Question about Garden
We have a keys backyard sauna and when I power it up the display shows EP manual says to check the temp sensor connector but does not say were it is please help were is it?
Model is FSK0011A5FSK0033A6 two person
2 Suggested Answers
SOURCE: We have a keys backyard sauna and when you turn it...
I had the same problem,I bought a used one and during assembly thought it didn't matter where I plugged the cables at the top power board, but it does or else once you try to turn on the heat the sauna shuts down.
INSTRUCTIONS: I fixed mine by connecting the cable that runs from the interior light to the last port, then comes a sealed port, then on the next port connect one of the two cables (the largest one) that comes from the temperature controller from the front wall, the rest cables don't matter which port you put them.
Good luck I hope it works, theres little information out there about fixing this problems. the manual doesnt say the order to connect the cables and to top it off the manufacturer went bankrupt.
Posted on Jul 30, 2011
I replaced my temp sensoe and it reads ccd
Hi Glenn, I'm glad to help! Here's how you check the Ambient Temp Sensor circuit itself to see if its working properly. Disconnect the Ambient Temp Sensor Connector. If the temp reading go to the default mode it will show 40 degrees. If it doesn't go to 40 Degrees then thyere something wrong with the system. Could be wiring or display itself. If it does go to 40 degrees then I'd try another sensor and see what happens. Hope this helps and have an awesome day Glenn.
Apr 11, 2014 | 2001 Dodge Ram 2500 Truck
Infrared sauna room (2 persons) Does anybody know what EP stands for or/means on the temperature control panel???
check to see if filters are clean if so see if recirculation pump is working if so check heater fuses if blown probably bad heater element
Mar 06, 2014 | Blue Wave Coronado -2 Person Infrared...
Sauna
I think you have the wrong category.
Apr 29, 2013 | Computers & Internet
Why doesnt the cooling fan come on on my 1993 mercury topaz
You just asked about the one circuit that gives this backyard mechanic nightmares(lol).There is a relay to turn fan on, but whether it is controlled by a simple temperature sensor/switch on the engine, or by your ecu (engine's computer) I don't know.
Until you get a definitive answer from one of our experts here, there is a simple test you can do to make sure fan motor is good. Unplug the connector for motor and check for corrosion in the terminals of the connector. Plug it back in. Look on the thermostat housing or just adjacent to it, for a single wire connector. This is the fan sensor/switch. Unplug it and turn key to on. Fan should start. Be careful of fan blades when key is on: It MAY come on any time key is on. If it doen't come on it may be a bad sensor in the switch-supposed to build resistance as coolant temp. increases, then at certain temp. will turn fan on.
So, fan on? Replace that switch you disconnected. Or, still no fan? Plug sensor back in. Turn key off. Unplug the fan motor again, and use jumper wires from battery to fan terminal connector, just long enough to verify if fan works or not. If fan motor is good, there is a problem with the temp. sensor, or the relay (probably located in fuse box by battery), or the associated wiring, or the computer (IF your fan is controlled by the computer). Then you have just inherited my nightmare. But if fan does not work, you have found the problem. Good luck.
Nov 11, 2011 | 1993 Mercury Topaz
"PROB" shows when fryer is
Computerboard will display "PROB" error when it could not sense resistance reading from the temperature probe sensor (temperature probe sensor is either open circuit or short circuited). Check first the temperature probe connectors, tighten loosely fitted connectors on wiring harness and computer board, then check if the wires are not damaged. Disconnect the temperature probe and check the resistance using an ohm meter. If the reading is either zero or infinite, you have to replace the temp probe.
Dec 18, 2010 | Pitco Frialator SG14 Deep Fryer
What does "prr" mean when displayed on the LED readout of the Mr. Steam control panel?
Hi my name is Mike I am with Mr. Steam Product Support. PRR is a code that shows up on our Steam Bath controls it was not used on our Sauna's. The PRR means there is a problem with the temp sensor on the control.please call me at 800-767-8326
Aug 20, 2010 | Mr Steam Mr. Steam Allegro Sauna Model...
My Maytag Self cleaning range is giving me a F-4 error when i turn on the oven
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
OK F4 is a Shorted wire or Sensor locate short and correct it or replace Sensor bcd5f2e.jpgGo to the rear of the stove and take the service panel off after disconnecting power. Find the sensor and unplug it. Check for continuity between each terminal and earth/ground/frame. Look for corrosion in the plug. Frigidaire offers a nice video which shows how to check a sensor. Yours is not a Frigidaire but they all work the same. They provide the control with temp data. The oven control (ERC) sends out voltage to the sensor. As temp changes the resistance in the sensor changes. This tells the brain (ERC) temp changes. When the sensor gets shorted or is open (no continuity) then the ERC declares an error and posts it to your control panel. Here is a tip. New sensors sometimes come without the connector. 2 porcelin wire nuts are provided to splice in the new sensor. If you see corrosion on the quick connect. and you cannot clean it but you have continuity to the old sensor and it is not shorted you can bypass the quick connect and make it work in some instances. Just thought I would throw that in.
Jul 22, 2010 | Maytag Kitchen Ranges
We have a keys backyard sauna and when you turn it on it only comes on for a split second than goes off. I cannot find any information on keys saunas online anywhere.
May 21, 2010 | Garden
I just bought a house with an amerec sauna. The
the 'easy' answer would be a tripped high-limit switch. Inside the generator box, there is a resettable circuit breaker to the heating element, on the top of the water tank.
kill the power to the unit, take off the shell and look for the pushbutton.
If that is the problem, there is a likely chance that the temp sensor in the shower is not working so it overheats and trips the high temp limit.
Dec 22, 2009 | Kitchen Appliances - Others
Garden Logo
91 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
