Question about Microsoft Windows Server Standard 2003 for PC
Intel D945GCZ board / RAID1 / Server 2003 cannot see array
I setup a mirrored array in the intel RAID setup and the status is OK. I then downloaded this driver: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=2063&DwnldID=15251&strOSs=All&OSFullName=All%20Operating%20Systems&lang=eng
It loads IaStor.sys and continues but then says it cannot see any disk to install 2K3 onto?
Any ideas?
  • 20 Answers
Here is a link for a driver that supports server 2003 , the one you had did not
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProductID=2101&DwnldID=17269&strOSs=84&OSFullName=Windows%20Server*%202003&lang=eng
Copy & Paste into address bar
hope tis helps
Posted on Feb 15, 2009
Drive replacement and rebuil ding Raid 1 on a Dimension XPS Gen 2
Hmm,tricky, I think your best bet would be to save old drive and do a complete new programme install hopefully you have the discs, then once setup and running, connect old drive as a backup and transfer data you require, there may be a better way, this is what I would seriously consider.
Mar 07, 2014 | Dell Dimension Computers & Internet
Can't see drives outside of raid
You may not be able to boot you drives outside of a RAID array depending on the RAID type (software/hardware) and configuration (RAID0/1/5). Generally a mirrored RAID1 should be bootable off of the RAID array. If you are using software RAID or a RAID0, you best bet is to update the RAID firmware, and if the data is accessible at all, transfer the data to another storage device.
Jan 24, 2012 | SuperMicro P8SC8 Motherboard
I need a diagnostic tool for RAID falure code 0. Initial boot indicates degraded condition. DISK scan does not seem to remedy the issue. Did the drive actuually fail? Is there a fix? Primary disk still...
It looks like you have two arrays here. The first one being a mirrored RAID array and has only one disk. This means that the other disk has failed in some sort. This does not mean that the drive is bad, just the RAID failed for some reason. You will need to rebuild the RAID if you want to maintain the same level of redundancy.
You can just attempt a rebuild the RAID to the same drives but if this fails you will want to replace the bad drive. In order to do this you will need to make sure you can tell which drive is which. You do not want to mirror the bad drive to the good one.
If attempting a rebuild to the existing drive does not work or is not an option (because the failed drive could really be bad), you will need to determine which physical drive needs to be replaced. You may be able to hot-swap the drive but if you can power things down, that is always safest. Once the new drive is installed, you can rebuild to it and all should be well after that.
Jan 04, 2011 | Dell Dimension 9100 PC Desktop
I upgraded matheboard from p6t6 (stopped working for some reazon) to p6t7. My hard drives have been set up to raid. I have windows 7 ultimate installed. I set bios to raid and choose proper disc as boot 1...
On many systems with RAID1 support built into the mobo chipset, that system includes some RAID management software in BIOS. You won't see it until you turn on RAID capabilities in the BIOS and add a drive. But you might find all the details you need in manuals on the matter from Dell, so look for those. They could have come with your machine, or you may have to search their website and download.
On systems I've seen you create and manage RAID arrays using that built-in software, NOT Windows tools. In fact, some RAID1 management tools would allow you to convert a single stand-along HDD to a RAID1 array by adding a matching HDD unit and then having the system copy all the data to the second drive. This is almost the same as the process to repair a damaged RAID1 array by replacing one faulty drive with a new one and rebuilding the array.
HOWEVER, Windows ALWAYS needs a RAID driver installed in it to use any RAID array. If you are simply booting from a "normal" stand-alone disk into Windows and then using a RAID array as a data storage system, the RAID driver installation can be done any time after Windows is running as you set up the new storage system. BUT Windows in ANY version cannot BOOT from a RAID array unless the RAID driver has been installed at the very beginning of the OS installation. This implies that, if you want to convert your single disk into a RAID1 2-disk array and use ONLY that as the HDD resource in the machine, you will need to re-install Windows, this time including the required RAID driver install at the beginning, in order to boot from that array.
I have read that there may be ways to convert a non-bootable RAID array into bootable by some complicated editing of Windows registry and boot files in order to force it to load the right driver at the right time from the right spot on a HDD, etc. But I am not SURE that would work. It's definitely for the adventurous knowledgeable techie.
So here's a quick guide to installing hardware RAID on a motherboard that features a RAID controller. These steps assume you are performing a clean Windows 7 install rather than an upgrade, and they might differ depending on your system set-up, but the general principles should be the same.
  1. Download the RAID drivers for your motherboard from the manufacturer's website and save them to a memory stick.
  2. Back up all your important data!
  3. Turn your PC off and unplug it.
  4. Install 2 hard disks preferably with identically capacity into your PC.
  5. Turn on your PC, press the delete key or F2 key when prompted to get to the BIOS menu.
  6. Find the option to select the RAID mode, save your settings and exit BIOS.image.axd?picture=bios-raid-options.jpg
  7. On reboot you should see a new menu option to enter the RAID controller settings. Enter the key combination when prompted to get to the RAID controller menu. image.axd?picture=amd-raid-menu.jpg
  8. Create a new RAID array selecting either RAID 0, or RAID 1.
  9. Select the disks that will form the array, save the settings and exit.
  10. On reboot press the delete key or F2 key when prompted to get to the BIOS menu.
  11. Check the boot sequence of your PC and ensure your optical drive is top of the list.image.axd?picture=bios-boot-sequence-options.jpg
  12. Insert your Windows 7 disk into the optical drive and exit the BIOS.
  13. On reboot press any key when prompted to boot from the optical drive.
  14. Windows 7 should start installing.
  15. Select your localisation settings and click next.image.axd?picture=localisation.jpg
  16. Click "repair your computer" and click the "load drivers" button.image.axd?picture=windows%207%20repair%20menu.png image.axd?picture=load-drivers-option.jpg
  17. Insert your memory stick and browse to the correct driver and install.
  18. Exit back to the Windows 7 install menu click "Install now" and on the next screen click "Custom (advanced)" to perform a clean install.image.axd?picture=install-windows-custom_thumb.jpg
  19. When you are asked where you want to install Windows 7 you should see that the 2 RAID hard disks are now visible as just 1 drive.
