Question about Planet Audio BB212D Car Speaker
I need a wiring diagram for a Pyle plwch10d sub with a 1200 watt 2 channel 2 ohm amp
2 Suggested Answers
Suzman
  • 642 Answers
SOURCE: need to wire my planet audio big bang 1200 watt
N/C - No Connection
Posted on Dec 04, 2010
I want to wire my 4 ohm DVC subs to my Pyle 3000 watt home receiver amp
No you don't. You'll fry the amp. You need a low frequency processor to strip the mid and hi frequencies out of the signal applied to the subs or you'll have a full frequency sub that will sound cruddy. If your amp outputs 8 ohms the you'll have to wire 2 speakers in series or poof goes the amp. If the amp is only 16 ohms then you're out of luck unless you have 2 more speakers to connect in series to the 2 you aleady have.
Feb 19, 2015 | Pyle Car Audio & Video
Can someone please show me how to wire my subs to amp.. i have a 2600 watt planet audio 2 channel amp (2 ohm stable) and my subs are soundstream tarantulas t4 12s 900/1800 watts total. they are 1 ohm subs...
for your subs and amp the best way would be for the speakers to be wired in series1ch (mono or bridged)to have a 4 ohm load to your amp stable at 2 ohms
see pic for wiring diagram for 2 1 ohm dvc subs wired in series.
you will need more than one speaker wire for wiring the subwoofers coils(positive & negative terminals) together
hope this helps :~)
Mar 03, 2014 | Car Audio & Video
My pyle 2200 1400 watt 2 channel amp wont get power..... why!!!!!
did you check the remote turn on wire connection at the back of stereo?
Jan 15, 2012 | Pyle Car Audio & Video
Can I hook up 2 lanzar opti1532 subs 2 a kicker kx 1200.1 or do I need a bigger amp, its a 1ohm stable amp an birth sheet says 1390watts but they told me at 14+ volts it will do 1400rms
Based solely on spec sheet information the Lanzars can handle 1300 watts RMS and the KX1200 is rated at 300x1 @ 4 ohms, 600x1 @ 2 ohms, & 1200x1 @ 1 ohm. Even with a 1 ohm load you will still only be providing 600 watts to each sub. While the kicker will provide more power at 14+ volts, no car creates more than 12-13 volts via its alternator. A car battery only provides 12.6 volts. So you will be loking at 1200 watts from 1 channel as a best case scenario.
Additionally, with your 2 subs, they will need to both be Dual 4 ohm voice coils in order to net a 1 ohm final load. Each voice coil will need to be wired in parallel and then each speaker needs to be wired in parallel.
Dec 23, 2010 | Lanzar OPTI1532D Car Subwoofer
What size amp needed with a sony explod player?
this bandpass enclosure is rated peak power at 1200 watts . what this means is that each subwoofer in the is peaked at 600watts to make 1200 watts . what your looking for is to power up the subs with rms continuous wattage . you need an amp that will put out 400 to 500 rms a channel to run this sub enclosure at 800 to 1000 watts rms to keep the speaker from blowing
audiopipe apf1801
71671968.jpg this amp will give you 1 channel @ 4 ohm x1 350 watts 1 channel @ 2 ohm x1 900 wats 1 channel @ 1 ohm x1 1800 watts you would have extra power for better subs with more power later but you get 900 watts which when connected right would mean 450 watts per sub be perfect for you . i sell this for $320.99 in my store can shipp any where in usa to contact me caraudioquestion@gmail.com
Oct 14, 2010 | Dual XINBP-210 Car Subwoofer
Pyle Academy 2300 watt amp not working =(
wrap a striped speaker wire around the back of the rca out put on your cd player and for the record that aint a 2300 watt amp its like a 300 watt amp
Mar 30, 2010 | Pyle PLAM2300 Car Amp
My amp and subs work but the subs dont sound very loud. how do i adjust my Pyle PLA4340 amp and fix this problem
Hello polarisracin,
You need to bridge 2 of the amp channels to each 4 ohm sub to get the most power from the amp. Bridge channels 1/2 to one of the subs and channels 3/4 to the other one. But the amp is only rated for 75 watts RMS per channel and Pyle products are sometimes rated higher than their real capabilities. So, even bridged and with the rated output, you'll only be getting at most 150 watts from a pair of bridged channels. That's not much for a sub.
Hope this helps.
Oct 01, 2009 | Pyle PLA4340 Car Audio Amplifier
Want to bridge 2 channel amp to push single 4 ohm dvc sub
Hello k_rabbit89,
A 4 ohm DVC sub can be wired in series like you described for an 8 ohm load or the voice coils can be wired in parallel for a 2 ohm load.
If your 2-channel amp isn't stable down to 2 ohms when the channels are bridged (most 2-channel amps are only stable to 4 ohms when bridged), you do not want the voice coils paralleled. The amp will overheat, go into protection mode, and eventually fail completely. A sub with 2 ohm voice coils would be a better fit. That way, you could series the coils for a 4 ohm load and the amp would operate OK with the channels bridged into that load.
But anyway, for the best power from THAT amp to THAT sub, your best wiring solution would be to wire each voice coil to a separate channel. The problem with that is that the signal to each coil needs to be EXACTLY the same or you will have one coil trying to move the cone out while the other one tries to move it in. You can closely approximate identical signals on the output side by using the same input to both channels. Do this by using only one RCA connection (either right or left channel) from your head unit and split it with a "Y" cable.
Hope this helps.
Sep 12, 2009 | Car Audio & Video
Where can I get wiring diagram?
www.pyleaudio.com/manuals/PLMRA220-420.pdf
Jul 22, 2009 | Pyle - plmra220 - Marine 600 Watt 2...
Planet Audio BB212D Car Speaker Logo
180 people viewed this question
Top Planet Audio Car Audio & Video Experts
Tygh Duval
Tygh Duval
michael galang
Are you a Planet Audio Car Audio and Video Expert? Answer questions, earn points and help others
