Question about Masonry Tools
Should i get the pointing Pen Of Sahara Slate Vision T2300
2 Suggested Answers
  • 1015 Answers
SOURCE: My slate vision tablet pc is having some problems.
Your tablet pc uses the Wacom Digitizer so the pen does not use a battery. It is possible that it could be the pen or the screen. It works with electromagnetic resonance technology and the screen produces this signal that the pen grabs, converts, and returns to the screen without batteries. The pen does contain compenents that can fail but so does the screen. You could try buying a replacement pen for around $20 dollars and see if that works. Worst case you would be out $20. If you had another tablet PC that uses a Wacom screen you could try the pen with that one or test the other pen with yours.
Posted on Sep 29, 2009
What is a stylus pen?
Wikipedia says: A stylus pen is a computer accessory that is used to assist in navigating or providing more precision when using touchscreens. It usually refers to a narrow elongated staff, similar to a modern ballpoint pen. Many styli are heavily curved to be held more easily. Another widely-used writing tool is the stylus used by blind users in conjunction with the slate for punching out the dots in Braille.[3]
Jan 20, 2013 | Computers & Internet
Turning on hp slate 500 without power switch
I hope you found a solution months ago, but just in case:
My switch also broke a while back, and this is a common problem with the slate 500 due to the construction of the switch.
This should help:
http://forum.tabletpcreview.com/hp-slate/41309-my-power-switch-just-broke-2.html
My solution: remove what's left of the plastic switch (if anything) then use a long thin thing (LTT) (about 2 cm long) in the hole where the switch was. I use a squashed paper clip - someone else had a mini screwdriver, someone else the toothpick on their pen knife.
Put the LTT straight at the top of the switch hole and pull down, the same way you used to pull down on the power switch, then let go. The indicator light under the switch hole will blink 3 times quickly if you've successfully tripped the switch.
All the best!
Nov 05, 2012 | HP Slate 500 8.9 Tablet
The tip broke off my pen. How do I get the old one out and then put in a new tip?
I used a razor blade and dug in a bit where it broke off. Minimal damage--not recommended but I got it out.
Mar 24, 2011 | Polyvision eno mini 2120 Interactive Slate...
Can you tell me where the serial number is located on the eno mini polyvision slates?
The Mini itself does not have a serial number. If you need to provide a serial number for support or any other reasons just use the Serial number for the stylus. This is located inside the stylus underneath the battery. If you have any other questions you can call PolyVision tech support directly at 800-620-7659 Opt. 1.
Good Luck!
Jan 06, 2011 | Polyvision eno mini 2120 Interactive Slate...
My child acidently change the name and did something to locked out the ssid code i have no access i have to constantly inter codes or look for other sites all this happen when she tried to add on another...
In this case, it's best to reset your modem to the factory default settings and start off with a clean slate. You can do this reset by pushing the little hole saying Reset at the back for about half a minute. You'll need a pen or a toothpick, or something of a similar size for this.
Aug 25, 2010 | Belkin N1 Wireless-N Wireless Router
My archos 3 vision screen has frozen how do i fix this problem
press the reset button in the back with a pin or small pen, hold for 10 s or so.
May 20, 2010 | Archos 3 Vision Digital Media Player
How do you capture signature
To capture signatures you must have a graphic tablet that has a pen mouse with it. Procure and install the tablet and then use the pen mouse to capture your signatures. It is an electronic slate that is attached to the USB port and use to trace drawings, maps and such non linear graphics. Basically for outlines.
Nov 18, 2009 | ACECAD 3" x 2.25" Flair GT-302 Graphic...
I am trying to get some sort of an antivirus program running on my laptop..it has no cd rom. help?
you can download a number of software titles if you have internet access. There are many ways to get free software, just google it. If you have a usb port you may be able to use a flash drive (thumb drive, pen drive, etc.) to install software from another source.
Oct 26, 2009 | Panasonic Toughbook 51 Notebook - Intel...
My slate vision tablet pc is having some problems. The screen is not reacting when the pen touches the screen. I went into the control panel seems that everything set up correctly. Could it be the pen that...
Sep 28, 2009 | FIC SlateVision Tablet PC
Masonry Tools Logo
212 people viewed this question
Top Masonry Tools Experts
Tom Chichester
Are you a Masonry Tool Expert? Answer questions, earn points and help others
