Question about Canon Office Equipment & Supplies
Canon iR2525 copier showing E001 code
The problem started from a faulty power cable connected to a power outlet.
SOURCE: Canon 850 E001 Error
I entered service mode and it fixed itself.
With the front panel open and the copier lid/carriage lifted up, I used a paperclip and stuck it in the small hole on the center of the front grey panel (the covering of the DC controller) . I simultaneously used a pen to hold down the tab in the slot on the lower left edge that makes the copier think the lid is down...then I hit the power button. It reset the error code and all is OK now.
Posted on Apr 24, 2008
  • 9 Answers
SOURCE: canon iR2016
most times eoo1 can be reset in service mode if there is no damage to fixing unit. 1) Enter service mode.
Press the operation panel user mode key, 2 key, 8 key and user mode key in this order.
2) scroll to "clear" and press ok then scroll to "err" and press ok.
if that does not work you can go back into service mode as above and instead of scrolling to "err" scroll to "all" and press ok. power off then on. doing this will clear settings service techs might have made but i've done quite a few and had no probs
Posted on Jun 14, 2008
SOURCE: canon copier iR2016
My Canon copier IR2016 Problem code E007 Solve the problem pls
help me
Posted on May 06, 2009
SOURCE: Error Code E007-01 on Canon CP-200 Copier
Fixing Assembly needs replacing.
Posted on Sep 15, 2009
  • 109 Answers
SOURCE: i have canon ir6570.its shows e001-001,e001-0010
try to clesr the err. from service mode ( * 2,8 * ) function - clear- err- press ok
if not ok
you have a problem in the fixing unit
Posted on Apr 01, 2010
How to fix the Canon Image Class Printer 4750 error code e001-0000
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
for more details : www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
Jan 04, 2015 | Canon Office Equipment & Supplies
Ir 3300 000001-0002 error
Title : E001 Error Code That is Not Resetable Error : paper jam
When the machine powers up the E001 error code is displayed but cannot be reset. (Note: The reset procedure for an E001 code is COPIER>FUNCTION>CLEAR>ERR)
Workaround :
In this case, the Main Power Supply PCB Assembly was replaced. The machine was powered up and the E001 code was able to be reset. The part number for the Main Power Supply Assembly is FM2-0260-000.
Remember, if the fixing unit circuitry has an open or a short, the code may not reset. Be sure to confirm the fixing unit wiring and try resetting the code before replacing the Main Power Supply Assembly. Canon USA, Inc. Systems & Technical Support Division1-800-528-2830
Aug 13, 2013 | Canon Office Equipment & Supplies
Ihave canon 400 problems. e051, e901, e805 problems frequently please suggest me
by the look at your problems:
E051 - Horizontal registration sensor problems
E001 - Fixing temperature faulty
E805 - The Fan rotation problems
It can be that You have problems with DC contoller ( main pcb ) or the copier is in worst condition and there are faults on every segment.
For E001, you can try to reset error:
1. The following error codes cannot be reset by merely turning off and then on the main power.
They require resetting in service mode:
E000, E001, E002, E003, E004, E032, E717
1) Start service mode, and select COPIER>FUNCTION>CLEAR>ERR.
2) Press the OK key.
3) Turn off and then on the main power.
2. Error codes other than the above may be reset by turning off and then on the main power.
n Detail Code
Some error codes offer detail codes, which may be checked in service mode:
COPIER>DISPLAY>ERR (3rd block from the right)
BUT I THINK THAT THE BEST SOLUTION IS TO CALL SERVICE TO RECTIFY THE PROBLEM OR YOU BUY NEW MACHINE:..
Hope that helps!
Jul 22, 2011 | Canon imageRUNNER 400S Copier
My Canon copier, Model IR 400s, Shows the error code : E 604. What is the problem ? How can I Solve it ?
My Canon copier, model IR 400s, Shows the error code : E604. What is the problem? How can I solve it ?
Sep 25, 2010 | Canon imageRUNNER 400S Copier
E001 error code on canon ir400
the fixing assy is faulty the halagon lamp has blown. this would have to be replaced and the error to be reset in service mode this requires a technician.
Sep 21, 2010 | Office Equipment & Supplies
Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
Jan 19, 2010 | Canon imageRUNNER C3200 Copier
E001
you may want a tech to do this.
E000, E001, E002, E003 CODES
To reset these codes perform the following:
Remove the front panel and be careful not to bend or break the flexible
cable connected to the panel and the DC Controller.
Turn on the copier and short the jumper wires JP3 and JP4 on the dc
controller pcb with a screwdriver.
The count ratio indicator on the control panel turns on 'F'. When 'F'
is turned on stop shorting the jumper wires
Turn off copier and turn it back on and its then reset.
Jan 01, 2010 | Canon NP 6050 Copier
Canon imagerunner c3220
Were the heaters at fault. It is more like a thermister problem. Replace the thermisters, both. And I would also change the thermostat as well. When you are sure thatyou have removed the faulty unit reset by doing the following.. service mode/copier/function/clear/error followed byswitching the machine off and turn on again.
Oct 31, 2008 | Canon imageRUNNER C3220 Color Copier
Canon 6025
"E001" Abnormal fuser temp. (thermistor, dc controller, ac driver)
Nov 17, 2007 | Canon NP 6551 Black and White Copier
37 people viewed this question
old marine
old marine
