Question about Apple M8536 23" LCD Monitor
Apple m8536 monitor does not power on when using a dp800 with pr
I have a dual processor desk top dp800 with the combined vga-adc video card. Does anybody know of a possible incompatibility. Or maybe how to run some checks on this monitor even if it means opening it up just to be sure that it is in working condition. The card works when I use the vga section and a different monitor so I presume the card is good???
skotkolr
  • 558 Answers
SOURCE: I have power with my 23 inch apple cinema but no picture vga monitor works fine
pc and mac do not play nice together you may need another vga cable since mac may use different pinnout than pc monitors
Posted on May 11, 2008
smartr10U
  • 1305 Answers
SOURCE: my apple cinema display m8149 adc version i want
yep! just use an ADC to VGA adapter and you're good to go. Then set the resolution to suit.
Posted on Nov 27, 2009
MacAppleTech
  • 206 Answers
SOURCE: 22" Apple Cinema Display doesn't power on
This may be an issue with the display detecting the wrong video format or is using an unsupported resolution for this Apple Cinema Display 22"
Procedure:
• Make sure your Mac is turned off.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the start up sound for the third time.
• Release the keys and allow the Mac to start up.
If that does not help here is additional support reference from Apple regarding its LCD displays:
Apple Support Link:
Power Light Flash Issues
Let me know if this helps!
Regards,
-Mactechtrainer
Posted on Jan 31, 2010
MacAppleTech
  • 206 Answers
SOURCE: M8149 22
This issue is can be caused by loose cable connections or a loose DVI graphics card in the computer. Check cable connections and verify there are no bent pins.
Ensure that the DVI graphics card is securely connected in the computer.
You can also try this procedure with your Mac:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} -PRAM RESET -
Here are some steps you can try to resolve the issue:
• First, hold in your power button for approximately 10 seconds to do a hard shutdown, if you have not already turned your Mac off.
This should help with the freezing issue:
• Now, hold the keys down until the computer restarts and you hear the startup sound for the third time.
• Please update me to let me know if this works.
A PRAM is a good troubleshooting procedure for display issues.
If this does not work, this may be a genuine issue with the graphics card in your Mac, more so, than 2 monitor just burning out. You may need to take the Apple ADC 17" in for service, if the procedures above fails.
Reply back to this post if you have more questions.
Regards,
-Mactechtrainer
Posted on Feb 08, 2010
SOURCE: Use a M8536 Monitor on a PC ?
You need an apple adc to dvi adapter which can be found on ebay for around 80-100 dollars.
Posted on Nov 06, 2010
Dual vga displays
With some motherboards the on board Video is automatically cancelled out when a slot dependent Video Controller is present. Bios will not change that option. If you want to use two Monitors at the same time, get a DUAL Video out card.
Jan 18, 2014 | AMD Athlon II X2 Dual-Core Processor 260...
I have a g4 computer with s dvi and vga output i also have a m8536 monitior with one cable coming from it . what do i need to make it work
The "cable" you talk about is probably the power cable of the monitor. You will also need a VGA or a DVI cable to make it works.
Feb 28, 2011 | Apple M8536 23" LCD Monitor
Hello! I have a processor intel pentium dual cpu e2160 @1.80 Ghz and for display a graphic card NVidia GeForce 7300SE/7200 GS, DAC Type Integrated RAMDAC 512 mb. I use my VGA monitor connected to the...
Hello ghinea18, sorry you can't do that because this will cause hardware conflict, that's why motherboard bios automatically disable integrated graphics if you install video card using pci express x16 slot - Nvidia GeForce 7300SE. do you know if your video card has dual vga or dual dvi connection?
You can try dual display, im not sure if this card supports dual monitors because nvidia online specs does not show full specs on 7300se series. \
Good Luck!
Nov 24, 2010 | Computers & Internet
Apple Cinema display goes BLACK after start-up
My G4 has a ADC & VGA on the same card. The VGA works but the ADC, is doing the same thing as you described. I am searching the web, and can not find an answer to this problem. George 3/21/2010
Aug 03, 2009 | Apple Cinema Display Flat Panel Monitor...
How can I use my apple lcd monitor (model m7649) to my dell
here you need to do:
1) you need find a video card with a DVI port and analog output ports, upgrate this card in your destop if you can not find a DVI port at your destop.
2). then you need buy a ADC to DVI adapter because your monitor ADC port is a digital port. you may reference here:
http://store.apple.com/us/product/M8661LL/B
and you can buy the parts at:
http://shop.ebay.ca/items/?_nkw=dvi+to+adc+adapter&_sacat=0&_trksid=m270&_odkw=adc+to+dvi+adapter&_osacat=0
hope help you fix it. please take a rating let me know huw much helped you thanks!
May 19, 2009 | IBM (14R0060) Monitor
Mar 22, 2009 | Apple Televison & Video
Add a 22" Apple Cinema Display to an Ibook G4
use the video toggle key to transfer the picture to the cinema screen..
Sep 21, 2008 | Gefen ex-tend-it The VGA to ADC Conversion...
Switch to alternate 2 computers and dual monitors
What you probably want is a KVM (Keyboard, Video, Mouse) switch that supports dual monitors. It's a simple device that allows you to plug multiple computers into one set of monitors, keyboard, and mouse and switch between controlling them.
I don't know of any that support mixing analog and digital connections for the monitors, but using a VGA to DVI adapter for one of the monitors should solve that problem cheaply.
Dec 14, 2007 | Computers & Internet
Computers & Internet Logo
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
