Question about Kibri Ho 9802 Lkw Commercial Garage Repair Center Nisb
"Where can I find garage door repair services?"
My garage door's alignment is not correct and want to know where can I find door repair service provider?
My garage door opens by itself, periodically.
Note: For us, the garage door opener repair technician had to replace the sensors, even though they seemed to be aligned.
Hello, Wayne -
A few years ago we experienced a similar problem with our garage door. We had to call for service on the garage door opener. Fortunately, the previous owner of our home left a business card for the company which serviced the garage door when they owned the home. They left the business card tucked in behind the garage door opener power button on the garage wall.
Best wishes.
Dec 23, 2017 | Building Materials
How to align safety eyes on garage door opener
The receiving unit usually has an led that lights when the sending units light is aligned correctly to let you know its ok.
Jun 26, 2014 | liftmaster Chamberlain Garage Door Opener...
Chamberlain garage door will not close
If your garage door will not close from the open position and reverses immediately or part way down there is a safety beam problem, usually there is a safety light on the opener which will flash when the safety beam is activated or faulty. Clean the photo beams with a clean damp cloth, check if the door now operates, if it does not, check that the safety beams have not become misaligned, there is normally a light on one of the sensors that indicates when they are correctly aligned, if the light is on it means they are not aligned, the light off indicates they are aligned. If they are not aligned try adjusting them, if this does not work they are probably faulty.
Further reading garage door opener repair guide
Jun 16, 2012 | Chamberlain Power Drive 1/2 HP Chain Drive...
My liftmaster will open with the remote but to close the door, we have to hold down the wall unit. It starts to close, jerks to a stop, then we have to press and hole the button and it closes.
Hi, it is probably the safety photo beams out of alignment or not working, when this happens the garage opener goes into 'dead man' operating mode, ie you need to keep the button pressed for the door to operate. You can find user and installation manuals here - Liftmaster Garage Door Opener Installation Manuals
Sep 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
Have to hold button in on remote and keypad for door to go up and down changed battery on keypad but problem still occuring please help
Jul 30, 2011 | liftmaster 371 Remote Transmitter
Garage door will not close when using the remote or garage door button. it will open, however. it can be forced closed by holding the garage door down. i have had this problem before . i have...
Check to see if your child/animal security beam is working correctly. It is an "Electric Eye" mounted about 12 in off of the floor on two mounting points and one side shoots an infra red beam across to a receiver. These points must be reasonably aligned to flash a beam (cannot see) from one point to another. This beam keeps the door open if it is interrupted . If it is not aligned, then the door opener sees a problem and will not close the door electrically. You must aligned the beam by bending the transmitter or receiver untill you can close the door by the remote. Also check to see if something placed in the garage is not blocking the beam first.
Jan 06, 2011 | liftmaster Garage Door 1/2 Hp
I have problem, with my door garage. it desn't
IF THE DOOR OPENS WITH YOUR REMOTE BUT DOESN'T CLOSE (AND WORKS NORMALLY FROM THE WALL BUTTON) THE PROBLEM IS IN THE SAFETY EYES - CHECK TO SEE THAT BOTH LED'S ARE LIT.
IF NOT CHECK WIRING POLARITY - CHECK FOR BROKEN WIRES - CHECK FOR ALIGNMENT AGAIN.
Sep 06, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Kibri Ho 9802 Lkw Commercial Garage Repair Center Nisb Logo
172 people viewed this question
Top Kibri Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Kibri Toy Expert? Answer questions, earn points and help others
