Question about Lexmark X5470 All-In-One InkJet Printer
Cartridge I PUT IN TWO NEW CARTRIDGE AND IT READING ERROR #1203, WHAT IS MY PROBLEM
  • Lexmark Master
  • 684 Answers
Remove both the Cartridges take a Paper Towel turn the catridges direction so that u can see a Copper plate with small boxes on it....... Just wipe it twice or thrice with the Paper Towel..........Now Move the Catridge carrier which holds the Catridges manually with ur Hand from right to the Left and from Left to right for about 20 Times............. Now Insert both the catridges inside the Printer............. Turn the Printer On............ If still the same Error Message.... Clear NV RAM..... Unplug the Power Supply from the Printer.... Press and Hold the #5 button on the Printer and plug in the Power Supply....... Don Release the #5 button till the Printer turns on completely.... After releasing the #5 button........ Press the Menu button once Keep on Pressing the Right Navigation Key till u find an option saying Maintanence goto maintanenece and go to manufacturing and click on clear NV RAM..... Now as soon as the Printer is Restarted....... Still if it doesnt work call: 1-800-LEXMARK (539-6275)
Get the Printer Replaced... Good Luck
Posted on Jan 28, 2009
The printer read Cartridte error 1203 I am reading the manuel but I do not understand how to fix it to print. I do not have it connected to the computer I just want to make copies.
Are you using Dell Series 9 ink cartridges?
Error 1203 is a very interesting error code. Here is what I found out about error 1203
Error 1203 is a very interesting cartridge error. It means your cartridges overflow even from brand new cartridges after a several prints or right after you refilled the cat ridges. Check to see if ink are smeared on the holder where the contact panel with the cartridge
Solution:
I use the lint free cloth(coffee filter work great) with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
Then before you print anything, you should run aligned the cartridges a couple times then run clean cartridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of lint free cloth(coffee filter work great on those holder contact panel.
Rick
May 30, 2011 | Dell 926 All-In-One InkJet Printer
Cartridge error 1203
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Hope it will work for you take care all the best Pineworks
Mar 13, 2010 | Lexmark X7170 All-In-One InkJet Printer
I have inserted a new color ink cartridge, but when i close the printer I get an error message that reads 'Cartridge Error, Error #1203'. I have tried two different cartridges with no success. What is...
Yes ok it will be the inks.
or
Jan 05, 2010 | Dell 966 All-In-One InkJet Printer
I turned my printer on and have a message reading Cartridge Error Error:1203 See guide. I do not have a guide, it is missing as well as my install disc.
or
Dec 08, 2009 | Lexmark X7170 All-In-One InkJet Printer
Error 1203 I'm getting error 1203 on the printer. I have new cartridges in. Fresh paper. Still getting error 1203
1. Press Power to turn your All-In-One off.
2. Unplug your All-In-One from the wall outlet.
3. Plug in your All-In-One.
4. Reinstall the cartridges.
If this does not resolve the problem, replace your cartridges to fix the problem.
Nov 26, 2009 | Lexmark X7170 All-In-One InkJet Printer
My lexmarkp4350 is not printing the black ink
Ok this some times works.
or
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 26, 2009 | Lexmark C533DN InkJet Printer
Lexmark x9350 printer gives error message #1203
I logged into Lexmark's web site and checked their printer support page. It said that if you get error message 1203 your ink cartridge has leaked fluid. In order to find the right cartridge, do the following. Remove both ink cartridges, put in one, turn off the printer, turn it back on and if you get the message 1203 that's the cartridge with the problem. I did not get that message. I turned off the printer, put in the other cartridge, and turned it back on. Sure enough, I got the 1203 message again. (I had cleaned the wrong cartridge before). I removed the leaky cartridge, cleaneded it (making sure I did not leave any residue) and put it back in the printer. It worked!
Jun 13, 2009 | Lexmark X9350 All-In-One InkJet Printer
Error #1203.
or
Jun 01, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
Lexmark P6250 Printer error 1203 - Consult User Guide
It is a hardware printing problem . Try to clean contacts in printers in cartridge holder by alcogol and elastic rubber. it may become dirty an poor contact. after this you can try this:
Put some layers of the sticky tape on cartridge to improove force of contact.
Mar 06, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Error message 1203
This link should have the answer for you.
http://www.dellcommunity.com/supportforums/board/message?board.id=A940&message.id=13761
Jul 27, 2008 | Dell 924 All-in-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
66 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
