Question about Sony RDR-GX380 MULTI REGION DVD RECORDER FOR 110-240 VOLTS
Problems with DVD Sony RDR GX380 message unknown disk format
SOURCE: SONY DVD RDR-GX315
Turn off recorder. Hold the on/off button on the dvd player for a few seconds. until "CHILD LOCK" disappears. The child lock is now disengaged...Check page 37 in the manual (I found it online -- same thing happened to my player -- I just freed it)
www.manualshark.org/manualshark/files/4/pdf_6908.pdf
Posted on Feb 04, 2008
ginko
  • 19396 Answers
SOURCE: A Sony RDR-GX210 DVD player I can play a CD -
Hi Allan,
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
In your case the lens does not work on DVD , but only on CDs for the reasons above , that is quite common.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Posted on Sep 08, 2009
Testimonial: "Haven't tried it yet - but will let you know if successful thanks - Allan"
LoneWolf10
SOURCE: Dirty Disk Problem with DVD+R Disks on SONY RDR-GX300?
I have used my Sony GX300 for a couple of years and love it. I prefer +R blanks. The only occasional problem is the media brand. It will not record Fuji 16X, but will record Fuji 4X, which are rare nowadays. I have used TDK 16X with success, but this week bought TDK "lightscribe" blanks, and the GX300 would not record with them.
Sony should provide an upgrade download for the GX300 but does not. On the internet I have been unable to find a list of suitable brands for this DVD recorder, so I have to take risks when shopping. Fortunately, all blanks can be used for my computer so my money is not really wasted.
It's October, 2009 and in Toronto there has been a shortage of DVD blanks for months. I've been told there will be lots available in December.
Posted on Oct 11, 2009
  • 53 Answers
SOURCE: sony rdr -dc multi region code
Try this Site, may get you going:
http://www.ehow.com/how_5091093_change-region-dvd-player.html
Read Ya,
Z
Posted on Jan 02, 2010
  • 69 Answers
SOURCE: Sony RDR-VX530 DVD Recorder / VCR Combo - cannot format DVD+R
is it possible to record dvd+r?
is this machine not only dvd-R
Posted on Apr 07, 2010
Sony rdr-gx380 will not play any disc. always shows " no disc."
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD. If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor. Also in some cases the central motor base can shift and so the distance to the disc can be more resulting in low detection. You can pull up the spindle to come closer.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Nov 28, 2011 | Televison & Video
When I burn a DVD (R- or R+) on a Sony RDR-GX300 it burns the DVD which plays on that unit only. If I try to play the DVD burned on Sony RDR-GX300 on any other brand or any other Sony DVD player or even on...
On That Type Of DVD Recorder,( RW,R-R+). You Will Have To Finalize The Disk. Finalizing is Necessary When Playing On Any Equipment Other Than This Recorder.Even IF Your Other DVD Equipment IS ( VR ) Format Compatible You Still Need To Finalize The Disk. After Finalizing,You Cannot Edit or Record on The Disk,Make Sure It's In Video Mode.
Aug 11, 2011 | Sony RDR-GX300 DVD Recorder
My Sony RDR-GX7 dvd recorder keeps giving me a "disc error" message every time I try to play a disc. How can I fix this?
Hard to say because this could be caused by any number of things. You could try cleaning the optical read head but this could get very involved unless you use a cleaning disc which may not work. You could try different discs such as a CD to see if that still fails. It could be the disc format. If everything fails then most likely a repair is required. Go to https://eservice.sony.com/webrma/web/index.do and locate a SONY repair location.
Aug 07, 2010 | Sony RDR-GX7 DVD Recorder
Apr 07, 2010 | Sony RDR-VX530 DVD Recorder/VCR
I have an rdr-gx380 recorder that wont play back some burned dvd movies why
i want buy for fixing my CCTV....
RDR GX380 have any problume to do this?
Mar 13, 2010 | Sony RDR-GX300 DVD Recorder
DISC ERROR
it could be a region problem. most dvd players are locked on certain region areas..like America being Zone 1 and S.A being Zone 2. imported or diffirent format of dvd's usualy gives a disk error message. if you think it might be region try www.videohelp.com. they give hacks for region problems^^
Mar 30, 2009 | Sony RDR-GX300 DVD Recorder
Sony DVD/VCR combo recorder
possible chance the disk has not been formatted ..another chance the disk is damaged .....try with another new disk .......
Feb 05, 2009 | Sony RDR-VX515 DVD Recorder/VCR
Dvd recorder not formating after recording.
My Sony DVD recorder RDR-GX 350 not formating the DISK to enable me to record.What`s the problem with it? Thanks.
Dec 28, 2008 | Televison & Video
Sep 03, 2008 | Sony RDR-GX300 DVD Recorder
Sony RDR-GX380 MULTI REGION DVD RECORDER FOR 110-240 VOLTS Logo
54 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
