Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
What is the difference between pulse and tone? What should I set my phone and fax on?
  • Cheryle Roussin
    Cheryle Roussin Jan 28, 2009
    Thanks for your help. I appreciate it!
    Problem Solver:
  • 7 Answers
The difference is that when you set your phone on pulse it works like a switch on/off 1 pulse for number 1, 9 pulses for n9 and so and so.
When you set it on tone each number has a different tone, differnet sound frequency.
You should set your telephone on tone.
Posted on Jan 28, 2009
4 Suggested Answers
SOURCE: Tone Pulse
1)Make sure the phone is OFF (not in TALK MODE) 2)Press and hold the PROG buton until you hear a beep. The TALK button will flash while in this mode 3) Presd the TONE (*) button to select Tone Dialing or press the PAUSE (#) button to select Pulse Dialing 4) Press the PROG button again. The unit beeps to confirm.
Posted on Aug 17, 2007
  • 3 Answers
SOURCE: From Pulse to tone
TONE/PULSE DIALING
1. Make sure the phone is OFF (not in TALK mode).
2. Use the CID/VOL left (-) or right (+) arrow button to
scroll to 1TONE or 2PULSE, or use the touch tone
pad on the handset to enter the desired setting. For
example, to choose TONE dialing, press the number 1
key. 1TONE is the default setting.
3. Press flash/program to store selection. You will hear a
confirmation tone.
Posted on May 16, 2008
  • 102366 Answers
SOURCE: VTECH VT-2406 TONE- PULSE SETTING ?
http://www.vtechphones.com/vtechui/support/manual.cfm?manualID=373
Posted on Jul 19, 2010
How do I change pulse to tone dialing?
Are you sure about the phone model number?
Tone/pulse is set in the common equipment (KSU) configuration, not the individual set.
Press Feature 9*80 to see the system software version.
Jan 27, 2015 | NorStar M7324 Telephone
How do you change the dial tone from pulse to tone?
is this a land phone? if so look on the side of the phone you should have a switch (T/P) switch towards T...cell phones you go to settings/network/switch fax/tone/pulse/data...
Jun 15, 2010 | Lands Phones
Accidentally set the pulse/tone dialing feature to pulse for a Ricoh 4430L. How do I change it ?
Option setting within "Setup" menu (need access code of 2222) allows you to see advanced features not normally viewed after installation of fax machine is completed. Within these advanced features is a parameter to choose analog line setting of either tone or pulse.
Jan 09, 2010 | Ricoh 4430L Laser Fax
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Problems sending and receiving faxes.
  1. Open Lexmak Productiviti studio - 5600 - 6000 Series ( icon on Desktop)
  2. Open Setup and manage faxes link ( left bottom corner)
  3. On Ringing and Answering card look at the Manual Answer Code ( if some nuber inside delete it, it should be blank)
  4. On Dialing and sending card look at the Dial method (if you have a tone phone select Touch - tone, and if you have pulse phone select Pulse)
The diference betwen Touche Tone and Pulse is that Tone when you press nuber hear tone (like on cell phone), and Pulse when you dial nuber hear serie of short pulses (like when you dial nuber 5 you hear 5 short pulses like tttttt)
Mar 24, 2009 | Lexmark X5650 All-in-One InkJet Printer
Customer looking for pulse fax machine in remote area
Most fax machines will work either way, but you have to set it that way thru the fax settings or it will not work correctly.
Andrew
Mar 16, 2009 | Office Equipment & Supplies
Faxing on pulse line Brother Fax-575
HELLO! YOU WILL NEED TO GO INTO THE SET OF THE MACHINE, THERE IS SECTION THAT WILL ASK YOU PULSE OR TONE PUSH TONE THEN THE SET BUTTON GOOD LUCK
Feb 01, 2009 | Brother FAX-575 Plain Paper Thermal
No dail tone
IS THE PHONE LINE PLUGGED IN TO THE RIGHJT JACK YOU WILL NEED TO CHECK THIS OUT FIRST GOOD LUCK BROTHER TECH
Jan 29, 2009 | Brother IntelliFAX 1840C Plain Paper...
Intellifax 4100
First the link to the manual
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_4100e_EN_250.PDF
The date and time are set up under general set up. Under that menu there is also TONE/PULSE dial mode setting if you have accidently changed this to pulse it will cause issue. Change it to tone if you have and this will resolve the problem. Pulse is the old style phone system.
Mar 05, 2008 | Brother IntelliFAX 4100 Laser Fax
Fax is on pulse dial
Go to the Utility menu, select "Administrator Settings" (password required) from there , fax settings, telephone line. In here you should be able to set the dialing method. There should only be 2 options, just pick the other one. (PB is for tone i believe)
Oct 31, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
201 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
