Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Blue convergence problem
My tv has a blue convergnce problem. the blue "ghosts" and this was sudden. I cannot correct it using the remote. It is a panasonic pt-53tw53g. any ideas where to look on the boards for blown resistors or other things. thanx a bunch, Rick
    Problem Solver:
  • 6 Answers
You lhave a problem with the convergence IC that control the blue but for the description you made it seems you have no even a slight idea about electronics then my best recomendation is do not mess with it & get some body that does it for you because trying to save some bucks may be costly if you make a mistake think about it
Posted on Feb 08, 2009
Blue image is ghosting and not lining up with other colors. Perfect focus is on but with "no sensor data" message at top
The tv have a problems known as a convergene problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergnce board,must be replaced to solved the tv picture convergence problems.Can u do basic things like take things aparts and install another things into it placed?Yes?Try website like Tvrepairworld.com to buy a whole refurbish convergence board for the replacement.The DLP tvs Samsung/Akai tvs used the same convergence board.Or the shop,will cost u like $300-350 for parts and labors.
Jan 14, 2011 | Samsung HCL4715W 47" Rear Projection...
Blueish hue throughout picture, like a blue ghost a couple of inches to the right of objects on the screen
Your TV's Convergence may be out of line. To adjust this do the following.
1) Press the Menu button on your TV/Remote
2) Scroll through and select the "Advanced Features" Menu.
3) Select Blue Convergence
4) Use the V keys on your remote till the cross hairs are all lined up in the middle of the screen and the center one is white.
4a) You can use the "Video" button to switch between the red & blue cross hairs.
Dec 28, 2010 | Mitsubishi WS-55809 55" Rear Projection...
My has a double picture with a red ghostly picture in the background. Any information on how to fix the problem? I have changed the cables, viewed the different colors, tv input, and looked over the menu....
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergnce select that and wait a minute the TV will adjust itself and give you a clear picture.
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the curser (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It taked time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synch.
RPTV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.Please run the convergence feature on your TV. Its giving you duble image because the red, green, and blue guns are disaligned. By running convergence it will realign the guns properly. You need to run the convergence feature at leat onece a week. Please note this is only for CRT rear projection tv's and I assumed it was. If it is an LCD rear projection, then there's nothing you can do to fix such thing, but call a repair person. But if doing the convergence doesn't fix the problem, you need to call a repair person. But I hope you won't have to. Please refere to your tv's manual on how to do converegence and how to overlap the crosses because every CRT projection tv is different.
Good luck
Oct 15, 2010 | JVC AV-56WP30 56" Rear Projection...
We have 52 inche akai and it shows double inmage
This problems is known as a convergnce problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergnce board,must be replaced to solved the tv covergence board.To solved the tv picture convergence problems.Try website like Tvrepairworld.com to buy a whole rebuild convergence board to replaced.The Akai/Samsung tv used the same convergence board.
Sep 15, 2010 | Akai PT5492S 54" Rear Projection...
We have an 80's hitachi mts 52" tv/ monitor and it has a 3d effect how do we fix this?
Tv have a problem known as convergence problems,it dead.Tv R,G,B colors lines mis alignment,Colors shadows or 3d pictures effect.The tv convergnce board is dead.The tv convergence board,require replacing 2 STK convergnce ICS and some or all it resistors.To solved tv convergence board,to solved tv convergence pictures problems.The shop,will cost u like $300-350 for parts and labors.
Sep 11, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Samsung tv model # HCP4363WX Ghosting
The convergence board that you replaced will not correct the issue that your describing as your model has the convergence amp circuits located on the Deflection board. You would need the deflection board which is available at the following link. It also has a picture of the board which is in your model its the large board on the right with the Flyback and both Convergence ICs on it.
http://servicemanuals.vstore.ca/product_info.php/pName/p59a-pwr-def-board/cName/samsung-parts
Dec 16, 2009 | Televison & Video
Color is distorted. Green, red, and blue ghosts
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jul 15, 2009 | RCA P52950 52" Rear Projection Television
Panasonic projection tv
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 08, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Color
you need to re converge the set...theres should be a convergnce button on the remote
Aug 29, 2008 | Televison & Video
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
107 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
