Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Front menu controls do not operate and volume creeps to maximum
I have a Sony 32" Trinitron the front menu buttons do not work. The volume creaps up to maximum and will stay there.
    Problem Solver:
  • 7 Answers
The push button on your tv its all busted i mean its not working so the first you do is to buy a contact cleaner WT40 and you can spray it in front of your panel area.
Posted on Feb 21, 2009
Need remote control code for sony trinitron KV-28LS35U
Hello
Here are some setup codes for Sony TV. Select one which will have maximum functionality. Check with all of them, and select one which can operated maximum function with tV. It is a trial process. If one stup code won't allow to some functions, try an other one, till you get maximum functions can be controlled with.
0128 0013 0002 0071 0380
002/ 006/ 071/ 128
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Feb 15, 2012 | Televison & Video
Cannot control the sound on my sony trinitron
hello,
Try this method : operate with remote. if still not working, try manually by pressing volume button on tv. If this still not working, and you have tools and experience with electricity equipment , i suggest you to open it.
In front panel , change volume switch. Change all switch if necessary.
If you doesn't have experiences in electrics, call technician for a better repair.
Good luck.
Mar 25, 2011 | Sony FD Trinitron WEGA KV-27FS120 27" TV
My volume on my sony tv wont go past 12 it will higher and lower but the maximum it will higher to is 12 have i maybe put a volume lock on it??
The only way the volume could be limited is if you were in the hidden tech menu----many of these sets have a setting there for initial volume level and maximum volume level.
Were you in the TECH menu for some reason?
I can tell you how to get in but you have to be very careful if you make any ADJUSTMENTS there--over 200 things can be adjusted there.
Let me know if I can help.
SD TECH
Feb 08, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The volume ramps to maximum. I can adjust it back
Sounds like the circuit board for the button keys in front has a shorted tactile switch causing sound to keep increasing, Replace all switches on this board or get new board. I believe it is called a HS board or very close to that.
Dec 30, 2009 | Sony FD Trinitron WEGA KV-32FS200 32" TV
Menu Screen pops up, try to exit and goes to video 1
This could be a stuck button on the front control panel or a bad solder connection on one of the switches on the front control panel.
Aug 02, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Verizon FIOS remote buttons all work except Volume. Sony Trinitron WEGA remote has to be used. Volume is Fixed. Can something be done to control volume with the Verizon remote?
I had the same problem with a Sony Trinitron KV-32FS320 32" TV. I reset the remote to factory default.
  • Press and hold STB
  • While holding STB, press OK
  • Release both keys, wait for device keys to blink twice
  • Press 9-0-0. The STB key will blink three times
Then I reprogrammed the TV control.
  • Turn your television on
  • Press STB to enter Set Top Box mode
  • Press and hold TV
  • While holding TV, press OK
  • Press 1-1-2-7. This is one of the Sony TV codes
After this, the volume + and - worked to control the TV.
  • Program any other devices, such as DVD using procedure similar to above.
I hope this works for you.
Apr 25, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv is stuck on channel 25
30 YR SERVICE TECH
THER ARE NUMEROUS THINGS THAT MAY HAVE CAUSED YOUR PROBLEM. TAKE IT IN TO A SONY AUTHORIZED SERVICER
Jan 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Buttons/ Remote won't operate TV
Defective tactil switch?? Remove tact switch control board.
unplug connector,use meter--check each switch.
If no problem found,leave unplugged overnight or longer.
Sony is famous for getting brain freeze!.........T.
Oct 24, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
No picture, stuck on Video 1, volume self-adjust to maximum
the tacticle (micro switches)on the front of the main chassis have most likely gotten wet at some time,I suggest replacing them all.
Apr 02, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony 36' TV Volume Goes up on own/Stuck on Video 2
There's a setting in the menu. I think it's called "smart audio". It's supposed to adjust the volume automatically for commercials. But I don't think it works that well. Give that a try.
Jan 09, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
59 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
