What is the difference between a disk array and a disc enclosure?
    Master:
  • 951 Answers
A disk array has cache memory and advanced functionality
Posted on Jan 11, 2017
    New Friend:
  • 75 Answers
Posted on Jan 23, 2013
My Mac no longer recognizes the drives
Raid 1 mirrors the disks, but they are still in an array. You need to identify which disk of the two failed. Replace the bad one and let the unit rebuild the raid if it can. This could take hours. Independently, I have not found them to work alone. They need the built raid array. I lost a ton of pictures on a 4 drive raided array that lost one drive, even though they were raided mirror.
Best bet is to see if your manufacturer will guide you through the diagnostics and procedures to restore the array for that unit.
Nov 13, 2013 | Icydock Icy Dock MB662USEB-2S 3.5 Inch 2...
Format harddrive
What OS are you using?
In Windows, go to the disk management utility and see if the disk is listed. (In Win 7, this is Start > Control Panel > System and Security > Administrative Tools > Create and format hard disk partitions.) For XP and Vista, the directions are similar but do differ a bit. Look at the bottom of the window, to see the list of disks. (Disk 0 is your main hard disk; do not reformat this by accident.)
Assuming the disc is correctly connected to the enclosure and is seen by the computer, you should see it listed as a removable drive. Note: you may need to change the USB port. The MX100 is an enclosure for 3.5" hard disks and needs the AC cord plugged in as well.
You may want to connect and turn on the enclosure when the computer is off, then turn it on. Then turn on the computer. This will hopefully allow the USB drivers to note the new device.
For the Mac OS, look for the Disk Utility.
If you still don't see the drive, check that the cover (and plugs) are completely seated. (Turn off the enclosure first.) Try the hard disk in another enclosure or a USB/SATA hard drive adapter. (If you have a desktop with a free SATA data port and power connector, try connecting the disk directly to the computer. (You need to determine if the enclosure is faulty or the disk itself is bad.)
I hope this helps. Please add a comment with your OS and if you see the disk in the disk management utility, if you need additional assistance.
(This enclosure will work with older versions of Windows, back to Win98Se. However, I don't believe all of those versions came with disc formatting utilities. In that case, you would need a third-party partitioning software (Partition Magic, Paragon Partition Manager). If this disk was in another computer and you want to save the data, try copying the data before reformatting. This may be easier to do with the USB/SATA adapter or the direct connection to the motherboard of a desktop.)
Apr 17, 2012 | Antec MX100 Aluminum Hard Drive Enc e
My external hard disc buffalo HD-PE500U2 had a clicking sound when i connect to my laptop and it's says format disc,then when i start to format the drive it stuck and i can't control my computer,then i...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Feb 19, 2011 | Computers & Internet
Hi! i have an external hard disc Toshiba PX1396E-3T01. i've connected the divice to my pc but the red light doesn't turn blue but instead keeps on blinking blue. what's wrong?
* the USB cable
* the power-adapter
Dec 23, 2010 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
WD Elements DCM BCCBAAA not working how to fixes this? plug in and no light comes on cant fin d removeble disc either
* the USB cable
* the power-adapter
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
Dec 16, 2010 | Western Digital WD Elements Portable...
The 1 tb hard disc is not beign reconised by comp and producing sound
* the USB cable
* the power-adapter
Nov 18, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
Dear all, My toshiba external hard disc (640GB) is not working properly. the problem is that the disc is detected by the computer and i can see the data for first 5 minutes and after that light in the...
The device has four major components:
* the USB cable
* the power-adapter
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, to "check warranty status" -- if it is still under warranty, you can get a replacement, at minimal cost to you.
Nov 07, 2010 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
I pluged in usb to computer and nothing happens. it should automatically open hard drive. i looked for it under control panel -> admin tools ->comp mgt ->storage -> disc mgt. ...
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 04, 2010 | Hitachi 200GB External USB Drive 200 GB...
Is my hard drive broken? Cant get it recognised on other PCs
I'm having a similar problem with the same Akasa integral enclosure, so far I have tried 3 different hard disks and not one of them will work properly and on two different computers.. , all of the hard disks I've tried are Samsung .. but I'm sure that makes no difference. I plan to send back the enclosure to where I bought it from and get a different one from a different manufacturer.
Dec 10, 2009 | Samsung SpinPoint P120 SP2514N 250 GB IDE...
Array
I'm going to guess that your question is about hard disk arrays
There are several uses for arrays and there are different level of arrays
Here is a link detailing the levels and uses for hard disk arrays:
http://en.wikipedia.org/wiki/RAID_1#RAID_1
Jan 31, 2009 | Computers & Internet
Open Questions:
The Best Unlimited Online Backup and Cloud Storage Services Cloud backup, in simpler language also known as online backup, is a way to backup data by storing a copy of the data over Internet to secured cloud servers. Unlike the traditional ways to store data on local hard drive media the data is stored on cloud servers that are accessible through Internet. Cloud backup technology also help us retrieval of stored data on the go using a variety of devices all connected to the cloud servers. With Cloud backup, end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on Server Cloud Backup Solution their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software publishing companies choose to offer their products via the web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. All data is critical for businesses. It's a treasure trove of information. Problem is, they are drowning in it. Datalign provides a lifeline. We provide Cloud Backup For Small Business companies with a unique approach to backup, analyze and organize their data with the use of artificial intelligence Capabilities. Not all data file types should be treated in similar manner. Data may be accessed or stored depending on the requirement of the users; some users may want the data at their fingertips whereas others may want to store it for archival and compliance purpose. To rectify this problem with one solution, we have introduced the world's first Tribrid Backup. Without sacrificing any data, it enables businesses to protect all produced data and save storage costs. Our innovative platform has been designed while keeping you in mind. To provide Online Backup Pricing optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Our Cloud services are available on demand and always up and running. We ensure 99.9% uptime for our cloud services. This ensures un-interrupted data transfers and practically no downtime.
Apr 21, 2018 | VIA Computers & Internet
Computers & Internet Logo
641 people viewed this question
David Payne
David Payne
