Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
My maytag neptune MAH6500 wont start. panel lights up but doesnt respond to any buttons,
  • 39 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs.
Posted on Jan 24, 2013
  • Maytag Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Posted on Jan 23, 2013
SOURCE: maytag neptune
i have maytag neptune wash,modelo mah5500bww,my problem is: no starting,flashing start/pause button,after ten minutes is off.And now is ready for start when press start/pause button
Posted on Aug 29, 2008
  • 11 Answers
SOURCE: Maytag neptune washer: will not start
plug a light into the washer outlet to check for elec current at this point before anything else.
Posted on Dec 28, 2008
dh1200s
  • 335 Answers
SOURCE: how to get front panel off neptune fav6800aww washing machine
Just a quick search in this forum fot "Front Panel" returned this post which says it better then I could.
http://www.fixya.com/support/t538238-remove_front_panel
Posted on Jan 18, 2009
milten1
  • 1304 Answers
SOURCE: Maytag washer MAH6500 leak - door boot issue?
there is a drain hole at the very bottom of the sump
about 1/4 in
if you ahve any other holes you will need a new boot
there is no real way to patch them, most patches will not flex enough to stay in place
ive included the part number you can order from sears
22003070
the best way to get one over on sears is to order it
then you cazn either fix it kinda hard but id walk you through it
or when the part arrives shedule service, just tell them its leaking
only when the tech gets there tell them you have a boot
sears hates self diagnostics and you will go to the bottom of the list
Posted on Oct 07, 2009
ginko
  • 19396 Answers
SOURCE: maytag neptune front loader model
Hi.
First disconnect power by tripping circuit breaker or disconnecting power cord. While power is off access the hose connected to drain pump. The pump assembly is mounted to the right rear of the base. With power not connected undo hose from pump, collect water and remove blockage, fit the pump back. See page 63, section six in the manual below:
SERVICE MANUAL.
Regards.
Ginko
Posted on Jun 18, 2011
Error code od maytag Neptune
http://homeguides.sfgate.com/maytag-neptune-washer-model-mah8700-troubleshooting-codes-102595.html. Here's the site for Maytag Neptune Washers. You can also find other modes there. Hope this helps. Enjoy.
Sep 30, 2014 | Maytag MAH6500 Neptune Front Loading...
Wont start. I soaked a shower curtain in bleach, ran the machine to add water and then hit pause to allow the fabric to soak in the bleach before washing. I pushed the pause buttonn to continue thewash...
I would unplug the washer to reset it. if you have already hit the power button to turn the unit off and it failed to respond. Newer washer machines are like computers, and smart phones these days. you have to reboot them because they do sometimes lock up. Pull the cord for about 5 minutes and see if that resolves your issue.
Dec 03, 2013 | Maytag MAH6500 Neptune Front Loading...
MY WASHER WON'T SPIN, WHAT COULD BE WRONG
this model has a problem with the lock
open your front panel and check r-11
on your control board
if this is burnt it wont lock and then wont spin
Oct 03, 2009 | Maytag MAH6500 Neptune Front Loading...
Hi, I have a Maytag Neptune (clothes) Washer. The tub didn't drain. Ran it twice. The second time with no soap. The drain pipe is not blocked. The hose is not kinked. I just leveled it because it was...
is the door lock light coming on if so then could be a clogged pump or bad pump. if lock light doesnt come on then may be a bad door latch/lock. may take a minute or two for light to com on once you turn it on .
Sep 16, 2009 | Maytag MAH6500 Neptune Front Loading...
Maytag neptune front load washer wont start when button pressed
This is joyce
first lets start simple unplug the machine and leave unpluged for 1 min. replug back, see if this solves the problem.
thanks,
joyce
Feb 06, 2009 | Maytag MAH6500 Neptune Front Loading...
Neptune mah4000aww belt wont stay on drive wheel
lost you on chat you closed the window
plz email me
Mar 03, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune MAH4000AWW
I SAY REPLACE TIMER (POWER CONTROL BOARD)
Jan 15, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune on/off button wont stay on
You have to investigate where the burning smell came from. Start at the timer and then check the main board. Also check the drain pump.
Oct 23, 2007 | Maytag MAH6500 Neptune Front Loading...
Maytag washer
Maybe you over-loaded, or you did not shut the door properly. Try reading the users' manual.
Mar 12, 2007 | Maytag MAH6500 Neptune Front Loading...
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
63 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