  20. Add a partition to the new drive so Windows with be able to recognise it.
  21. Continue installing Windows as normal.
Dec 04, 2010 | ASUS P6T7 WS Supercomputer Core i7 / Intel...
What is intel(R) matrix storage manager
Yes you need it. document.write("The files below contain the Intel® Matrix Storage Manager.
This driver provides support for high-capacity & fault-tolerant Serial ATA (SATA) RAID 5 arrays and high-performance & fault-tolerant SATA RAID 10 arrays on select Intel® 5 Series, 4 Series, 3 Series, 965, 975X, 955X and 945 chipset-based platforms. It provides support for high-performance SATA RAID 0 arrays & redundant SATA RAID 1 arrays on select Intel® 5 Series, 4 Series, 3 Series, 965, 975X, 955X, 945, 925, 915 chipset-based platforms. It also provides AHCI support on select Intel® 5 Series, 4 Series, 3 Series, 965, 975X, 955X, 945, 925 and 915 chipset-based platforms, as well as on Mobile Intel® 915/910 chipset-based platforms.
Note: Intel® RAID Technology requires the Intel® ICH9R/ICH9M-E/ICH10R/PCH/PCHM SATA RAID controller hub, Intel® 82801HR I/O controller hub (ICH8R), Intel® 631xESB/632xESB I/O controller hub, Intel® 82801GR/GH I/O controller hub (ICH7R/DH), Intel® 82801FR I/O controller hub (ICH6R).
DISCLAIMER: This software is provided by Intel only for the convenience of its customers. THIS SOFTWARE IS PROVIDED \"AS IS\" WITH NO WARRANTIES WHATSOEVER, INCLUDING ANY WARRANTY OF MERCHANTABILITY, NON-INFRINGEMENT, FITNESS FOR ANY PARTICULAR PURPOSE, OR ANY WARRANTY OTHERWISE ARISING OUT OF ANY PROPOSAL, SPECIFICATION OR SAMPLE. This software is furnished under license and may only be used or copied in accordance with the terms of the license. The software is subject to change without notice. Intel assumes no responsibility or liability for any errors, incompatibility issues, inoperability or inaccuracies that may appear in this software.
See the Installation Instructions page for a list of system requirements and considerations.
Note: Before installing this application or requesting technical support from Intel, it is suggested that you first contact your system manufacturer. They may provide software which is specifically configured for your system.")The Intel® Matrix Storage Manager.
So don't delete it.
Mar 10, 2010 | Computers & Internet
A well meaning~idiot teenager changed my set up on my Dell Dimension in BIOS to Intell ARRAY.. now I cannot bring Windows up
If the well meaning teenager took a non-raid configuration and created a RAID array, then any data on the drives was destroyed.
If you reply with the RAID array and HDD status information from the boot screen (THE intel Raid Controller will report the status of the array, degraded, normal or Failed and the status of each HDD member or non-member disk.) With that information I MAY be able to assist in getting the system to boot
Mar 01, 2010 | Dell Dimension E510 Dual Core 2.8 Ghz...
Intel d945gcz mobo cannot setup Winxp pro, (reboots)
Have you tried going into BIOS Setup, and in Boot Options, change the first boot device to CDROM?
Do you have the Motherboard Manual for your Intel D945GCZ?
This is Intel Support, and the download page for the Motherboard Manual.
It is a PDF file.
http://www.intel.com/support/motherboards/desktop/d945gcz/sb/CS-020793.htm
Sep 26, 2009 | Intel D945GCZ Motherboard
Can I add additional drives to Raid 1 in order to expand storage?
I am not familiar with the specific model, but my guess is you can setup another separate logical vlume by using a RAID1 for the new disks. You will not be able to add the disks to the existing volume.
If there is no data, and the array supports it you can delete the existing volume and setup a RAID 5 instead, which will use all 4 disks, as long as they have the same capacity.
Apr 22, 2009 | Intel SS4000-E (SS4000ENA)
Poweredge 1600sc cant see other 4 drives
HI thanks for reply. i must say im new to this raid stuff. i was given the server by my coworker because he could not get the other drive to show in windows. he got fustrated and gave it to me. so i tey at home. ok here is what i have.
Dell poweredge 1600sc. it has two gig ram. I open the case andther it has one primary hdd and four other hdd connected on one ribbon to the board. it had windows server 2003 all ready on it. I was in the set up (ctrl +m) and i saw the drives say ready. i hit the space bar to set array. after i did that it say i had to initlize it before i reboot. now the drives say online. i boot into windows and the drives are still do not show. am i looking in the right place. i know. im stupid. go ahead and laugh.
plus is there a good place to lean this raid stuff. thanks. nezza
Aug 05, 2008 | Dell PowerEdge 1600SC Server
Intel SDS-2, 64-bit
check the Bios Setting and enable the SATA & Raid support in the Setup Utility.
Jan 03, 2008 | Intel Server Board SDS2 Motherboard
Microsoft Windows Server Standard 2003 for PC Logo
97 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
