ASUS A8N-SLI Premium Motherboard
Problem for ASUS A8N-SLI Premium Motherboard
Power supply wont come on
By coralseablue on Jan 28, 2009
Hi I have just installed the new ASUS A8N-SLI Premium Motherboard and its not turning on, the power supply is not on, green light shows on motherboard . I am not using a atx power supply. Do you have to use the atx. What else could be the problem. All connections are connected. I am using a Titan III Power Supply.
Comments:
Jan 28, 2009
- I have double checked the titan III Power supply says its ATX 20+4p. and Its brand new. Could it be faulty power supply? What other reason could it be
Same Problem
Mar 10, 2009
-   Have the same problem, tested with another power supply. The green light on the Motherboard indicates that there is power but it just wont switch on. -   Guest
Solution #1
posted on Jan 28, 2009
Somewhat Helpful)
Mr-Sticky
Rank: Wiz
Rating: 81%, 30 votes
I've check and that board uses an ATX power supply. that is your problem. slap in an ATX and you'll be good to go. Please be so kind as to rate this answer thanks and good luck.
Comments:
Jan 29, 2009
- i would double check the connections between case and motherboard. It is possible that power supply is bad but check all connections first, then if you have access to another Power supply that u know is good, swap out and see if that makes a diff. let me know if this helps.and again good luck
Was this helpful?
Yes
No
Popular Solutions for ASUS A8N-SLI Premium
Questions and Unsolved Problems for ASUS A8N-SLI Premium
Do you recommend ASUS A8N-SLI Premium Motherboard?
Answer
Answer
asus pgsc mx-1333. i've format my pc but i dont have the sound drivers, graphics etc. Please help.... (More)
Answer
network adapter missing. I've checked the bios and it is enabled, but nothing shows in Device... (More)
Answer
Regarding the Acer Aspire 5810TZ-4657 what is the most powerful CPU it can be upgraded to, from the... (More)
Answer
prior military computer,has guardian security.how do I take it out?
Answer
display adapter drivers , need drivers, for onboard video in motherboard, have all others but this... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
