Question about Drills
How do you replace the oil in a hilti te72 rotary hammer drill
2 Suggested Answers
  • 123 Answers
SOURCE: Hilti TE 17 Rotary Hammer repair switch fix
If you are talking about the wire going from the switch to the stator it difficult to get to. You have to remove the motor end cap, cooling fan and handle holding the switch. this will get you to the brush holders. These can be brittle so you need to be carefull. Turn the motor over and tap the end of the armature on concrete checking the brush holders every couple of taps to see if they are coming out of the motor housing. after they clear they will just come out. If you havn't done so already remove the wires going to the brush holders. Your stator will simply slide out after your brush holder comes out. This will give you access to the wires to repair.
Hope this helps.
Posted on Oct 29, 2009
Testimonial: "worked well for me"
I am trying to find a trigger switch for a Hilti TE72 can you help? thanks colin.
Hilti only sells parts directly...
http://www.us.hilti.com/holus/
heatman101
May 14, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
I require a switch for a hilti TE72 where can i get one please
call them direct at 1-800-879-8000 and they can help either shiping from their warehouse or possibly finding one locally.
Nov 01, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
We have a Hilti TE72 Hammer Drill.... We have taken it to fix but they say they can't find parts... We think it is the piston and a rubber gasket that goes with the piston.... Do you have this?
Parts are no longer available for the TE72. You may find some used parts on EBAY. If the tool is not hammering it would need more than the piston and oring that goes on the pistion. Without all the proper seals and gaskets I would not even attempt to repair. If you do attempt to repair it do not put more than 70cc of lube in the drill. Too much oil will distroy the gears.
Aug 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
No power at all for te72 hilti. Changed fuse and plug and cleaned brushes. Any help please
There should not be a fuse in the TE72. Do you have a continuity tester to test the switch, cord and stator?
If you have had the brushes out then you have had the motor endcap, fan and brush holder out. This would allow you to all the wiring on the 72. There are no electronics so it can all be tested easily. You have two wires coming from the switch that go to the stator. Then two stator wires that connect to the brush holder. Check that you have continuity through the cord, switch and stator.
Jun 26, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Hi.I am trying to find a triger switch for a Hilti TE72 The switch fitted is a ''MARQUARDT 1264 1601 but any alternative would sufice. Thanks Keith
this is quite an old machine and the switch will no longer be abailable from hilti. However the TE805 has a very similar switch. instead of a trigger switch its a rocker switch, but it is possible to unscrew the top off your old switch and attach it to the new one. the part number is 17904
Mar 29, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Parts for a Hilti TE72
Ebay would be your best bet. Hilti has not produced that drill since around 1992. They no longer have parts for it. That is a double throw switch. Usually the side that is burned out will be discolored or loose at the contact. If it is the left side you can take the bottem left wire and hook it to the top left wire at the contact. Or do the same if it is the right one.
Feb 22, 2010 | Hilti Drills
I have a Hilti TE72 and vhen is hot, smell electrical wornet
They do produce a slight electrical burning smell when they get hot.
Nov 26, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
TE-72 sporadic hammer
You should have no more than 70cc of oil in the housing. AW46 Hydraulic fluid will work.
Aug 12, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
I have a te72 hilti and i need the plece roller No 72139 help.
This is a problem we have encountered many times. There is usually a good supply of Hilti for sale used. See if you can find a drill the same as yours and swap out the parts.
Apr 24, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Drills Logo
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
