What is a disk array? - Computers & Internet
    New Friend:
  • 75 Answers
It is a disk storage system that has multiple disk drives. hope this helps
Posted on Jan 23, 2013
How do I rebuild broken RAID 1?
If Raid is broken then logical drive will fail & will result in data loss.
enter into Smart Array Controller bios by pressing F8 & Recreate Raid 1 by selecting two working drives.
Nov 19, 2015 | HEWLETT-PACKARD Hewlett Packard HP...
Can my HP disk array withstand extreme pressure changes?
The HP test centers have run a whole host of crazy conditions. One was a test to see if their disk array could with stand the test of fire and decreased oxygen in the room the array is in. They found that even with reduced oxygen and the increased pressure from the pressure fire extinguishers the array was still able to function properly without problems. You can be sure with an HP that it will last almost anything you can throw at it. Although its recommended not to throw things at it.
Oct 17, 2013 | Computers & Internet
How do I set up my Dell MD32x0i disk array?
Dell has posted a really great set by step guide for setting up this storage array on their youtube channel.
What is the difference between a disk array and a disc enclosure?
A disk array has cache memory and advanced functionality
Jan 23, 2013 | Computers & Internet
A DRIVE RAID 0 VOLUME IS FAILING GENERATION 2
> RAID
Rapid Array of Independent Disks
RAID logically combines several identical disk-drives for better performance or for better reliability.
For better performance, one RAID configuration "stripes" the data, i.e., when you write a block of data, the block is split into "stripes", and each stripe is written to a different disk-drive.
Since each stripe is smaller than the whole block, it is faster to transfer the data in "parallel".
For better reliability, another RAID configuration writes each block of data _identically_ to multiple disk-drives. Thus, if one disk-drive fails, your data still exists on the other disk-drives.
You can then replace the "bad" disk in the array, and use software to "rebuild" this "mirroring" of your data, by copying all the data from one of the "good" disks onto the "new" disk.
So, in your case, one of the disks in your array is failing. Identify it. Replace it. Rebuild your array.
Sep 26, 2010 | Dell 500 GB 7200 RPM SATA Internal for...
Not getting a drive letter from Compaq SCSI RAID setup
Did you see any new drives in the disk managemen screen? To get to the disk management, hold window key down and hit 'R', then type diskmgmt.msc and hit enter.
If you do see the drive in the lower half of the screen, you need to initialize the drive either as dynamic disk or basic disk. Then you need to add a new partition and format it.
Good luck.
Jul 04, 2009 | Compaq (128293B21) (128293-b21) SCSI...
Array
I'm going to guess that your question is about hard disk arrays
There are several uses for arrays and there are different level of arrays
Here is a link detailing the levels and uses for hard disk arrays:
http://en.wikipedia.org/wiki/RAID_1#RAID_1
Jan 31, 2009 | Computers & Internet
Run Compaq Array Configuration Utility
Hi Foambob,
Try all means to get a smartstart CD.
Normally new version will be able to use on older hardware , but no guarantees.
I have always found it easier to use smartstart CD auto mode.
You can also do the install and then run ntssd to update all the drivers etc., but I don't recommend it for novices. Use the auto mode , it takes longer but safely and surely.
Good luck
May 21, 2008 | Compaq ProLiant 5500 Server
Problem with new array.
Do you see your new disk in the "Disk Management" window? To get there go to "run", type "compmgmt.msc", then click disk management. If you do see the disks there, then you need to format the disk to a "basic" configuration. If your new disk/volume does not show up there, I would suggest a hard reset on your server whenever possible. I see this issue at times with Windows and newly added storage array logical drives.
Aug 31, 2007 | IBM Total Storage DS400 (13n1777) Fibre...
Computers & Internet Logo
599 people viewed this question
David Payne
David Payne
