Question about Teac P11/KIT Thermal Printer
Computer freezes up (Hangs)
After using this product a few times , now every time I use it after printing a few cd's it locks my computer up, I have to reboot my computer, I don't know why, some times I can print 3 or 4, and then It freezes up. Last time I did 5 without a problem?? Any body else with this problem? I have Windows XP It is suppose to me compatible with XP. I tried it on my lap top with Vista, but it didn't work at all.. Thanks
On Vista it's not working cuz u don't have propper driver installed for ur printer, as for PC freezing, chek printer's settings in XP, if it's set to print imidiatelly and not spool print jobs first, it could be ur problem.
Posted on Oct 24, 2007
SOURCE:
My Acer Aspire 4715Z freezes and go back to normal every 2-3 seconds all the time.
Try and reload the Operating System... usually Windows from the CD-ROM. If you do not have a CD-ROM that came with the laptop, you will need to contact Acer to buy a recovery CD for your product. Insert the recovery CD and follow the instructions to reinstall the operating system. Then go to Windows Update to update it. This will take while so leave the computer plugged in and 'ON". This should correct your problem. If you do not have a good anti-virus program, get one. Worms and viruses can destroy a computer's Boot Up directory forcing the PC to struggle to boot up normally. I use Norton 360 myself. While you are at it, get an external hard drive to store your files (back up your data) to secure your data outside the system. You can always get another computer, but you might not be able to retrieve your data from your old PC without some experience and knowledge.
Aug 27, 2012 | Computers & Internet
Sir,i have install 3 sata hdd on my motherboard gigabyte 945 GCM-S2L 1. 160gb 2. 500gb 3. 1 tb. my pc many times hangs on bootup and freezes then i disconnect the cable to turn off. how to fix that...
Do extensive diagnostic tests:
1. Set BIOS to default settings and do not use overclock settings, check.
2. Memory test, download ISO image, burn it onto cd and boot from it.
If memory fails after several hours testing: Replace memory
3. Flash the latest (original)[beta] BIOS version.
4. Connect just one (1) harddisk and test for longer time. *
5. Add second harddisk and test for longer time. *
6. Add third harddisk and test for longer time. *
* If connecting or adding harddisk leads to freezes, exchange that harddisk and retest.
Sep 25, 2011 | Gigabyte GA-945GCM-s2C socket LGA775...
Right from startup if i try to load a program my computer freezes and i get a loading wheel. When I am able to run a virus scan with wildblue it doesnt detect any viruses or spyware. Lately it tells me...
Remove all antivirus products you dont use, and use only one product at time. There is a few good products on the internet....and most of them is for free.
Remove all search products called mostly "Tool Bars" it already builtin in the most of the surf products. It is only more work for the computer.
Try to update from Microsoft Update regulary, if not helps, backup all your Photos and all important documents in My Documents and after backup reinstall the computer.
Feb 17, 2011 | Dell Inspiron 1318 Laptop Computer PC...
Camera hangs up between pictures. when we take a
You may be short on memory. Check your settings. Are you taking images in the 'max' setting? In most cases you do not need to burn 5 Mb per image if you are printing 4x6 prints, then 300k should be fine. This will free up your memory card.
Dec 19, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Got a Ms-6368 ver 2.1 hangs or freezes on boot up
JUST DO THAT FIRSTLY CHECKOUT YOUR RAM IN YOUR CPU AND PUT OUT THE RAM AND THEN REINSERT RAM IN RAM SLOT
Oct 06, 2009 | Computers & Internet
I recently bought a IBook for $10 at a yard sale. I knew the previous owners and they got rid of the computer because it glitched so bad. They wiped the hard drive so the operating system isnt even on...
gtabblt.gif Identifying lock-ups and freezes gtabblt.gif Close locked-up programs and locate problem software gtabblt.gif Uninstall and re-install the problem software gtabblt.gif Contact the software vendor gtabblt.gif Understanding backwards compatibility issues gtabblt.gif Change the operating system emulation with the Program Compatibility Wizard gtabseps.gif This document pertains to HP Notebook PCs with Windows Vista. Identifying lock-ups and freezes This document will help you to locate and troubleshoot programs that cause your notebook to hang, freeze, or lock-up. Print this document or save it to your hard disk drive to have the reference available after disconnecting from the internet. Symptoms of notebook lock-ups, freezes, and hangs include:
  • Nothing moves or blinks on the computer display.
  • The computer will not respond to the mouse or keyboard.
  • An error message appears and will not go away.
Freezes, crashes, and lock-ups may be caused by programs locking up resources, software conflicts, or older programs being incompatible with newer operating systems. Follow the steps in this document, in order, until the problem is resolved. Close locked-up programs and locate problem software If your notebook locks up or stops responding while using a program, close the stalled program to continue using other programs. Also, while closing the program, take note of which other programs are running at the same time.
  1. Close the program that is "Not responding" and determine if the lock-ups continue.
  2. If the lock-ups no longer occur after the program is closed, go to Uninstall and re-install the problem software .
  3. If the lockups continue, press ctrl + alt + delete to go back to the Task Manager.
  4. Write down all of the programs that are running when the lock-up occurs. The conflict could have originated by another software application that is running at the same time.
  5. Close other programs that are running one at a time (except for Explorer and Systray) and determine if the lockups continue. Once you find the problematic software application, go to Uninstall and re-install the problem software .
Uninstall and re-install the problem software To resolve the problem that is causing the notebook to lock-up, uninstall the suspected software and then re-install it. If your software came with an uninstaller program, use it first; otherwise, follow the steps below to uninstall and re-install the program.
  1. Click Start > Control Panel .
  2. When the Control Panel window opens, select Uninstall a program.
  3. Select the program that is causing the lockups and right-click it. Then select Uninstall . NOTE: Remove all versions of the same program. Sometimes upgrades will not remove old versions of the software before installing the new version. This leaves multiple versions of the same software on your computer.
  4. After removing the problem programs, close the Control Panel.
  5. Restart the computer.
  6. Re-install the program following the vendor's instructions
Jul 09, 2009 | Apple iBook G4 Refurbished Mac Notebook -...
Computer hangs up
You dont need those stress you will only be concern on your processor or do you use the pc with a network as in is it connected for browsing if itis connected try and always clear your cookies and again the processor fan may not be blowing well so it can cause it to be freezing all the time once the processor works too much without cooling fan ok try and do something about that your system will be ok
sure
Please rate this solution.
Oct 30, 2008 | Acer Aspire 3000 Notebook
PcAmerica Software
Hello Crush,
in case your programs hangs out, restart your sql service , once you have done it, access your database from MMC truncate " buttons & execute tables " this will reduce the load on your sfware.
for the printer check the drivers make sure the kitchen printer shows availbale in printer setup.
Aug 06, 2008 | Pc America Restaurant Pro Express
13N6769 will only rip the first few songs of a cd then freeze
if the disk plays to the end in your favorite player it is a software problem.
if it stops when only playing in approximately the same place it is a hardware problem.
That is the sort of incentive I would add to convince trial users to upgrade to the full paid product, perhaps your license code has been damaged
Jul 18, 2008 | Lenovo (13N6769) CD-RW/DVD-ROM Combo Drive
Teac P11/KIT Thermal Printer Logo
1,277 people viewed this question
Top Teac Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Marvin
Marvin
Are you a Teac Office Equipment and Supply Expert? Answer questions, earn points and help others
