Question about HP LaserJet Pro P1102W - printer - B/W - laser
Gray streaking on paper from HP Laser Jet P1102w
The paper prints but there is a layer of gray lines on the sides and down through the middle. How do I fix it?
  • 39 Answers
SOURCE: HP 2600N dark gray line down the left side
Maybe your transfer belt is damaged. If u have an spare belt replace it for a test. Answer me if it dont work. Maybe i can get an support manual for u. I work in a HP partner company.
Good luck
Posted on Dec 15, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Hp laser jet 1020 paper jam and not printing
REmove cartridge, and open rear door, might be all scrunched in very back fuser unit, if you can't remove it without damaging the rollers then it will need to be pulled to bits
Posted on Dec 27, 2007
SOURCE: HP 2600n gray background darkness throughout paper
Ehh, after futher reading it seems, as long as the EBT is not physically damadged, it is fine. So it all points back to the fuser. Ebay for $75 genuine HP.
But for others, just to rule out anything simple, disconnect from computer, and reset to factory defaults. Print Demo page. If still looks ugly, nothing to loose, run the service menu cleaning option, basicly heats the fuser very hot and passes a paper very slowly to catch any excess toner. I have never seen this cleaning option help but you never know. And if your print still looks like ****, you can save your beloved slow printing laser jet, replace the fuser.
Awsome instructions...
http://h20181.www2.hp.com/plmcontent/NACSC/SML/results.htm?SID=446153&MEID=B67763C2-AD42-45FD-B0E6-7D5998FCE86D
Posted on Nov 03, 2008
ODCaloney
  • 260 Answers
SOURCE: HP Color Laser Jet 2550 I want it to print in duplex
I believe you are being referred to the "Users Manual"
Do you still have the book that came with it?
Posted on Mar 13, 2009
pdouglasss
  • 125 Answers
SOURCE: hp laser jet 2430 dtn prints lines on left side of paper
Hi Karent503:
It sounds like you fuser assembly is worn. The part on the fuser assembly that you are having a problem with is the heat roller assembly located in the fuser. You can have a technician replace that for you at you local HP repair center, Her is the part number for the fuser assembly.
Fuser, 110-127 V RM1-1401-000CN
Posted on Apr 03, 2009
Tip
How to print a configuration page from an HP LaserJet P1102w
The HP LaserJet Professional P1102w is a compact wireless desktop printer. It is very easy to set up and use. Unlike larger HP printers, the P1102w does not even have a true operation panel; it only has a power button, a cancel button, and a wireless button.
However, like just about every other HP printer, the P1102w has the ability to print out a configuration page that displays many of the printer's settings and statistics. This page is called the self test / device configuration page, and on it you can find the printer's page count, number of paper jams (broken down by section), amount of available memory, network settings, and more.
To print the device configuration page, make sure the printer is on and ready. The green light on the top left side of the printer should be lit. If the red light is lit or flashing, then there is a problem with the printer -- such as no toner or a paper jam -- and you won't be able to print the configuration page until the problem is rectified. You'll also need to have at least one sheet of paper loaded into the paper tray. Make sure the two side fences and the rear fence are snug against the paper to prevent misfeeding.
Press and hold the cancel button (the button with the red X on it) for about four seconds. The printer will warm up and begin making noise, and the green light will start to flash -- when these two things happen, you can release the cancel button. The printer will print out the configuration page, face down, and once it has finished the green light will stop flashing and the printer will quiet down.
on Jun 11, 2011 | HEWLETT-PACKARD Hewlett Packard P1102...
Reset paper jam error HP P1120w
i have a hp p1102w laser jet, it's about a year old. Hp want 130 replace it, I only paid 100 for it. I have a blinking red light. It tell me paper jam, I can find no Paper that would make the jam. After two day we looked at it again, when we turned it back on it said out of ink. I knew that was no true, because I had just put new ink in it. Now it's back to paper jam. What do I do? Does anyone have any ideas?
Jun 02, 2012 | HP LaserJet Pro P1102W Printer
I get a streak down the middle of every page that prints. I have tried cleaning the printer, even tried replacding the cartridge, but still the same persistant streak, on every page all the way from the...
If the streak is like a thin double image line, or the print feels like it rubs off then it is coming from the fuser film. The fusing units are fairly inexpensive and not hard to replace but if you have to have someone do it for you then it might be just as cheap to get a new laser printer.
Look at the exit section of the printer where the paper comes out. The fuser film is a grey "roller" that sits on top of an orange roller. If you can see the grey sheet you may be able to see the defect line in the middle of the sheet that is causing the line.
Good Luck
Jan 07, 2010 | HP LaserJet 6L Printer
When printing 2 sided sheets our machine puts dark gray streaks on the paper after printing more than 6 pages. The streaks continually get larger until they cover most of the page.
When you are printing 2 sided sheets the reason you are getting streaks, is your first sided not dry yet. I know it is a laser printer, even laser you have waite a bit.
Dec 03, 2009 | Xerox Phaser 7700 Laser Printer
Balck and white streaks on left side of paper
Usually if there are streaks you need to change the pcu that is the same color as the lines. If the streaks are gray it also could be the fuser, but i would think it is the pcu.
May 18, 2009 | Ricoh Aficio CL3500N Laser Printer
Brother 1440 laser printer. Started printing with
may some dust in corona ware or drum clean the drum.
Apr 06, 2009 | Brother HL 1440 Laser Printer
Lines down both the left side of the printouts.
good day,
this usually occurs when you print large volume of copies of documents that goes beyond the printable area of the paper, some powders stick in the roller of your printer hence making the gray streak.
you can check if the rollers have accumulated some powder, if so, have the rollers cleaned.
i hope this will help.
Oct 14, 2008 | HP LaserJet 4L Printer
Xante CL30 printing streak line in middle of the paper
make sure there is nothing on th belt of the unit
Oct 25, 2007 | Xante CL30 HSE Laser Printer
HP LaserJet Pro P1102W - printer - B/W - laser Logo
329 people viewed this question
Seeker5211
Seeker5211
