Question about ViewSonic VA1912wb 19" LCD Monitor
19" Sansung monitor
I would like to know how to configure the screen where it no longer stretches the image and disfigures things. How to adjust the image function, size function. The image and writing is stretched out. and can this be adjsted?
  • 148 Answers
You need to set the resolution to 1400x900, if this is not an option in the Display settings you should download the apropriate driver for you graphics card.  once you have ascertained  what make (nvidia or ATi), and model, go to one of the following for the latest drivers.
  • nvidia; http://www.nvidia.com/Download/index.aspx?lang=en-us
  • ATi; http://support.amd.com/us/gpudownload/Pages/index.aspx
After installation and reboot, you can then select 1400x900 screen size i the display settings.
Posted on Apr 02, 2009
Screen image is stretched or smeared
I had that problem, after awhile of using mine, the words would appear to be streaking. I bought a new monitor.
Feb 19, 2014 | Gateway FPD1975W 19" LCD Monitor
My Viewsonic 2235 monitor only shows the desktop top on 70% of the upper screen. It was fine and I ran Paretologic. When I rebooted, the screen images are egg shaped or stretched out side to side. ...
If you have an Auto Adjust option on your monitor, press that and it should adjust the screen to the correct size.
The button should be on the panel or it might be a setting in the monitor settings itself.
Hope that helps
Dec 15, 2010 | ViewSonic VX2235WM Monitor
How do I get my gateway fpd1975w tft lcd monitor to not stretch images images across the screen?
You need to make sure your computer's display resolution is set to 1440x900, which is the monitor's native resolution. Other resolutions will result in fuzzy displays or, as you're seeing, distorted images.
Right-click on an open area of the Windows desktop (that is, not over any icons), then select "Properties" from the pop-up menu. Click the "Settings" tab and you'll find a slider adjustment to set the resolution. If 1440x900 is not offered as a resolution, you'll need to upgrade your video card (or add a video card if you have a motherboard with integrated video). Most newer computers support that resolution, but some older systems may only go to 1024x768.
Thanks for using Fixya!
Oct 20, 2010 | Gateway FPD1975W 19" LCD Monitor
Monitor stretches the images. How is it possible?
you might just need to touch the resolution or else check if the monitor has right settings from its inbuilt menu.
Mar 17, 2009 | iiyama ProLite E481S-B 19" LCD Monitor
Sansung 915N no video
the monitor gets the wrong signal from the computer (refresh rate too high or scan rate too high )
check the screen refresh rate from Display properties / Settings tab / Advanced button / Monitor settings
worse case: damaged hardware
Nov 07, 2008 | Samsung SyncMaster 915N 19" Flat Panel LCD...
Stretched Image
The problem is just the monitor settings. To reset the monitor, just press the Select button (+) and Adjust button ( - ) on your monitor at the same time.
Oct 12, 2008 | Dell M570 15" CRT Monitor
Acer AL2216WBD LCD Monitor Problem
If your computer does not have a video card that supports the correct resolutions for the widescreen monitors, then your picture may get stretched. Much like watching normal tv programs on a an hd set. It will eitther strech or cut off the picture.
Try different settings in you computer display settings.
Fran
Sep 09, 2008 | Acer AL2216WBD LCD Monitor
Display appearing stretched
the original image size was probably recorded in 4:3 aspect ratio...meaning your widescreen is a 16:9 ratio size screen and is stretching it outwards to fill the whole screen. If you want the image to look normal.. ie. not short and fat people.... you need to change the picture size in the settings from widescreen 16:9 to normal 4:3 tv in the settings menu most likely...Also most remotes will/should have a button for that.
Oct 26, 2007 | ViewSonic VA1912wb 19" LCD Monitor
ViewSonic VA1912wb 19" LCD Monitor Logo
181 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
