Question about Microsoft Zune HD MP3 Player
Zune error code c00d121a - Microsoft Zune HD MP3 Player
Does anyone know how to fix error 5 code?
Many Zune users will tell you of the dreaded error 5.
When the error occurs it means that the Zune has encountered a problem that it cannot recover from and informs users to contact customer support.
Usually to fix this error, the Zune must be sent to Microsoft. If the Zune is under warranty and the owner is within the US, this is little more than an inconvenience.
If the owner is outside of the US this is not and option and if the warranty has expired, the fix can come at a high price.
However, before sending a Zune off to Microsoft for fixing, there are a number of things to try.
The first thing to try would be to restart the Zune.
The steps to restart the device vary based on Zune model. For the Zune HD player, the user should press and hold the on/off button for roughly ten seconds and the player will reset.
For the non-touchscreen models of Zune, the user should unlock the hold switch.
Then, press and hold the back button and the top button of the Zune pad. The device should restart and the user can release the buttons.
If this does not fix the error, then the user should try reinstalling the software on their Zune device.
To reinstall the software on a Zune HD, the user should press and hold the on/off button for about ten seconds.
When the device restarts, the user should press and hold the "Media" button until the message "Connect Zune To Your PC" displays on the screen.
The user should make sure they have the most up to date Zune software installed on their computer and connect the Zune.
Update the Zune and it should be ready for use again. If the user continues to experience problems, then the Zune HD software may have to be completely deleted and reinstalled. Doing this will completely delete everything on the Zune, so anything that has not been backed up will be lost, including purchased items.
To do this, the user should hold down the on/off button again until the Zune HD restarts.
Upon restarting, the user should immediately press both the "Media" and the "Home" buttons until "Connect Zune To Your PC" displays.
The user should then connect their Zune HD to a computer with the most up to date Zune software and update the Zune.
For the non-touchscreen Zune models, the following step will erase user data (including purchased items), so a backup is recommended.
First, the user should unlock the hold button.
Then the back button and the top button should both be pressed and held down.
The next step varies by model. For owners with a Zune 4GB, 8GB, 16GB, 80GB, and 120GB, the Back button, Zune pad, and Play/Pause button should all be pressed and held down.
The user should continue to hold them until they get a "Please wait" message.
For owners of the Zune 30GB, the Back button, the left side of the Zune pad, and the center of the Zune pad should all be held down until "Please wait" displays.
After data is cleared, the message "Connect Zune To Your PC" will appear.
The user should connect the Zune to a computer with the most recent version of the Zune software installed on it.
After the software is installed, the Zune should be ready for use.
If these measures fail to fix error 5, then the Zune owner will likely have to send the device to Microsoft as the problem is deeper than a software issue.
Sadly, it is not always clear what causes error 5 to occur. In these cases, there are few other options than to leave it to the experts.
hope this helps
Oct 05, 2012 | Microsoft Zune JS8-00001 Digital Media...
Zune error
The error code 0x80070643 is related to Windows Updates (here, updates for Framework), therefore I suppose that your computer is not up to date and that the Zune Software is having problems to be installed due that.
So, for resolving this issue, there are two steps that I'd suggest you to follow:
- Install the Windows Updates needed as described in this article: http://support.microsoft.com/kb/976982
- Download the FULL Installation package for Zune Software and install it: http://go.microsoft.com/fwlink/?LinkID=206980
Aug 19, 2012 | Microsoft Windows 7 Home Premium 64BIT...
Error code 5 and 3
hold the back button and the up button until you see the Zune logo then release. if this doesnt work then you are going to have to reset your Zune....however this will loose all the data on the zune so your music/movies will be completely gone. you are going to need to press and hold the back and up button until the zune logo appears then hold the back,play/pause, and the center button until you see "please wait"
if this doesnt work you have some serious issue. Contact customer support
Sep 05, 2011 | Microsoft Zune JS8-00001 Digital Media...
Zune 30gb says "Connect Zune to your PC" and when
Hi if you have done this 7 times the HD is bad and will need to be replaced. I fun into this all the time with the Zune players.
If you need more help, parts or repair services you can go to my repair service web page at firehouse7777.weebly.com and find info to contact me if needed. thanks
Dec 11, 2010 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Error code cood124d
One of two solutions to try
First, hold back arrow button and up on the touch pad (non-touch screen version) until it resets, then try to sync again.
If no go...
Next, connect the device to a true 2.0 usb port, try not to use any usb ports on your monitor or keyboard, connect the Zune directly to your PC and then try.
Lastly, not a troubleshooting steps per se, but try a different Zune cable as the 1st generation cables are thin, slow, and are easily damaged.
Hope this helps!
Jul 09, 2010 | Microsoft Zune 2nd Generation Digital...
Zune 80gb mp3 player wont update sofetware, giving me ERROR CODE
uuuh your zune is eather dead or defective cause there were some "bad" zune that were let out and yours is probably one of them
Feb 01, 2010 | Microsoft Zune JS8-00001 Digital Media...
Error code c00d124d appears on my zune while sync
You may have to attempt a Hard Reset if this issue is persistant.
This will erase everything on your device, as a warning please be certian you have backup copies or this is a last resort.
Here is the original post:
WARNING: A hard reset will delete everything on your Zune.
  1. Press and hold the back button
  2. Press and hold up until it reboots
  3. Depending on which Zune you have, immediately do one of the following:
    1. If you have a Zune 4 GB, Zune 8BG, or Zune 80GB, immediately press and hold the Back button Back at the same time as you press the right side of the Zune pad and the Play/Pause button. Continue to hold these buttons until the Zune device restarts and you receive the following message: “Clearing contents. Please wait.”
    2. If you have a Zune 30GB, immediately press and hold the Back button Back at the same time that you press the right side of the Zune pad and the center of the Zune pad. Continue to hold these buttons until the Zune device restarts and you receive the following message: “Clearing contents. Please wait.”
    Good luck, Let us know
Apr 14, 2009 | Computers & Internet
Zune player
As a last resort or if you are receiving error code C00D2772, erase the device, and then sync your content again. To do this, follow these steps:
  1. Start the Zune software on the computer.
  2. Connect your Zune device by using the Zune Sync Cable.
  3. Click Settings, and then click device.
  4. Click SYNC OPTIONS, and then click ERASE ALL CONTENT.
  5. When you receive the following message, click Yes: Please Confirm. Are you sure you want to erase the contents of the connected Zune? You receive the "Erase All Content" message. This may take several minutes. Do not move or disconnect the Zune device until the message disappears.
Oct 10, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Frozen zune 80gig 2nd gen, error 5
One last ditch effort: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
And, yeah, as far as the international replacement - that is how all the manufacturers are - they are not willing to pay the cost to keep their customers. Also, they have no process in place for fulfilling such a request, even if they have offices in both countries (which most of them do). Sad, really.
Jun 02, 2008 | Microsoft Zune JS8-00001 Digital Media...
Microsoft Zune HD  MP3 Player Logo
65 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
