Question about GE WBVH6240F Front Load Washer
Troubleshooting after cleaning out filter strainer
Hello, saw your post about cleaning out the filter strainer. THANKS. That did work the first time. 6 months later, when we cleaned out the filter again, it now will not go into spin mode and just sits - wet soaking clothes. Any help would be appreciated on this one, as well. Thank you, Rick in phx.
  • rick molera Jul 23, 2007
    After wash cycle water does not come out from the machine. Do not hear anything but a high pitched whine.
  • rick molera Jul 24, 2007
    FYI - Fixed the problem: The drain hose was clogged with sand and dirt. After cleaning hose and blowing it out with h2o, all is well. Thanks anyway for trying.
  • 641 Answers
Do you hear if pump works or water coming out from the machine ?
Posted on Jul 23, 2007
There is no water going into the humidifier, make: Generalaire 1042
Hello, first thing is check is the strainer going into the solenoid valve for sediment, if there is clean the strainer and reinstall. If the strainer in clean the check if you are getting 24 volts to the solenoid valve, if you have voltage and the solenoid does not let the water thru replace the solenod valve.
Apr 09, 2011 | General Filters 1042-LH Humidifier
Hello, when i vacuum my inground pool using a hayward filter....it cleans the pool but the next day sand forms on the bottom of the pool...this was a constant problem last year....what may be causing this?...
If sand is getting back into the pool, the strainer in the filter is broken or out of place. The filter has to be disassembled, sand must be removed and the strainer must be inspected for cracks or leakage. New parts are available from most pool supply stores.
Gary
Mar 05, 2011 | Hayward SAND FILTER, PRO SERIES
Doesn't clean dishes, spray arms and filter look ok. Melted crayon in there a couple weeks ago?
Hello- This unit has a sump at bottom of tub that can get blocked, causing low or no water flow. Remove racks, water tube, and the accumulator cover to get to it. Clean the strainer and chopper screen. This should solve the problem. Let me know if this info helps- have more if needed. -Thanks- Ed
Mar 11, 2010 | KitchenAid 24 in. KUDI01FL - Multiple...
Clean light flashes off and on continually, nothing else works
Hello- This pump system has a strainer and screen that can trap debris against the pump blades, stopping motor. Turn off power. Pull torx screws holding pump cover and strainer. Remove and clean out debris. Check to see if motor turns. If not, it is locked up and needs to be replaced. Let me know if this info helps- have more if needed. -Thanks- ED
Mar 07, 2010 | Whirlpool 24 in. DU1100XTPS Built-in...
I have an 03 polaris 330 magnum 4x4 it worked fine than one day i had to keep the choke on to keep it running took carb apart cleaned all jets etc started it back up worked fine then it didnt put choke on...
Sound like the needle and seat are dirty. Also check the fuel strainer / filter for debris. Usually if the needle and seat are dirty so is the filter / strainer & bowl.
Needle and seat item(s) 24 and 24 original factory Parts manual under carb. at the dealer:
(called float valve in description)
Sounds like the float valve is either not closing or is dirty and not allowing carb to fill to the proper level. i.e causes fuel starvation AND carb over filling intermittently. You can clean the needle and still have a bad seat for the needle.
Find and replace or clean the fuel filter also. If your carb has a manifold and nut on the side of it for the fuel manifold remove the nut (actually a bolt type thing) and clean the strainer inside the manifold.
Thanks for using FixYa!
Kelly
Feb 13, 2010 | Polaris ATV
Hello, Kenmore Elite washer, doesn't drain properly.Leaves clothes full of water. We use the spin cycle quite a few times to get out as much water as possible. Where is the drain filter please tell me....
Hello. The drain filter, or strainer, is usually located at the bottom front of the machine, behind the kick panel. This is the small panel below the main front panel. Remove it and you'll see a hose coming from the drum to a canister. This is the strainer, and has a screw lid. Caution when opening this....There will be water. Be prepared.... Unscrew the lid, and remove the strainer and clean. If it is difficult to remove, try gripping the tab in the middle of the lid with pliers or channel locks to get some leverage. I always put a little silicone spray on the "O" ring and threads when I reassemble the strainer. This should solve your problem.
Best regards --W/D-- please feel free to rate this solution! Thanx!
Jul 30, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
NO START BENZ 190D
Hello I'm an M.B. tech.. It sounds like the fuel strainer is clogged. It is a very common problem on M.B. diesel engines of that era. Diesel fuel develops algea inside the fuel tank and after a period of time it clos the strainer. The strainer is at the bottom of the fuel tank where the big fuel hose attatches to the tank. The hose unscrews frome the strainer and then the strainer unscrews from the tank. There is a filter on the strainer that can be cleaned and reinstalled. In the engine compartment there is a small primer pump that is by the fuel rack inline with the feed hose from the tank. If you turn the knob(clear or white plastic) on the pump it will retract allowing you to use it as a hand pump. If when attempting to retract hand pump it is sucked back down and will not stay retracted that means you have a restriction in the line- your fuel strainer is clogged is the most likley problem. replace both fuel filters during repair for best results. Good Luck
Apr 14, 2009 | 1988 Mercedes-Benz 190
Asko W660 Quattro Front Load Washer - WATER INLET FAULT. Checked the troubleshooting guide, which recommends disconnecting the hose and cleaning the strainer in the water inlet of the machine. WHERE IS THE...
check the inlet valve solenoid there are three of them one might be o/c,also using to much soap can cause this or a coin stuck in the sump hose near the pump.the filter is in the valve but normally isnt the problem
Aug 28, 2008 | Asko Washing Machines
Washer will not pump out water and have cleaned the strainer
Depending on the specific model of your washer, probable culprit for "No Drain" with the strainer (filter) clean are:
  • stuck/defective drain valve;
  • defective drain pump/impeller;
  • kinks in or clog drain hose.
Please visually inspect/clean (and replace if needed) the above mentioned components.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 01, 2008 | LG Washing Machines
Soaking wet clothes
Harm, remove the lower panel and you will see the filter right in front. Unscrew the filter strainer and clean all the lint and debris. This machine has a pressure switch that won't allow a high spin if it detects water in the tub. Therefore you get these pauses and slow tumlbe. Try this and see if it's normal after cleaning the filter...Catriver...post back
Oct 10, 2006 | GE WBVH6240F Front Load Washer
GE WBVH6240F Front Load Washer Logo
108 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
