Question about Averatec (82-878011-01) Motherboard
My battery will not charge for my averatec laptop. The internal port seems loose and the external charger takes some wiggling to try to stay connected. Is the internal battery connection conneted to the motherboard.
    President:
  • 2,992 Answers
I've never worked on this brand, but almost all laptops have the power jack soldered right to the system board. Flexing the power connector can break the solder connections and cause the problems you describe. If there hasn't been any damage to the system board, these connections can be resoldered. Getting to them can be a challenge as it means removing the system board to get at the solder side. But if you have soldering experience, patience, a small screwdriver, and some attention to detail, you can fix this.
The only trouble that may pop up is that sometimes electrical arcing occurs where the connections break, and may burn the circuit board. Sometimes the area can be cleaned and successfully repaired, sometimes it's too far gone. But it never hurts to try the repair. Good luck!
Posted on Jan 28, 2009
Hi. Our Advent Roma 2000 laptop seems to have a problem charging. Thought at first it was the charger so bought a new one, but still the same. The charging light flickers on and off as though there is a...
If you wiggle the connection to the laptop and it feels a bit loose, then the power connection on the laptop itself probably needs re-soldering. This is a common problem with laptops. Unfortunately unless you can do it yourself or know someone you can, then it will cost quite a bit to get fixed outside of warranty.
Feb 28, 2011 | Computers & Internet
My treo pro wont charge the battery. I have purchased a new battery but the problem persists. I connect the phone to its craddle and tha charging indicator turns on; however, the battery remains at...
Either the charger port on the phone is faulty or the charger itself. Try a different charger if you can and if this works, the dock is faulty, if it doesn't then its the phone. Pretty simple repair and most Treo repair centres will be able to do it.
Feb 03, 2011 | Palm Treo Pro Smartphone
My laptop (hp x9010)is not switching on ,i pressed the reset button but still not responding whats the problem and solution
This could be down to several problems.
Firstly, check that the battery is being charged by the charger and indeed if power is getting to the laptop via the charger. The simplest way is to see if the charger LED light is green. Flashing green indicates that the power is being "spat back".. ie: not completing the circuit and this indicates that the charging circuit on the board may be damaged.
Secondly, is the charger plug tight in the port? A loose plug will not make enough contact (if it is try wiggling it and see if that helps. If it IS loose and works whan wiggling, you will need to get it replaced.
Thrirdly, try removing the battery and AC power, press the on button for 30 seconds, reconnect the Ac adaptor only and see if it then powers up
failing that, it would seem that the main fuse on the motherboard has bloen and you need it replacing
Jan 22, 2011 | HP Computers & Internet
Nokia 1100 not charging from external charger
Ther charging circuit seems to be defective or your charger is gone. Try and test the charger elsewhere.
Jul 28, 2009 | Cell Phones
My env2 wont charge. whenever i plug it in, the battery stays the same. what do i do?
This seems to be a common problem for the env2. If you hold your charger a certain way in the phone does it charger? Is the charger port broken or damaged?
If so the easiest workaround is to get an external battery charger and extra battery to charge the phone.
Check out the following link for information on the battery charger and other options for the env2 charge issue.
Lg Env2 External Battery Charger Fix
Jul 17, 2009 | Verizon Communications enV2 Cellular Phone
Laptop not charging the battery
It sounds more like your charger is the problem.... Btw,the cmos battery stays charged for a couple of years. you will notice its dead when booting up your pc loads default settings on in your bios...i.e the time resets each time.
Jul 17, 2009 | Computers & Internet
LG Vu Wont chrge correctly
Your charging port is probably going bad. It seems to happen fairly regulary on the lg VU
you can get it repaired or get a workaround external battery charger.
Check out the following link for your options.
http://www.chargemyphones.com/lg-vu-wont-charge/4/
Jul 02, 2009 | LG Vu Cellular Phone
Battery will not charge nor is able to use AC power to stay on.
Hi everyone it seems to me that the DC connector is loose inside your laptops,try wiggling it about gently at the charger to laptop cord nearer to the dc socket to verify this.Only solution is resolder or new dc socket.
Dec 27, 2008 | Acer Aspire 3680 Laptop
Havoc heli will not charge
As far as the green light on the charger not coming on: after I tested the batteries in the remote, I found that it was due to 2 of the 6 batteries in the remote control being dead (0.1volts) The charger probably sucks the power out of the #1 and #6 battery.
Make sure all batteries in the Remote have the same charge.
Also, there seems to be a loose contact in the charger plug prongs. You will have to find a way to sit the helicopter so that it stays in contact with the prongs while charging. Mine has to be on it's side to keep the green charger light on.
Dec 26, 2008 | Air Hogs Havoc Heli Helicopters
Asus F3JC Q059P Notebook
maybe the trouble is the connection between the charger and the laptop.check also the dc port if it is wiggling.if it does,the trouble is right there.u
Aug 30, 2008 | ASUS F3Jc-AP141C Notebook
Computers & Internet Logo
79 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
