Benson airconditioner fault codes
Flashing light
Panasonic power light flashing air not cold blowing
hi there you need to see where you bhave a gas leak thats all the flashing light indicates that your gas pressure is to low to activate your compressor
Dec 09, 2013 | Panasonic Heating & Cooling
My a airconditioner has both operation and timer flashing at the same time.there is no fan working on the outside unit there is no cold air coming inside.is this something to do with the control
I have one that the operation light flashes 7 times and the timer light flashes 2 times. Error code says Discharge pipe temperature error. Is there an easy fix?Thanks!!
Jan 19, 2011 | Fujitsu Heating & Cooling
I have a Haier split airconditioner HSU-22HD03, it runs for 5 minutes and then switches off and the power and timer light start flashing.
It shows your indoor PCB faulty. (As you didn't mention any error code). Next time count the green light flashing and write.Thanks.
Jan 11, 2011 | Haier Heating & Cooling
Can't get airconditioner to work
Hi
Try to reset the unit by disconnecting the power supply for 10sec. and operate the unit. If wont work then there are some safety device that work or defective. Try counting the blink of your green light so that I can convert the error code.
Dec 25, 2008 | Heating & Cooling
New airconditioner (installed 5 days ago) not working. Turned it on for first time (after installers's demo)yesterday, left the room after it had been running about 30 min. Returned within 10 min to find...
do nothing on a brand new unit but let the installer or service tech fix it for free, if you go messing with it you may camoflouge the real problem and when the repair tech arrives he wont be able to observe the actual cause or fault and it will do it again after hes gone and you'll be back to square one. please don't touch a thing till the tech arrives and gets the chance to see it broken and use his tools to determine the problem. good luck.
Dec 05, 2008 | Panasonic Heating & Cooling
TURNED OFF AND 5 WAY LIGHTS ON AIRCONDITIONER FLASHING, WON'T TURN ON
1.check selector switch.
2.wiring.
3. check cirkit board of aircondition
Jan 29, 2008 | Heating & Cooling
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
