Question about Kenmore 30 in. Updraft Range Hood with 3-Setting Halogen Lighting
Problems with Kenmore 30 in. Updraft Range Hood with 3-Setting Ha
As soon as the lights are screwed in, they are at the brightest setting. Can't adjust to other settings or turn the lights off with out using a  potholder; the lights will burn you.
  • elhaye1 Jan 28, 2009
    The solution sounds correct. I'll know for sure this coming week.
    I'll let you know the outcome. Thanks
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your description of the problem indicates a most like faulty 3-setting switch. Specifically, the last setting/brightest is shorted hence any other setting would makes no difference.
An alternate likely possibility is a burned wire/connector or relay/triac short.
While relatively a minor/easy repair, it is the dis-assembly to have access to and remove the 3-setting switch is the challenge.
Good luck and thank you for using FixYa.
Posted on Jan 28, 2009
    Brigadier General:
  • 8,619 Answers
Check the knob it might be loosened and needs a replacement.
  • 3,037 Answers
Sounds like you may have a burnt out resistor internally in the device and then it goes to the default setting with that being the brightest. You will need to find this burnt out resistor and replace it. It shouldn't cost too much for a new one. I would think that Kenmore would have a replacement if you give them a call or depending on its design, Radio Shack may also have one.
bestdarngood
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
www.kenmore.com/kenmore-elite-30inch-slide...electric-range...
Kenmore
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
www.kenmore.com/kenmore-elite-30inch...slide...electric/p-02...
Kenmore
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
If I replace a range hood should I get good updraft if I reduce a existing 8 inch pipe to 6 inches for the new range hood. The ADKY I just bought was an excellent price
according to bernolii's equation air velocity increases as pipe dia decrease's given that force(fan) remains' the same
aka it's gonna make a lot more noise !!
Apr 22, 2015 | Kitchen Ranges
Lights quit working on broad range hood
The tiny metal tabs that contact the very end of the light bulb after it is screwed in making a circuit get pushed back too far when you tighten the bulb and with all the steam and muck eventually fail to make contact. shut down the power and use a tiny screwdriver to gently nudge the electrical contacts back up "a little cleaning wouldn't hurt either" look at the very bottom of your bulb, clean that too perhaps with a few strokes of a wire brush, gently put the bulb back in and you are good to go, mine did the same thing.
Mar 29, 2014 | Broan QS130WW Under Cabinet QS1 Series...
Kenmore range hood model 31093. The fan motor sounds like its running but the blade is not turning. The blade turns freely when swith is off.
The fan shaft is stripped out inside the hub of the fan...this is fairly common and can be tough to fix...some hubs can be "egg"shaped with a large pliers to make them grip the shaft...
Others I have jammed a small piece of metal in to make them grip...
Also have glued some together with a glue like an expoxy cement that will get hard and hold everything together...
Each one I view and do differently depending on what I find and what's available...
heatman101
Jan 12, 2011 | Kenmore 36 in. Updraft Range Hood with...
GE Deluxe 30 Range Hood ---can't find a 2 way bulb (Light/night light)???
The current Convertible Deluxe rangehood from GE doesn't support a two-way (light/night light bulb). You can use an incandescent light with an A15 type (60 watts or less) or a compact fluorescent (A17 or T2) with an ordinary screw base that draws no more than 13 watts. Some models can only use the incandescent light (RN328, JN327, JV338). The recommended compact fluorescents are available from www.gelighting.com (product codes: 85383 or 47486). Check you manual or products.geappliances.com for a pdf of your manual.
I wish that I could be of more help.
(the model of your range hood would be useful to get more information)
Jul 09, 2010 | GE Deluxe 30" Convertible Range Hood -...
How to adjust headlights-2002 Grand Prix
The adjustment screws/nuts should be located either on the top of the headlamp assembly, behind the headlamp assembly, or near the frame rail by the radiator support.
You will have vertical adjustment screws for each independent beam (separate highs and separate lows, but will be same screw if highs and lows are the same bulb). You may also have additional horizontal adjustment screws as well
Park your car on a level ground 30 feet from a wall and measure the height from the ground to the bulb and mark on a wall (do this for highs beams and low beams if the bulbs are separate, if highs and lows are the same bulb, only do it for the lows)
For Low Beams: If the headlights read VOR, then aim the brightest part or cutoff part just below the mark on the wall. If it says VOL or nothing, aim them 2 inches below the mark on the wall.
For High Beams (if separate from low beams): Aim the headlight directly at the line you marked on the wall.
Oct 26, 2009 | 2002 Pontiac Grand Prix
How do I adjust the headlights on 2001 hyundai tiburon?
Pop the hood and you should see two dials (hex shaped plastic screws) on each of the headlight assemblies. One is for your high beams and one is for your low beams. You'll need to measure from the ground up to the center of your bulb and make that marking on the wall for each of your bulbs (so four marks). Then park about 30 feet away from the wall (make sure you're on a level surface that's level with the wall base. If the light says VOR, then the top of the brightest area of the light should line up with the mark. if it says VOL, then the top of the brightest area of the light should line up two inches below the mark.
Aug 21, 2009 | 2001 Hyundai Tiburon
Broan allure II range hood
Did you ever find out what blew the fuse originally? Do the lights have a dimmer feature on them? If so, the reostsat may be bad, or the switch that controls the light intensity, 1,2,3. ect. Something caused the fuse to blow, maybe a wire on the bulb or switch somewhere.
Dec 20, 2007 | Broan-NuTone Broan Range Hood Accessory
Light won't shut off
I have never reaplaced anything on the control board. But it is definetly the control board that is defective.
Part# R111638 = $110.00
I do service calls for broan-nutone.
Inventex.com
Nov 11, 2007 | Broan-NuTone Allure II QS230SS Kitchen...
Kitchen Ranges Logo
24 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
