Question about Acer Aspire 3000 Notebook
How do I remove the optical drive in a Acer Aspire 3000?
Which screws do I remove, or do I have to disassemble it?
  • 10,515 Answers
Check the below link
http://doube.org/aspireoptical.html
Thnx.
Posted on Jan 28, 2009
Removing cd rom
The optical (CD) drive on your Acer laptop connects to the side of the device and is accessed via the underside of the computer.
If you are having problems with the optical drive on your laptop you should address it as soon as possible, and one thing you may need to do is remove it.
The good news is that even if you aren't particularly tech savvy, you'll find that the process of removing and replacing your optical drive is relatively easy.
Turn your Acer off and remove any power cables that may be attached to the side of the unit. Turn your Acer upside down.
Slide the battery out of its compartment on the underside of the computer.
Locate the circular optical drive retaining screw on the underside of your laptop.
It is located just above the square WiFi compartment in the middle of the computer.
Use your Phillips screwdriver to remove the screw and set it aside.
Grip the optical drive by its edge on the side of the computer and gently pull to remove it from the computer.
Slide a new optical drive into the computer, making sure the disk opening is facing out of the laptop.
Replace the optical drive screw.
http://www.insidemylaptop.com/replace-hard-drive-dvd-drive-acer-aspire-3610-laptop/
Replace the CD Drive on an Acer Aspire 5000
The CD drive of the Acer Aspire 5000 is designed like most other laptop optical drives.
The CD drive is on the right-hand side of the computer and is attached with screws from the back of the case.
All you need to complete the task is a screwdriver.
To avoid electric shock or damage to the laptop, always ground your tools by touching them against a metal object like a table leg before using them on the computer.
Turn the Acer Aspire 5000 laptop off.
Unplug the power cord from the electrical outlet. Remove the power cord from the power supply in the side of the laptop.
Flip the laptop over so you are looking at the bottom of the case.
Slide the battery pack off the top of the case.
You'll see the CD drive on the left-hand side of the laptop when you are looking at the bottom of the case.
Unfasten the screws that are holding the CD drive onto the laptop with a screwdriver. Slide the drive out of the case.
Slide the new CD drive into the case and secure it with the screws.
Place the battery pack in the laptop and turn the computer back over so it is sitting on its base. Plug the power cord into the power supply in the side of the laptop.
Plug the other end of the cord into the electrical outlet.
http://www.batterystyle.com/acer-aspire-5000-drive-p-307461.html
Sep 06, 2013 | Acer Aspire 5610-4648 Notebook
HOW TO GET THE BACK OFF
Break it off..........
In order to take the Base Enclosure (Bottom Cover) off, you would have to break it off.
The Acer Aspire 5000 series of Notebook PC's, disassembles from the Top down. When you are done you are looking at an empty Base Enclosure,
http://www.ebay.com/itm/ACER-ASPIRE-3000-3004-ZL5-5000-LAPTOP-BOTTOM-CASE-COVER-LOWER-BASE-3AZL5BATN05-/181127078788
You have to;
Remove ALL power. Remove the AC adapter (Charger), and Battery.
Remove the Harddrive Compartment Cover, Harddrive, Memory Compartment Cover, Ram Memory, Wireless Module, Wireless Antenna wires out of laptop body, Optical Disk Drive, (DVD drive), Display Assembly, (LCD Module), Keyboard Cover, Keyboard, Palm Rest Cover, Motherboard, and so on..........
Then you have the Base Enclosure. (Bottom Cover)
WEAR an ESD wrist strap, and have it's alligator clip attached to a good ground source.
Acer Aspire 5000 series of Notebook PC > Service Manual (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Go to the paragraph that starts with Aspire 1200. (1200 in Blue)
Drop down to the 6th line (4920G), scroll across; and click on the blue -> 5000
For additional questions please post in a Comment.
Regards,
joecoolvette
May 02, 2013 | Acer Aspire 5000 Notebook
How do I remove acer aspire 9810 keyboard,I have removed the base cover and screen assembly but I cant fugure out how to remove the keyboard Thanks in advance Peter
to remove the keyboard, remove the screws at the back of your laptop. Then remove the Hard drive, then remove the Optical drive then remove the video card, and then power supply. Then remove the fan from the motherboard and you may remove the screws on top of the keyboard. Finally you may replace the keyboard.
Jul 15, 2010 | Acer Aspire 9810 Notebook
How do i remove the cd/dvd drive for my acer3003lc so that a can replace it
You can use the Toshiba Satellite 5205 guide for removing and replacing the DVD/CD-ROM drive or the keyboard. On this model you have to remove the keyboard in order to remove and replace the DVD/CD-ROM drive because the optical drive securing screw is located under the keyboard. Always start laptop disassembly with removing the battery or you can damage the system board if you accidentally touch it with a screwdriver and shorten traces. Removing the keyboard strip is not very difficult, use your fingers to release the plastic latches. If you want to replace the keyboard, do not forget to unlock the connector on the system boar before you pull the cable.
for the acer 3000
1. At the back of the laptop remove the three screws on the support posts for the screen
2. Open the laptop fully and lift the plastic panel that has the power button.
3. Remove the 2 screws holding the keyboard in place
4. Carefully slide the keyboard towards the monitor and lift.
5. To the left of the keyboard ribbon cable is the screw that's been causing all this grief.
6. Remove, slide out optical drive, reassemble.
Jan 03, 2010 | Acer Aspire 3003LCi Notebook
Replace the optical drive on Acer Aspire m1201
based on the images i've looked on for the Aspire m1201, you don't need to remove the front panel in order to remove the optical drive. if there are screws holding the drive in, remove them and then slide the drive forward. if its held in by sliding latches and not screws, then slide then in which ever direction necessary and then push the drive forward to take it out.
Sep 23, 2009 | Acer Aspire M1201 Athlon X2 320 Gb PC...
Upgrade acer aspire 3000 optical combo?
Yes you can Upgrade by changing the whole device to a DVD writer.
Mar 20, 2009 | Acer Aspire 3000 Notebook
How do i replace the optical drive in my acer aspire 3000 laptop?
I have a small tutorial on youtube about memory and hard drive the basic are the same ill post a tutorial in soon ,however to let you know there are a lot of screws and they are tiny things too! by looking at it on the left hand side there are 4 screws that hold it in place then you should be able to just slide it out, im not sure exactly how but ill figure it out and post the tutorial on toutube youll be looking for acer 3000 or zoomietime ill post it later today-z
Dec 19, 2008 | Acer Aspire 3000 Notebook
Dvd rom does not light up and will not eject and definitely will not read discs.
First off, DON'T FORCE ANYTHING
1. On the back of the notebook remove three screws on the support posts for the screen
2. Open the notebook fully and lift the plastic panel that has the power button.
5. To the left of the keyboard ribbon cable is a screw that holds the drive in place.
Link to Acer pictures
Hope this helps...
Sep 25, 2008 | Acer Aspire 3000 Notebook
Acer 3000 - disassembly instructions in order to change out dc computer connection
goto GOOGLE.COM
then write the same thing as below
" hardware structure of acer aspire 3000 laptop"
that's it...
Dec 01, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
105 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
