Question about Air Tools & Compressors
Miller big blue air pak deluxe package 90706, air compressor blowing off oil thru filters
5 Suggested Answers
rayname
  • 70 Answers
SOURCE: Air compressor/ alot of air is coming out of the oil cap vent.
this could be blow back possibly bad piston rings you may need new rings oil chamber is usually at intake pressure unit may need rebuild
Posted on Jan 24, 2009
  • 41 Answers
SOURCE: Compressor turns on but no air in tank. Oil level
Dismentl the valve plate check the gaskets and the valves,cif not good change and it wlii be ok
Posted on Oct 10, 2009
HansPP
  • 2510 Answers
SOURCE: compressor will pump up about
Check the non-return valves in the compressor head, they could be damaged or leaking.
Posted on Feb 25, 2011
  • 21 Answers
SOURCE: why the temp. rise also all parts ( oil filter / sparator / oil / air filter ) replacement ?
Check the following.
Coolers need cleaning use air line to blow out dust
Thermostat could be stuck, if you take it out and put the spring the other side to hold it open all the time this will temporarly fix problem.
Check fan running and check for correct rotation.
Check oil lvl
Hope it helps
Posted on Sep 05, 2014
Why does compressor push oil through air filter when it shuts down ?
Minimum pressure check valve is bad. when unit shuts down air pressure goes back thru compressor and pushes oil out the air filter.
Jun 02, 2015 | Ingersoll Rand UP6-20-125 120 Gallon...
What would cause compressor oil to migrate to dischage air.
If it is a screw compressor and by you saying you replaced the seperator i would say it it you need to check the scavange line. This is a pipe that goes to the bottom of the seperator filter and sucks any excess oil back into the bottom of the element (pump ) if this is blocked oil will pass down the line insted of going back into compressor. Check pipe on seperator and flex hose going from seperator vessel to bottom of element.
Jul 31, 2014 | OEM Air Compressor Genuine OEM Replacement...
Reset change oil filter alarm after filter changed
I thought this is something that I.R. had to do but it's been a while.
Dec 18, 2013 | Ingersoll Rand Type 30 Electric Driven Two...
After running for a few hours it gets hot and shuts down but runs fine every morning
Without more info I will have to give you several things to look at. Typically during the hot months rotary units experience temperature shut downs due to the following. Dirty oil coolers. Blowing them out with air my help some but ideally they need to be washed using a degreaser solution. Location. during the hot months poor air flow/ air removal may let heat from the compressor build up in or under the cover or room. This hot air gets drawn in by the compressor and raises the compressor temperature. The cycle continues until the compressor shuts down on high air temp. Maintenance. Poor maintenance on rotary screw compressors leads to shut downs on high temp, high air temps then play havoc on dryers which causes moisture in the air system. Maintenance items that need replacing regularly ( about 2000 hrs) oil filter, air filter, Depending on type of oil used change 2000 to 8000 hrs, seperator @ 8000 hrs. Also the amont element will cause high temps if bad. It is located where the three oil lines come together. There should be 4 screws that hold the cover on. the cover also has a hose connected to it and located close to the oil cooler. This amont element acts like the thermostat in your car. it lets oil bypass the oil cooler or causes more oil to go thru the cooler. the cooler oil and bypass oil mixes and maintains a certain temp. air end temp should run about 195 F and injected temp about 165 F. hope this helps. if you can give more detailed info I can get you closer to your problem.
Jul 13, 2011 | Air Tools & Compressors
Gardner denver air compressor is blowing oil, need help
Is this a rotary screw compressor? If so, is it blowing oil out of the air filter or out of the discharge air lines? If it's blowing oil out of the air filter you have a oil stop valve or minimum pressure check valve bad. If oil is coming out of the discharge air you need to change the seperator.
Nov 15, 2010 | Air Tools & Compressors
Oil comes out thru crankcase vent
sounds like piston ring blowby or a broken piston, teardown will reveal the broken parts.
Jan 25, 2010 | Ingersoll Rand - Rand - Ir 2545K10FP Type...
Temperature rising
Make sure that your pully fan is blowing across ehe fins. Check and clean the air intake filter. Check the oil level.
Regards, --W/D--
Jul 16, 2009 | Ingersoll Rand Type 30 Fully Packaged Ir...
When shutting down the compressor, oil comes out intake filter
hi there,
well,if your air compressor was shut off this due to pressure switch w/c auto switch off your compressor,the pressure switch acquired already the cut off pressure.if the pressure goes down the cut in set up reached it will start your compressor
to run.
regarding oil spillage when shutting down check the oil level on the sight glass of crankcase
a red line indicate oil should not exceed on that level line,if the oil exceed try to drain oil.,on the side bottom of engine there is a drain plug.until on limit level .,besure that machine is shut off/breaker is off.have a nice day don't forget to rate me,thank's
Apr 28, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
Blows cloud of smoke
thin your fuel mix with about a gallon of kerosene to 5 gallon of heating oil.could also be a semi clogged fuel line filter.
Nov 21, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
