Question about Acer Aspire 3680 Laptop
Buying new Acer Aspire one netbook..can you answer some questions: 1. My TV has a RGB port. Will my VGA port be compatible on the Aspire One? 2. What are my options for installing programs and files from a CD"s? Will the card slot be an option using flash drive? 3. I have an external hard drive. How can I upload programs to the Aspire One? 4. Do I need to buy a external CD drive to install programs? Thanks in advance. Dean Dubbs
  • dotdean Jan 30, 2009
    So called NETBOOK computers are new. This one is identified as ACER ASPIRE ONE NETBOOK with the 1.6 Ghz Atom processor, 1 GB memory, 160 hard drive, three USB, wireless lan, SD card compatible with Multimedia cards supportin , 1 gMemory Stick, 1 VGA, webcam,and ethernet & at $349).
    -Do I need to install the Seagate External drive software on the Acer before installing the drive to load programs and files or will it start right up when I plug it in and the program automatically installs?
    -I think you'll telling me to try the cable at both ends with the VGA connecter at both ends to see if it works?
    Thanks for your prompt reply.
    Dean Dubbs, dotdean@earthlink.net
  • Acer Master
  • 5,568 Answers
There seem to be several versions of that model number 3680-XXXX. It's kind of hard to answer your questions without knowing the precise configuration of the computer you want to buy.
Take a look at just those on the first page of a Google search:
Aspire 3680-?
1. As a general comment RGB does not equal VGA although the latter contains those color lines, it also includes vertical and horizontal synchronization signals.
RGB can even vary; some versions combined sync signals with one of the color lines (usually Green for some reason) and they are separated internally then.
2. - This could be affected by changes in that sneaky -XXXX   3. It depends on both your external drive and which ports are available on the Aspire - if your drive is USB, then there shouldn't be a problem since USB ports are on any PC made in the last dozen or so years. 4. See response at 2.
You will really have to see the exact specs on the machine you are getting to answer most of your questions.
Posted on Jan 28, 2009
  • Steve Allison
    Steve Allison Jan 30, 2009
    That depends on the BIOS and operating system and you didn't mention what is installed on the one you are buying.
    The BIOS (most) would automatically detect the drive and pass information to the operating system which would then install the driver(s) IF it is 'plug and play' (often called plug & pray- for good reason).
    The standard VGA chassis connector is a 'D' (flattened) with 15 pin positions although some of them are often missing (not used).
    VGA illustration
    There are adaptors that can match different connectors but you can't mix VGA and RGB unless the adaptor has at least five coaxial connectors, the additional two for the horizontal and vertical sync signals.
How do i fix white screen on my kav60 acer aspire one
The KAV60 is also the AOD250.
Netbook OFF, monitor OFF, connect an external monitor to the netbook's VGA port.
[You can use a VGA monitor. Looks like a small TV.
This is an example of a VGA port,
VGA connector Wikipedia the free encyclopedia
Note* VGA port doesn't have to be blue in color ]
Turn the monitor on. Turn the netbook on.
If there is no image shown on the external VGA monitor, press and hold down on the Fn key, and at the same time tap once on the Display Toggle-Over key.
(The F5 key is the Display Toggle-Over key)
No image on external VGA monitor?
Hold the Fn key down once more, and tap again on the F5 key.
Still no?
Problem is internal in netbook. Probably graphics chipset soldered to the motherboard.
Replace motherboard.
Image shows on external monitor?
Problem is with Video Cable or laptop LCD screen.
MOST of the time it's the Video Cable.
The Video Cable connects to the motherboard, in an area under the Keyboard. It then routes up under the left Hinge, and into the Display Panel.
Inside the Display Panel it then connects to the LCD screen.
With frequent opening and closing of the netbook, the Video Cable can be pulled on. This can cause damage to the Video Cable.
(Stretched/broken wires inside the sheath of the cable)
And/or it can cause the connection at the motherboard to be loose, and/or at the LCD screen.
Example of Acer Aspire One video cable,
For ACER Aspire One D250 LCD Screen Cable DC02000SB10 KAV60 New
You can remove the Video Cable, and check it's continuity with a multimeter, or if the cost is reasonable to you simply replace it.
8 to 10 dollar video cable is not the problem? Then problem is the LCD screen itself.
My money is on a loose video cable connection, or damaged video cable.
For additional questions or to have me clarify/simplify anything in my solution, please post in a Comment.
Regards,
joecoolvette
Jan 15, 2015 | Acer Computers & Internet
My laptop is Acer Aspire 4920. When I connect to Samsung LCD TV nothing is coming. I connected properly. Can any body explain how to go about it
Make sure TV is set to connecting input port, like VGA or S-Video. "New Display" should appear on laptop.
Acer has more troubleshooting answers with helpful pictures.
http://acer.custhelp.com/app/answers/detail/a_id/5989/kw/monitor/related/1
Oct 05, 2012 | Acer Aspire One PC Notebook
I have an Acer one aspire but cannot link this to my HD tv, I have bought a VGA to component cable but it will not display image even though I press the FN key and F5. it works on a smaller TV via VGA to...
A VGA to Component cable is used only in special monitors - it won't work on tv's because the signal is completely different between them and the tv can't decode it: in the VGA you have an RGB signal with separate synchro while in the Component you have a Luminance signal with integrated synchro and 2 colour difference ones. So a converter is mandatory , one like
http://www.electronicsshowplace.com/hdmi-converter-p-251440.html
Aug 17, 2011 | Acer Aspire One Netbook 8.9" Notebook
How do I connect the Acer netbook to the TV?
The only option is using the VGA port on the Aspire One to hook it up to the TV.
Your TV must have a VGA in port for your to be able to hook your computer to your TV. All you need is a regular VGA cord.
Mar 26, 2011 | Acer Aspire One Netbook 8.9" Notebook
How do i connect acer apire one to lg lcd tv?
In order to connect your netbook to lcd tv your need a VGA or a HDMI cable( if your laptop has a hdmi port). Once you connect the netbook with the lcd tv you nned to use you tv remote to choose the input to pc or pc1 or HDMI depending the lcd tv. if you any futher questions please feel to ask.
Jul 08, 2010 | Acer Aspire One PC Notebook
I have an acer aspire 5535-6637 and I was wondering if it is compatible with an S-Cable.. If not how can I watch things on my laptop from my TV. Thanks!
You may or may not be able to, it depends in part on your TV. The earliest interface that was compatible would be VGA but it may not be very good on resolution.
The specs for your notebook show only:
DVI Port, VGA port
The DVI (Digital Video Interface) port is available on later sets so check your user guide for either of those two and if VGA is the necessary choice, check which resolution the computer and TV share. DVI will adhere to the same standard for both.
BTW, when asking for help when interfacing devices, include model numbers for both; it saves us time and will give you a more accurate answer with fewer generalities.
Mar 27, 2010 | Acer Aspire 5535-5050 Notebook
I have an ASUS 1005 HA Seashell netbook,and i an
You need a DB15pin male VGA to DB15pin male VGA cable - you cannot use rgb with this netbook. This type of VGA cable is available on Amazon at a very good price and at many different lengths.
Mar 02, 2010 | ASUS Eee PC 1000HE Netbook
How to work with an acer aspire mini laptop with linux?
2 - it does not have a cd ! This is not a linux or windows thing ! U can use a usb cdrom if u realy want to...
3 - u;ll need a usb stick bootable with dos OS on it and the kit for xp ... there is plenty of info on google... But i recomand useing the linux(faster, more stable ... prettyer :) )!
Jan 07, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 3680 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
