What does RAM stand for? - Computers & Internet
  • 1,869 Answers
Random access memory
Posted on Feb 05, 2013
  • 75 Answers
Random Access Memory
Posted on Jan 23, 2013
WHT IS THE RAM AND WHERE IS IT LOCATED IN EL18505-42W
Install: Wood floor is best to stand on.
Worst: Carpet adds static potential!
Static can destroy your components inside your computer.
Make sure to grab a hold of your case before, discharge static.
You can choose to install one or 2 sticks of ram.
Image of what your main board might look like.
Dual channel would be both sockets with same size sticks of ram.
Example: 2 sticks of DDR3 at 1GB (1 Gigabyte per stick)
Aug 03, 2014 | E-Machines eMachines Desktop PC
2008 Dodge Ram 3.7 cylinder location
standing in front of the engine, number 2 cylinder would be the first cylinder on the left bank.
Apr 25, 2014 | 2004 Dodge Ram 1500
Thermostat locaiton on a 2006 Dodge Ram 1500 big Horn Editon
follow the lower radiator hose to engine block,you have to raise the vechicle remove thermostat from the bottom,besure secure vechicle with jack stands.
Aug 30, 2012 | 2006 Dodge Ram 1500
How do i use a pen drive as ram?
Hi, Thanks for using fixya.
Flash drive is a different device than ram. You can not use a flash drive as ram. Ram stands for Ramdom Access Memory. Flash drives are used for file/program storage.
Hope this helps.
Terry
If you have any further questions regarding this matter feel free to post a comment or if you are satisfied with my answer, please give it a rating for this is the reason I do this work.
Feb 20, 2011 | Computers & Internet
Is ram and memory the same?
Yes it is Ram stands for random access memory .........cheers
Jan 27, 2011 | Toshiba Satellite L25-S119 Notebook
Can I put different types of RAM on a motherboard?
Not different types per se, but you may be able to put different speeds.
Type would be like DDR Sdram2_bing.gif, or DDR2 Sdram for example.
Speed is a slang term for Frequency Rate. What frequency rate does the ram memory2_bing.gif module (Stick) operate at.
Example: DDR2 Sdram that has a frequency rate of 667MHz. (PC2-5300) MHz stands for MegaHertz.
Mega = approximately 1 Million. Hertz stands for Cycles per Second.
The above ram memory module operates at 667 Million Cycles per Second.
If you install two ram modules that have a different frequency rate, all the ram memory installed will operate at the slower frequency rate.
(Provided the computer will support more than just one frequency rate)
Have a computer in mind, or is this just a generic question? A what if?
Reply to your recent comment:
If this is in relation to two different manufactures of your ram memory, it shouldn't be a problem.
Where you may get into trouble in this area, is if one ram memory module (Stick) is generic, or low budget, and one ram memory module is a high performance gamer ram memory.
Without knowing the exact manufacturer of your computer, plus the Model name of it, and also knowing the information you have about your ram memory 'sticks', the following information is just generic, or general information.
High performance ram memory may use a higher voltage. Not always, but a good portion of the time.
High performance ram may also use a faster set of ram timings.
It may also have high density DRAM chips, and the chip configuration may be setup differently.
(The black rectangular modules you see on the side of a ram memory 'stick', are DRAM chips)
To explain so far;
SDR Sdram was the typical ram memory for years after SIMM ram memory.
SDR stands for Single Data rate.
Commonly just referred to as Sdram, but in actuality that is erroneous.
(Sdram stands for Synchronous Dynamic Random Access Memory)
Then came DDR Sdram.
Double Data Rate Sdram.
Then DDR2 SDram.
Double Data Rate 2 Sdram.
Then DDR3 Sdram.
Double Data Rate 3 Sdram.
1) http://en.wikipedia.org/wiki/SDRAM
(Anything you see on a Wikipedia page that is in blue, is a link to more information.
To further illustrate this,
2) http://en.wikipedia.org/wiki/DDR_SDRAM )
SDR Sdram specifications were all over the place. What was considered to be a standard for one manufacturer, differed for another manufacturer.
The JEDEC organization was formed.
JEDEC sets the standards for ram memory from DDR Sdram on up.
Voltage for DDR Sdram is 2.5 volts
DDR2 is 1.8 Volts
DDR3 is 1.5 Volts.
Ram manufacturers found that by upping the voltage requirement on high performance ram, the ram could perform, better.
Not true in all cases, as there is high performance ram that operates at the JEDEC standard.
Ram timings were also varied.
Also the chip configuration
Plus the density of the DRAM chip.
Unless it is a really cheap, generic ram module, (Stick), there will be a manufacturers code on the side.
With this code I can tell you the specifications of that ram module.
I can also explain
Feb 28, 2010 | Computers & Internet
How do i check my break pads on a '93 dodge ram 50?
  1. jack up car
  2. place a stand under car
  3. remove tire ( have a friens stand on breaks )
  4. now remove caliper usually 2 bolts on rear of caliper
  5. break pads normally are 3/4 - 1 inch thick new
ok now if you are un sure at anny point in the directions or locating bolts (STOP) go no further
replace tire tighten nuts up and go to a mechanic
it might cost a bit but the alternative is a posability and your life or the life of a family of four is worth more than a few bucks
Jan 07, 2010 | 1993 Dodge Power Ram 50
Want to add RAM to my Pavillion DV 1000 and I know
Refer to the manual that comes with your Notebook when you purchase it.
Here is the manual link for Hardware & Software guide
http://h10032.www1.hp.com/ctg/Manual/c00569409.pdf
Download the manual if in case you don't have it. and open it with adobe reader.
Dec 28, 2009 | HP Pavilion dv1000 Notebook
What Jack and stand to get for my '04 Ram 1500 Short Bed V6?
THE SAFEST CHOICE IS THE 3 TON.. YOU COULD GO WITH THE 2 OR 2.5 TON, BUT WITH THE SIZE OF YOUR TRUCK YOU NEED THE 3 TON..REMEBER TO ALWAYS USE THE JACK STANDS..GOOD LUCK KEITH...
Mar 14, 2009 | 2004 Dodge Ram 1500
I want to know if SDRAM and DDR@ are the same thing?
No SDRAM is single data ram, with 2 slots in the bottom and DDR is double data ram, with one slot at the bottom.
Aug 17, 2008 | Computers & Internet
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
