Question about Acer Aspire Computers & Internet
My Acer Aspire V3- 711g Says The Wifi Is Off And I Cant Fix It.
I had this problem and i had to go get a new bios from the acer website and install it
Posted on Aug 02, 2013
5 Suggested Answers
kbdesign
  • 370 Answers
SOURCE: Where the wifi botton on "Acer aspire 3004" is?
Think it is like the Fn key + F2 or F3.
Posted on Mar 17, 2009
SOURCE: im using acer aspire one za3 and cant connect to
The Aspire One is a great machine that, for me, was mildly crippled by a finicky Wi-Fi connection. There has been some discussion about this on other parts of the web. For some people, the actual wireless module turns on and off occasionally. For other people, the wireless connects and works just fine, but then won't work for a few minutes - but doesn't disconnect from the router. After a brief wait, the internet works again.
This was a bit frustrating. I had the problem of the module remaining connected but not working. Fooling with various settings helped, but it was still not as good as it should be, so I decided to replace the module with an Intel 4965AGN wireless module. This is the easiest fix for those who have this problem and have been frustrated by a solution. I say "easy," because it was easy to spend $35 for the module on eBay and install it, rather than spend another 3 hours fiddling with the settings.
I followed the disassembly guide here to take the keyboard and top panel off. This guide is great, and the author did a nice job with the descriptions.
http://www.aspireoneuser.com/forum/v...hp?f=40&t=1443
It was a really easy operation to crack the case open. I then removed the Atheros and replaced it with the Intel 4965 card. Here's where the easiness comes in.
If you look at that guide above, after installing the card, he has you removing all sorts of other parts just to run the new antenna wires. (The Intel card has three antenna jacks, the Atheros only two.) There is really no reason to do this unless you are really serious about having diversity reception. The Intel card will work just fine with only two antennas.
The antenna leads that you remove from the Atheros have the same connector as the Intel card, so just go with the two leads instead. Then you don't have to take apart your screen and all of the other tricky parts. Now, you won't get true Wireless-n without the third antenna, but reception overall seems better with the Intel card, and the Intel card does not get as hot as the Atheros. (Which is kind of nice, since the card is under your right palm. And actually, the Intel card does not get hot at all.) And you can connect to a Wireless-n device, which is not possible with the Atheros.
Also, the Intel card works properly with the hardware on/off switch. No problems there.
A couple of tips. Before you install the Intel card, remove the Atheros drivers and software from your AAO. You can use Add/Remove if you do this BEFORE you pull the Atheros card. Otherwise, Windows wants you to reinstall the card before you remove the drivers.
Also, when you take the AAO apart, use a credit card or other thin piece of plastic to push in the tabs on the keyboard. This saves you from scratches if you use a metal tool.
I hope these suggestions help anyone who is looking to do this easy mod. I wouldn't have added the new card if I had to go through the complete disassembly to add the third antenna, but this is not a necessary step. The new card completely solves the finicky internet problem. For some reason, the Atheros just does not work well with the Acer hardware.
Posted on Feb 23, 2010
  • 232 Answers
SOURCE: i cant turn on my
The Wifi Driver for your acer might not be installed
Visit the below mentioned link and install the WIFI Drivers and then you will be able to get connected
http://www.4hindisms.com/notebook-laptop/download-acer-aspire-one-d260-windows-xp-drivers.html
Posted on Dec 20, 2010
SOURCE: i cant enable wifi on my acer aspire one D260a
On the Aspire One D260-a .To turn on and off the wi-fi next to space bar press the fn button and press f3 and the light for the wi-fi on botton left will come on and do it again to turn off.
Posted on Nov 05, 2011
My laptop wont connect to my wifi just started a few weeks agto
Acer Wireless Not Working? - Easy Fix by Drivers.com
www.drivers.com/update/drivers-news/acer-wireless-not-working/
Jun 17, 2014 - In some Acer models you can use a combination of keys on the keyboard to ..... My acer aspire wont connect with wifi, it say windows cant connect.... I've just had a similar problem with my Acer Aspire laptop (wireless .... It is startedto happen just a month ago before it was ok I am using this since 6 months.
Acer notebook won't access the internet [Solved] - CCM
ccm.net > Forum > Network
Sep 17, 2014 - My Acer Aspire one series notebook says it's connected to my wireless... I know for a fact that my wireless is working fine, as my normal laptop is accessing it and ... it a while ago, sometime in Autumn 2010) but now it just won't work. ... 1) First make sure that you have configured the WiFi settings correctly. Can't get Aspire One D255 to connect to wifi [Solved] - CCM
Jan 15, 2015
Can't Access Internet-Wireless Working! [Solved] - CCM.net
Dec 19, 2012
My laptop Browsers won't connect to the web [Solved] - CCM
Oct 10, 2012
More results from ccm.net
wifi wont connect all of a sudden - Aspire - Laptop Tech ...
Dec 14, 2015 | Acer Computers & Internet
How to get wifi on acer aspire 1390 wireless
Acording to the Manual
http://www.manualslib.com/manual/1156/Acer-Aspire-1360-Series.html?page=7#manual
that is a 2004 unit the best way is to go to the Control Panel, click Device Manager, rt click the wifi adapter and update the drivers on line. (takes awhile) Microsoft will auto install the correct driver. If you cannot see the wifi in your device mgr. Purch a USB wifi adapter from Tigerdirect an install that. Should be able to fix for less that $25. If it still has Windows XP on this PC you should not be on the internet with it, it is totally vulnerable to viruses & hacking.
Aug 22, 2015 | Acer Aspire 1360 Notebook
I cant turn on my wifi on my acer aspire D260 laptop
Dec 20, 2010 | Acer Aspire One PC Notebook
How do i turn wifi on acer ast180-us340b
YOU CANT IT DOES NOT HAVE WIFI YOU WILL HAVE TO BUY A WIRELESS ROUTER.
Aug 14, 2010 | Acer Aspire (AST180-US340B) PC Desktop
I just put XP Pro on my Acer aspire 5050 and I downloaded all the drivers and my wireless internet will not work.
If You downloaded the correct wifi drivers and still didn't get wireless...
Choose a different series... Try acer aspire 3000 wifidrivers... then Acer Aspire 5000 wifi drivers, if still no luck... Choose the acer ferrari 3000 wifi driver.. or the acer travelmate 5530 wifi driver/..
I've had alot of Acer Aspire models.. including yours... and I too would have to jump around to different models to get all correct drivers,...
Dec 15, 2009 | Acer Aspire 5050 Notebook
Cant get wireless to work
if u knew how to open wireles card, then open it and clean wifi card using Pencil Rubber, then fix it back if still cant, rool back driver, if cant reinstall driver . if cant remove and Installl a new driver, then its should be ok
Oct 01, 2009 | Acer Aspire One Netbook 8.9" Notebook
How do I enable the wireless on my Acer Aspire one?
Open control panel scroll down to Internet connections and click to display. Right click wireless wizard then click choose enable. After this you will be prompted with a box that will show you that the computer has detected wifi connection in the surrounding.
Jun 22, 2009 | Acer Aspire One PC Notebook
Computers & Internet Logo
131 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
