Question about Westinghouse Dishwashers
How do you start a Westinghouse sb925 dishwasher
We have just bought a new house which has a Westinghouse sb925 dishwasher. It has no manual and we are struggling to get it to work and only seem able to get flashing lights on the screen. Any ideas where we might be able to get a manual?
SOURCE: Indesit idl 705 Dishwasher
Having read another users fault (LUNNY) that has same fault. They got engr out and it was a blocked pump. Where is the pupmp located on this model as I have the same fault and want to resolve it asap.
Posted on Sep 23, 2007
jsrock516
  • 5911 Answers
SOURCE: Dishwasher
If this is a blinking "clean light", this is a common problem with some of the Kenmore and Whirlpool models. I believe the problem is attributed to water supply temperatures being too low when filling. Apparently, there are some sensitivity issues with the temperature sensing circuits in some dishwashers. There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on what the flashing light sequence is in determining WHAT component is bad. Let me know if this helps you. Post back with your comments or questions.
Posted on Feb 16, 2008
  • 351 Answers
SOURCE: Hotpoint Dishwasher BF1620
ive not worked on hotpoint dishwashers,does the dishwasher drain? at the point it plays up is it supposed to be filling or washing.check the filters inlet valve etc.do you still have the manual for the dishwasher.the flashing lights are most likley a fault code but we dont get hotpoint dishwashers in australia.sorry i cant be of more help.Ian
Posted on Mar 23, 2008
  • 3 Answers
SOURCE: dishwasher, flashing lights, frigidaire
The steam has gotten into the keypad display and fried it. Call Fridgidaire and let them know you've seen numerous people on the internet with the same problem and that you need part# 154554401 It worked for me.
Posted on Apr 01, 2009
SOURCE: Flashing "Washing" light on my frigidaire 1000 series dishwasher
Possible solution. I had the same problem of "washing" light flashing last year and now today. Warranty has been expired for awhile, so no harm in trying. What worked for my situation was removing the six screws for the back of the plastic control cover. Take of the plastic cover. There are are two connectors to the HANDLE with white and black wires. To be safe I would shut off the ciruit to the dishwasher. Safety first. Carefully disconnect and inspect the contacts inside the connectors. Do not insert any metal objects if you left the power on. I believe that the moisture from the dishwasher can degrade the connectivity. I cleaned the contacts with q-tips and re-installed. Be careful to not bend the contacts. If you had sound, you could hear my dishwasher running. Total cost is about three cents. I believe that the connectors do not full close when corroded, which prevents the completion of the circuit to the controlls. The flashing light indicates that the door is open, when in fact it is closed. Hopefully this will help someone. Semper Fi
Posted on Feb 06, 2010
My dishwasher has a flashing code 20. where do I check to fix this problem
This is a water drain problem.
• There is a blockage in the sink spigot.
Clean the sink spigot.
• The installation of the water drain hose is not correct. The
hose can be kinked or squashed.
Make sure that the installation is correct
Jun 26, 2014 | Westinghouse Dishwashers
What voltage should be across the pins on the heater element on a westinghouse sb925
please confirm if the heater element looks like the one on this diagram
http://spares.bigwarehouse.com.au/product_info.php?cPath=64685_79594_79627&products_id=1611198
Is your model operating on 240v AC.
Generally to test heater it is better to check for ohms. If the dishwasher is now working then please clarify why you need to check voltage on heater.
Apr 11, 2014 | Westinghouse 24 in. MDP531 RF...
Me and my partner just bought a new house and yesterday we tried the dishwasher for the first time. I'm not sure which model we have, but it is a white Westinghouse Dishwasher with 5 wash options. The...
If the dishwasher has been setting for a long time the seals in the pump could of dryed out. Go ahead and run the dishwasher again and it could seal itself back up if not..... you will need to call a repairman to replace the seals. Or buy a new dishwasher if the unit has some age on it. You will get a new warranty..... I would also tell your realitor about it and maybe she could help you. The appliance may have a 30 warranty with the purchase of the house.......Hope this helps...
Mar 17, 2011 | Westinghouse Dishwashers
Hi soes anyone know how to remove the front control panel from a westinghouse sb925 dishwasher. the buttons are sticking and I want to inspect the board Thanks Gavin
You usually need to remove the top panel first, screws at the back, then you can gain access to the rest of the panels.
Jan 17, 2011 | Dishwashers
My westinghouse virtuoso sensor wash dishwasher isnt cleaning things as good as it should. I dont have a manual as I have just brought this house with dishwasher. Please help?
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things...
Bought new spray arms online and installed them in minutes...now the thing works like new...
However I have also found that if the heating element goes bad then that also can mess things up bad...
So I would buy new spray arms, and also check out the heating element to make sure it is working...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker
Sep 24, 2010 | Dishwashers
Periodically works fine, but mostly appears to only be rinsing dishes no matter what programme I put it on
Conia dishwasher continued for about 5 hours. No way of knowing how to operate this dish washer with no instructions. Just bought house with this dishwasher already installed.
Please help
Jan 24, 2010 | Westinghouse Dishwashers
Stops mid cycle often
Hi there, did you ever find out what was wrong with your dishwasher? I have a Westinghouse 904 doing the same thing but when we moved into this house the manual was long lost. Any thoughts would be greatly appreciated.
My email address is shaneane@clear.net.nz
Jun 02, 2009 | Westinghouse Dishwashers
Westinghouse SB925 Dishwasher not filling
Request the service manual directly from Westinghouse.
Dec 01, 2017 | Dishwashers
WESTINGHOUSE 906 DISHWASHER
Has anyone managed to find a Manual for the Westinghouse 906?
Dec 09, 2007 | Westinghouse Dishwashers
Dishwashers Logo
42 people viewed this question
Top Westinghouse Dishwashers Experts
Denis FixYa...
Denis FixYa...
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
