What are some different types of electronic memory?
  • 75 Answers
BIOS, ROM, RAM (dynamic/static), Cache, Flash memory, memory sticks, video memory, etc
Posted on Jan 23, 2013
Memory card not inserting in mobile phone
There are several memory card types. These types are of different sizes and format. You have to check what type your mobile phone supports.
For instance My mobile phone supports MicroSD memory cards. My earlier phone supported micro 2 type. There is mini SD type too. you have to match the type with the mobile device required type.
May 01, 2014 | Electronics - Others
Where on my dell inspiron/1200 do i insert sandisk
Do you mean an 8GB SanDisk USB flash drive (thumb drive) or memory card (SD card or another type) or another SanDisk product?
If you have a flash drive, plug it into one of the 3 USB ports on the back of the laptop. If you have other devices plugged in, you may need a USB hub to add ports. (Note: hubs can fail; try a direct connection if the unit doesn't communicate.)
If you are using a memory card, you need to add a memory card reader. USB card readers are available from many shops; they will be cheaper from some online vendors compared to the big box electronics stores. Get one that supports the format of your memory card. There may be PC card slot card readers but I'm not aware of any specific models. The Inspiron/1200 supports Type I or Type II CardBus devices; 16-bit PCMCIA cards are also supported.
If you have a different item, please add a comment giving more informatiion on which SanDisk product you are connecting to the computer. I hope this helps.
Oct 16, 2012 | SanDisk Televison & Video
Aiptek Sd card compatible Problems
Some Aiptek cameras work with SD and SDHC cards, some work only with SD cards. If you have one of the latter, make sure your card is an SD card, not an SDHC card. The two card types are physically identical but electronically different.
If you need further assistance, please feel free to reply to this post. But be sure to specify the model of your Aiptek camera, as well as the type and size of your memory card.
Feb 17, 2012 | Aiptek Cameras
Can't seem to get nextech memory stick to fit into IBM computer
Hello wswarts547,
It's possible that the module of memory you have is not the right type for the motherboard you are trying to put it in.
There are different types of memory. (DDR, DDR2, DDR3, and SO-DIMM is for Laptops)
Each has a not or two in different places that prevent installing the wrong type into the wrong socket. Check the specifications of the motherboard and make sure you have the correct module type.
Hope this helps!
Jun 28, 2011 | Computers & Internet
Is there any way to retrieve data from a memory card that cannot be detected on any device? Is there a place you can send it to retrieve the data?
You can get a converter for the tiny chip at the local big box electronics store (in our area, Best Buy).
It will take the small micro and put it into a different type of device with a USB port that attaches to your computer, then you can download the pictures.
Also, if this is the chip out of your phone, you can also buy a device that will attach to your phone and USB to your computer so you do not have to remove the chip.
Nov 26, 2010 | SanDisk 2GB microSD Memory Card
How to use a memory stick right from the start
hi
  • Understand how a Memory Stick Pro works. The small card saves information from a portable device. You can save, delete and rewrite to the card as many times as you want. You can also remove the card and insert it into another device. For example, you can save photos from a camera, then insert the memory card into your laptop to view or download the images.
  • Step 2 Make sure you buy a memory card that matches the demands of your electronic device. The cards have different saving speeds and data-holding capacities. Generally speaking, the more data the card can hold and the faster its speed, the more expensive the memory card. Check your electronic device's product information for recommendations on the best type and size of memory card.
  • Step 3 Insert the Memory Stick Pro into the electronic device. Most devices have a small flap or cover on its side that holds the card. The memory card slides into a slot under the flap. Gently push in the card and close the flap.
  • Step 4 Save to the memory card. Once the card is installed, many devices know to save new data to the card. In some cases, however, you may need to specify where to save files, either to a built-in hard drive or to the memory card.
  • Step 5 To remove the card, open the flap and gently press the card in. The card should then pop out of the slot for easy removal. The card can now be inserted into another device.
  • vote me if your setisfied
    Jun 29, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
    Memory type for the acer am5630-u5209a
    Acer Aspire-Desktop AM5630-U5209a specs:
    Memory Type-----DDR2
    Memory Speed---PC2-4200, PC2-5300
    Memory Type-----Non-ECC Non Registered
    Memory Slots----2
    Max Memory Per System--4096MB (4GB)
    Max Memory Per Slot-------2048MB (2GB)
    Dual Channel Memory Support---Supported
    Tri-Channel Memory Support------Not Supported
    Install Memory in Pairs--------------Not Required
    also check your memory voltages by looking at the different memory voltage settings in your bios, write down the choices of the different voltages supplied by the motherboard for the memory.
    Not all memory is created equal. for example, i purchased some high end gaming memory that matched my system specs only to find out it ran at a higher voltage than my motherboard would supply. Post again if you need more help ..
    Regards..
    Mar 20, 2009 | Acer Computers & Internet
    Pda newbie - memory question
    If you are referring to the difference between Compact Flash and Secure Digital memory, then there is no difference, except the format. By providing two different memory slots, you are able to install more memory, or use one slot for memory, while using the second slot for other peripherals, like network cards, modems, or wireless cards.
    Sep 13, 2005 | Dell Axim X5 Pocket PC
    Sony memory stick
    Lexar, Sandisk, Sony, Delfin, Dane etc... http://www.streetprices.com/Electronics/Digital_Cameras/Accessories/Memory/Memory_Stick_128MB/ I think I've seem a Riken or similar as well.
    Sep 08, 2005 | Sony Cyber-Shot DSC-P31 Digital Camera
    Computers & Internet Logo
    66 people viewed this question
    David Payne
    David Payne
