Question about Ovens
Need the owner manuel to a KitchenAid Thermal Convection Oven model number KEDH207YWH
I would like to know if the oven has a reset button
textonor
  • 130 Answers
SOURCE: Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Posted on Feb 03, 2008
SOURCE: kitchenaid KEBC177 electric convection oven will not heat
This is a design flaw in the Kitchenaid convection ovens. I can help fix this problem if you have a built in oven (I don't know if the parts are located in the same place for stand alone ovens). First it is not a FUSE that has blown rather it is the thermostat in the rear of the oven. (Part #4452223) This small part cost about $37 US and after shipping it will cost you about $47. I tried to get an estimate from an electrician as to what they would charge for the part and to come out and fix the oven an the price was about $90 for the part and anywhere between $100 and $170 more for the service call + repair! After a day of frustration I decided to tackle the problem myself.
The very first thing you must do is shut off the circuit breaker to the oven and put a very large sign on the panel that reads DO NOT TOUCH! That is 220 volts to that oven and while most panels have just the oven ont circuit you dont want anyone reactivating that circuit by mistake!
The next part requires a little work. Find the side panel screws (usually located in the oven door) and remove the two panel flanges that cover the 2 or 4 mounting screws that keep the oven in the wall. Now go underneath the oven and find the power junction box, take off the cover and disconnect the wires that run from the oven. Remember which goes where. Next remove the little nut that holds the electical conduit cable to the junction box then loosen the wires. Once this is done you can now slide the oven out and get to the thermostat.
This part requires a little elbow grease. Find a platform or table that fits just under where the stove will slide out and slide the oven on top of the table or whatever for support. In the back of the oven there will be a sheet metal panel that covers the thermostat and other wires, remove the 5 or 6 screws that hold this panel on and put the panel aside. Almost in the middle of the oven's back you will see a little black device with two wires running out of it (one red the other white or yellow). It will have the part number on its front, remove the wire and notice that the thermostat is half red and half white (remember this for the new part will have the same markings) the red wire goes onto the lead coming from the red markings. When you have the new part simply put the new one in (remember: the red side to the red wire), attach it to the back of the oven, replace the sheet metal cover and slide the oven back into place securing it with the screws. Viola! you are done! Turn on the power and then test the oven (I used the broil setting to warm it up then switch to a temperature setting). The entire process took me about an hour and I am NOT a handyman!
For about $50 and a little work you will save yourself from $150 to $250. Not to mention the repairmen won't have a clue as to what the problem is or who will attempt to sell you a new front panel or perform other unnecessary work.
Posted on Dec 09, 2008
kram26
  • 544 Answers
SOURCE: I need to self- clean my Thermador convection oven
hi,
here is the manual for your oven try to follow them and make them as your guide enjoy..
click on this site..
http://specs.retaildeck.com/CACHE/FILE2202.PDF
thank you,
please don't forget to rate our answers.
Posted on Feb 19, 2009
SOURCE: OVEN will not heat
KitchenAid KEBC107KSS does not heat hot enough and does not heat evenly. When the temperature is dialed higher, it burns the cookies. When the convection fan is on, it has a 'cooling effect' so the temperature never reaches the proper level. Is this problem repairable? Or is this a thermostat issue? Thank you for your help!
Posted on Jul 17, 2009
jumptrout51
  • 3361 Answers
SOURCE: Kitchenaid Superba electric convection oven not preheating right
Your temperature sensor is failing. Replace the temp sensor.
Posted on Jul 21, 2009
Free fuse box diagrams
Parts #: W10317343
Substitution: WPW10317343 $145.98 at sears
Parts #: W10354052
Substitution: WPW10354052 $125.92 at sears
Part #: W10317347 front LED board $230 at sears
Many ovens have a bi-metal thermal fuse-also called a thermal limit switch-that protects the oven from overheating. The oven thermal fuse trips when the temperature in the oven gets too hot. After the thermal fuse trips, the oven won't heat. If the thermal fuse trips after the self-cleaning cycle, try resetting the fuse by turning off electricity to the oven, removing the exterior back panel, and pushing the reset button. If the fuse tripped during normal operation, replace it. If the problem persists, the electronic oven control board might require replacement. Reset the thermal fuse after replacing the control board.
Jul 15, 2014 | KitchenAid Ovens
When trying to thermal/radiant bake, convection fan at the rear does not stop turning after the preheat. Why doesn't this happen? Isn't it then convection baking?
Most wall ovens have a cooling fan that comes on when the oven has been on for some time. It is separate from the convection operation. It should shut off after the oven has been off for a time.
Nov 12, 2013 | KitchenAid KEBS279BWH 27" Double Electric...
KitchenAid gas convection oven model # kgst307hbl4 won't turn off
seems like the safety switch not work. be careful
Mar 27, 2017 | Ovens
Teka ha 830 oven timer will not reset after power cut
I have a Teka HA830 oven I held the buttons down but it never resets. Would like to know if its possible to change the computer board, and where can i purchase it online?..
Jan 29, 2013 | Ovens
My daughter-in-law just moved in to a newer home with a stainless steel Kitchen Aid ceramic top stove. It has a warming oven, a convect feature etc. However, with options etc. it is very confusing to...
Kitchen Aid manuals are available from their support site: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . The model number is needed to locate the manual. For ranges, the plaque with the model number is inside the oven door.
The KitchenAid ovens that I know will turn off when you press Off (unless the control lock is on - then you need to disable the control lock). The Warming Drawer will have a separate Off button. Dual oven units require you to select which oven and then press off.
See http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KESS907XSP_Use%20and%20Care_EN.pdf for a similar range. (ceramic glass cooktop, convection feature and warming drawer)
I hope this helps.
Jul 02, 2011 | KitchenAid Ovens
The oven won't turn on. We are unable to set the clock either. The display flickers but doesn't display.
There are lots of different timers on fisher and paykal The last one I reset was a few weeks ago it involves pressing 2 buttons at the same time I think it was the oven on and oven off buttons but I am not sure You will know when you have pressed the right 2 buttons the display will stop flickering set the clock time using the up down arrow buttons The auto light should not be on if it is press the manual button Regards Geoff Stove Recyclers
May 29, 2011 | Fisher Ovens
I set a cooking time on the oven button, but now want to cancell it I have tried everything and it will not cancell out
Without knowing the specific model and given you've tried all the buttons the brute force solution is to temporarily cut your power at the meter box. It solves the automatic oven problem but may create others (resets your clocks!)
Sep 11, 2010 | Ovens
The oven will not operate after I switched the mains power off. The clock is flashing 0. Any help appreciated !
I dont know your model but it seems like the clock needs resetting if you have a manual it will tell you in the book.if not just keep pushing buttons. normally holding the 2 on rhs then pressing other buttons can do it keep fan oven switched on as you try to reset
Hope this helps.
Good Luck.
Apr 11, 2010 | Ovens
Ovens Logo
69 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
