Kyocera KM-1820 error code c4000 how to fix it?
SOURCE: KYOCERA KM-1820 COPIER
follw these steps, it should work
turn off copier.
open top toner cover.
turn copier back on.
when you see message "close top cover" press "system menu" button.
scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time.
then scroll down to "maint mode"
press "enter"
then enter 163
press" enter "
turn off copier then turn back on
close toner cover
you should be back in business
Posted on Jun 12, 2008
KyoDoc
  • 38 Answers
SOURCE: KYOCERA CS-1820 ERROR CODE C7990
Apologies for the late reply. This is a waste toner full problem. Pull out the process unit (in case you don't know, it's the big black unit where you fit your toner into, also the one that you need to remove to check for paper jams. Turn it around so that the side where the toner fits is furthest away from you. Now on the side closest to you, on both the left and right hand side are two small covers, each fastened with 1 screw, hidden in deep holes. Remove these screws and covers, and empty the toner inside.
Be advised that this is a very messy job. Also, after you've removed these covers and you turn the unit on its side, the toner may not fall out. in this case stick a screwdriver or something in there to loosen the toner.
When done, refit the covers, place the unit back into the machine, restart the machine, and thats it. If the code still appears, you've got toner on the waste toner full sensor, which sits just above where the waste toner part of the process unit is, inside the machine. you can take a cloth and wipe this. although this is highly unlikely, nothing in this industry surprises me anymore.
if this still fails, you could have a faulty sensor or circuit board, but again, highly unlikely
have fun (nothin like gettin your hands dirty) ;)
Posted on Sep 18, 2008
leroyal
  • 2120 Answers
SOURCE: Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Posted on Jan 15, 2009
fsantello
  • 4 Answers
SOURCE: Error Code 2102
Change the SMTP port from 25 to 587
Posted on Aug 20, 2009
cbtmaya
  • 84 Answers
SOURCE: error code C-6 for kyocera km 1500
c6-400 code error is poor connection (power supply)
press start and clear/stop button
the code is inizialized
Posted on Aug 31, 2009
How to solve error c4000 for Kyocera KM-2035 copier? it has stopped
c4000
The Problem:
inside the laser unit Polygon motor synchronization problem
The polygon motor does not reach the
stable speed within 15 s of the START
signal turning on
Causes:
1-Poor contact in the
polygon motor connector
terminals.
Reinsert the connector. Also check for continuity
within the connector cable. If none,
remedy or replace the cable
2-Defective polygon
motor.
Replace the polygon moter or LSU.
May 29, 2014 | Kyocera KM-1505 Copier
Se produjo un error llamar al tecnico C7980
On the screen of my KM 1820 copier Kyosera get the message "An error occurred calling a technician" and C 7980
how I can fix this error?
Sep 03, 2010 | Kyocera Copystar CS-1820 Black and White...
I have a kyocera km 1820 copier at work and cannot figure out how to navigate it to make 2-sided copies???
The Kyocera KM-1820 does not have an automatic 2-sided option. This is why it cannot be found in the settings.
May 20, 2010 | Kyocera Copystar CS-1820 Black and White...
Error Code 2102
Oct 21, 2008 | Kyocera Copystar CS-1820 Black and White...
Oct 20, 2008 | Kyocera Mita KM-1815 All-In-One Laser...
54 people viewed this question
jasbo
jasbo
