Question about Seiko SKZ211 5 Sports Automatic Atlas Diver Yellow Hands Black Dial Watch
CRYSTAL FOR SEIKO ATLAS - Seiko SKZ211 5 Sports Automatic Atlas Diver Yellow Hands Black Dial Watch
Seiko instruction adjustment instructions day date
The crown ( the winder as used to be) will pull out one ,two, or three stops. Each stop does somthing different.e.g. 1 - hands, 2 - day, 3 - date. Sometimes, the second stop will do two functions - turn one way for day and the other for date.
Jul 22, 2014 | Seiko SGG713P1 Sapphire Crystal Analog...
Remove crystal of SNZH57
This isn't really a job for the DIY.. Best to take to professional
Sep 30, 2013 | Seiko SGF204 Wrist Watch
The gold trim box around the day/date feature of my Seiko 5 SNZH57 has come out. It now slides around under the crystal, and the hands catch on it. can I remove the crystal? Can it be replaced so it does...
You will need to remove the back of your watch and the movement to do this, don't remove the crystal... I usually just take the surround out but it can be glued back in place. Being a divers watch its best to get it done professionally so it can be resealed to ensure its water proof
Sep 30, 2013 | Seiko SNZH57K1 SNZH57 5 Sports Automatic...
SEIKO 7D48.... WATCHING SHOWING CORRECT TIME(WORKING PROPERLY).. BUT SECOND HAND NOT MOVING.
Second hand could be stuck against the crystal inside or it is slipping on the shaft. Both of these conditions can be fixed but the case back would have to be removed and the movement removed to fix this problem
Nov 05, 2009 | Seiko Kinetic watch
Where can I get a replacement crystal, and what is the part number? SEIKO SGF528
i get mine from castker. they have generic ones and all u need is the messurements
Oct 08, 2009 | Seiko SGF528 Wrist Watch
I need the movable ring on case front.It is like a diving watch with ring that has time markings on it around the crystal.
Seek the services of a watchmaker. If it's a brand watch i.e. Seiko, Omega,Rolex etc. look for an authorised repairer they are far more likely to be able to source the part and fit it for you.
Jul 19, 2009 | Watches
After replacing the capacitor in my 5J32-OAPO the
It is possible that the second hand is touching the crystal. However, this probably would have only happened if for some reason you remove the movement from the case and in putting it back in it now touches the crystal. If this is not the case, then I am assuming that you have pushed the crown all the way in. Please let me know if any of this works for you. I don't know of any reason that replacing the capacitor would only affect the second hand.
Jul 03, 2009 | Seiko Arctura Kinetic Autorelay #SNG067...
Seiko watch
the seals are starting to go in it. i will have to take it apart and replace them(or send it into the dealer)
Jun 02, 2008 | Watches
Seiko SKZ211 5 Sports Automatic Atlas Diver Yellow Hands Black Dial Watch Logo
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
