.
There is also a Help menu shown (upper left corner of the photo I'm looking at - page 4 of the PDF document referenced above.
Let me know how this works for you - thanks in-advance.
Jon
Dec 23, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Profile Advantium Wall Oven 240 volts 950 Watts
How long does it run before it fails? Does it look like the display is getting scrambled characters? I'm leaning toward a bad magnetron, but it may be more or less than that. If you can give more details and especially the actual full model number (as opposed to the model name Advantium 120) that would help. Thanks!
Oct 02, 2007 | GE Advantium 120 Convection/Microwave Oven
Advantium 120 problem
dis connect from power alow to reset for about a minute . if not there are switches behind the door probably not making good contact make sure door is closed tightly
Jul 30, 2007 | GE Advantium 120 Convection/Microwave Oven
Sca2001bss03-Advantium oven-built 06/2000
If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts (such as "button") by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 If you find you need control panel repair, we do that nationwide for $39.95 in most cases. See: http://tinyurl.com/yzjozk
Mar 19, 2007 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
99 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
